Question about Sony CDX-L480X CD Player
Sony CDX-L480X hi iam having problems with my sony headunit i cant put in a cd the cd player want grip it when i put it in the gap if i press the cd button it tells me to RESET so i do this you can hear the cd player winding but for longer then normal then it says RESET again ive tryed replacing the fuse and rewiring the cd player with a new power and earth wires and nothing happens but the strange thing is i tryed my old jvc cd player and its doing the samething cheers Ben
  • G8LPU Sep 16, 2008
    tHE cdx-l480x ASKS TO BE RESET, BUT WHEN i REST IT - IT STILL ASKS TO BE RESET
I had the same problem, CD not accepted by unit and pressing source button to select CD player causes unit to display reset.
Using reset button just causes unit to 'whir' for a while, problem is not solved. Firstly with unit switched off, and the ignition off I inserted a CD using some gentle force, I then inserted a second CD, forcing it in over the top of the first. Next I pressed and held the reset button for a short time before releasing it. Both CDs were ejected, when the unit had stopped I took the CDs out, replaced the front panel and turned on the ignition, The unit will now accept CDs and eject them O.K.
(This did take two attempts to get right). Seems to reset the eject status of the CD player.
Avulon
Posted on Aug 08, 2010
Same problem here (more or less). Unit was bought new, 6 years ago. This winter, I tried to insert a CD. Unit keeps humming for way too long, then tells me to reset. Resetting doesn't work either, unit hums for way too long, tells me again to reset....
Ejecting: same symptoms...
Already opened the unit up, hoped it was some mechanical problem, but found nothing strange.
Would like to know if there is a solution to this problem...
Posted on Jan 11, 2010
Salut
am o problema cu un SONY CDX-L480X
MI S-A FISURAT (RUPT) UN COLT DE LA PLACA ELECTRONICA DE LA PARTEA CU DISPLEIUL SI NU MAI STIU CARE SUNT TRASEELE SA-L REFAC
DACA MA POATE AJUTA CINEVA VA ROG CU O SCHEMA SA-L POT REFACE SAU MACAR CU O POZA FATA VERSO CU COLTUL DIN DREAPTA JOS
MULTUMESC
Posted on Jun 28, 2008
I have a Sony CDX L480x fitted in my car, this radio has worked fine since i got the car, unfortunatly when i put the face back on it the other day, none of the buttons will work, volume, source...etc. All...
It sounds like the volume button may be jammed or the volume up switch may be bad. If the switch is open just enough to let some voltage through it locks up the microprocessor. Unless you have a multimeter and know how to check resistance on a switch you would be better having a professional repair person check it out.
Sep 29, 2011 | Sony CDX-L480X CD Player
I just want to no what colour does what job on my sony cdx-l480x player just ripped it out my old car and cant find the wireing diagram
Yellow: battery constant 12v Red: Ignition 12v Black: GND ground White and White with Black stripe: Left front speaker. White is positive (+) Grey and Grey with Black stripe: Right front speaker. Grey is positive. (+) Green and Green with Black stripe: Left rear speaker. Green is positive. (+) Purple and Purple with Black stripe: Right rear speaker. Purple is positive. (+) Blue: Antena remote turn on. Blue with Wite stripe: Amplifier remote turn on. I think thats all of them. Make sure to connect your positives and negative correctly or you will have phasing problems. dreamsystems
Feb 08, 2011 | Sony CDX-L480X CD Player
I would like to fit the cdx-L480X into my caravan
ok that will work fine please tell me what the problem is genrally if ir caravan had a tape player the plug should be the same as this unit uses a uni plug if not there will be a converter for under 5 pounds
Jan 19, 2011 | Sony CDX-L480X CD Player
Hello! My Sony CDX-L480X car radio can't read the CD-s. Could somebody help me to solve the problem?
Please try to put in an ordinary audio CD track and see if this is detected. If yes the optical is working, if not there is no laser scanning ,then the possibility of the head being faulty is high.
Now certain cleaner disks are not read and so will not be tracked. Hence it could reject but the best is do a cleaning manually of the laser head eye with a cotton bud very softly and without any pressing of the lens eye.
If there is still no result then watch the CD if it spins or tries to spin. If the head unit moves up or down to focus or in and out of the drive, if so the board seems to work correctly and the possibility of the optical head being the suspected fault is closer.
But if any of the above seems otherwise we must recheck with possibilities of the processor board
Nov 27, 2010 | Sony CDX-L480X CD Player
No instructions on tuning radio
The Manual is downloadable from Sony at
http://pdf.crse.com/manuals/3247340121.pdf
Avulon
May 19, 2009 | Sony CDX-L480X CD Player
Clock
Hi, i have a manual in front of me. To set the clock
press DSPL button for 2sec
press volume +/- button to set the hour
press SEL, then the minute indication flashes
press the +/- button to set the minute
Press DSPL.
hope this helps
Feb 11, 2008 | Sony CDX-L480X CD Player
Sony CDX-L480X CD Player Logo
650 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
