Question about Canon i860 InkJet Photo Printer
My Canon won't clean its print heads
My Canon i860 has a dirty black print head, but it won't initialize cleaning. The queue just disappears without it doing anything. I have tried selecting just the black head for cleaning, selecting "all colors", and have tried both regular and deep cleaning. Nothing so far has made it execute. My Canon i860 won't print the black even though I've installed new cartridges.
    Genius:
  • 3,422 Answers
Switch off the printer and disconect the USB cable for 30 seconds. deep clean on the black head to get it work properly.
IF this doesn't work then please follow the below 2 options to clean the print head.
Option
1:
It appears that the internal print head ports were clogged with ink. Try removing the print head and washing it in alcohol- when I did this i had clumps of congealed ink coming out of the tiny ports. The print head has two small screws underneath that I also removed and cleaned the ports inside by use of a syringe and alcohol. After I put the print head back together, dried it and ran an auto alignment - it all seems good now.
Option 2:
If your cartridge has been sitting outside for more than a couple of days, it is very likely that your print-heads may be clogged.
  1. Step 1: Place the clogged nozzles in warm water and soak them until the dried ink begins to flow from the nozzle.
  2. Step 2: After a few minutes of letting the dried ink flow, remove the nozzles from the water and dry it with a soft tissue or cotton swab.
  3. Step 3: Reinstall the cartridge and run the print-head cleaning mechanism (described in your inkjet printer's manual).
  4. Step 4: If this does not work, repeat the procedure.
  5. Step 5: If your cartridge still does not print after repeating, uninstall the cartridge and place it on a soft tissue or cotton swab with rubbing alcohol in an upside down position. Let the cartridge sit on it overnight.
  6. Step 6: Reinstall the cartridge and run the print-head cleaning mechanism (described in your inkjet printer's manual).
  7. Step 7: If none of the procedures above works, then you did your best, unfortunately you will need to purchase a new cartridge because the print-head is probably clogged permanently and/or damaged.
As you said even after installing the new cartridge it does not print then i think the cartridges are not recognised by the printer.
step 1: Run the print-head cleaning mechanism (described in your inkjet printer's manual) and attempt to print a few pages.
Step 2: If this procedure does not work, using the syringe supplied in your refill kit, inject air into the top air vent to clean the nozzles. A small amount of ink should be emitted from the nozzles upon injection. (The nozzle is the porous metal piece at the bottom of the cartridge)
Step 3: If this procedure does not work your print-head nozzles are probably blocked with dried ink. At this point use the syringe to take out as much ink as possible from your cartridge and read on to the next section.
Goodluck..
Posted on Feb 17, 2008
    President:
  • 1,944 Answers
Have you tried power cycling the printer?
3e black cartridge not printing. Canon i860
Did you try another cartridge?
What can happen sometimes is that the print head can get blocked.
You can clean that by removing the print head from the printer. Do not touch the foil on the head or the print nozzles.
Boil some water, pour 1/4 of an inch (6mm) of water into a saucer, place the print nozzles in the water for a minute or so.
Take the print head out of the water and touch it on a paper towel to get the water off.
Reassemble the printer and see what happens...
Feb 20, 2010 | Canon Office Equipment & Supplies
Nozzle for cyan blue will not cleen. photos print without blue.
Try print head cleaning first. if standard cleaning does not work perform deep cleaning. If the problem still persist you should replace your print head.
Source:
Canon i865 Service Manual
Inkjet Zone
Nov 03, 2009 | Canon i860 InkJet Photo Printer
Why has the print quality gone down on my i860 printer
The head may be dirty or misaligned.
Run through the tools on the printer to clean the printer head and realign the print head.
If this does not work, then you will have to remove the print head and clean it (with rubbing alcohol) until residue is removed. Or you can soak it over night with a 25% rubbing alcohol and 75% water mixture.
Dont take your printer apart unless you know how.
Aug 04, 2009 | Canon Office Equipment & Supplies
My Canon i860 just can't print out black words, it's frustrating
pull the ink cartage back out to see if a clear film is not on the cartage??? Check the area by cleaning the ink cartage with rubbing alchole, and also the area that the ink cartage goes into. Use a cotton ball the clean these area with.
Jan 31, 2009 | Canon i860 InkJet Photo Printer
After deep cleaning the print heads, it will only print one page
This sounds like the print head alignment is not stabilized and may indicate you need a new print head ($$$). Try looking in the Service Manual.
A copy of the Canon i860 Service Manual is downloadable at:
http://rapidshare.com/files/179582794/Canon_i860__i865_SM_-_printer1.blogspot.com.rar
The password to open the compressed PDF file is: printer1.blogspot.com
Jan 24, 2009 | Canon i860 InkJet Photo Printer
One color
yep, print head needs proper clean, here it is.
OK, Canon will hate me for posting this.
1. Remove ink cartridges
2. Remove print head
3. go to sink or tub (stainless steel, not plastic type), pick up a roll of paper towel on the way.
4. Fold several layers of paper towel and place on flat surface.
5. Run hot water until HOT!
6. Turn hot water back to a dribble.
7. Run the dribbling hot water through print head, be careful not to wet the gold contacts.
8.When water running through print head is clear, place print head on paper towel.
9. Repeat number 7 and 8 until no colour shows on paper towel.
10. Gently DAB print head (DO NOT WIPE) inside and out with dry paper towel until dry.
11. I normally replace print head after drying, but you may wish to let it air dry overnight.
12. Replace print head in printer and install cartridges
13. Start printing.
I do this to all 4 of my Canon printers every 6 months or so.
If any colour fails to print after this process it means your print head probably needs replacing.
Jun 29, 2008 | Canon i860 InkJet Photo Printer
Canon i860
Print head temperature rise [5200]
I would assume that the cleaning efforts resulted in oveheating the print heads.
Please ensure that you have sufficient ink, as ink acts as a lubricant for the heads.If you try to use them while empty it is equivalent to driving a car without oil.
Take your time..
Verify ink is in all cartridges.
Remove paper jam
let the printer cool off (heads)
Chances are the head alignment is not necessary and you are low on one of the inks...
Try this test program (Page) to isolate low colors...
http://www2.clicshop.com/Stores/metawatch2/Files/metawatchprintertestpage.pdf
Feb 10, 2008 | Canon i860 InkJet Photo Printer
How to remove printhead from canon i860
The gray-colored arm (it's not that small) is to the right of the cyan cartridge. It is the arm or extension of the gray-colored hinged cover. Remove all ink cartridges, lift the gray-colored arm up, and pull the print head out. Clean the print head with a cotton ball soaked with water or rubbing alcohol. Dry and re-install the print head.
Feb 01, 2008 | Canon Pixma MP500 All-In-One InkJet...
Canon i860 InkJet Photo Printer Logo
205 people viewed this question
old marine
old marine
