Question about Garmin GPSMAP 178C GPS Receiver
Certain keys unable to push
When I push the down arrow key, the find key and the nav(mob) key it just gives the beeping noise and will not allow the keys to work.
    Problem Solver:
  • 5 Answers
Hey there...
if you tried to install a new software on your device then it might be a skin problem...or a resolution error...
if the software if the original one...and it worked untill may be lucky to fix it with a software update from the manufacturers` oficial site....BEWARE: do not try to update it if you are e real newbie in this domain....
Posted on Feb 23, 2008
I have a salt water pump 8110. It won't go pass start up and when I push the left button it just keeps beeping. It will not let me unlock the keys to set timer. I have already unplugged for 10mins....
Okay... Let's do this step by step...
1st... Press the down arrow button until you hear the beep and let it go quickly..
2nd ..Press the up arrow button until you hear the beep and let go quickly..
At this point, the LED reading should be blinking 00.. If it is, you have unlocked the keys and you can now press the up arrow button to increase the timer to 01, 02 and up to 12. Note: To adjust the time, press the up arrow button in short intervals, do not hold down the button. It tends not to adjust if you hold down the button longer than 1 sec.. I hope this helps and it not a bad unit.. If it did, please post a comment and rate.. really appreciated...
Aug 08, 2011 | Intex Automatic Salt Water System for ...
This is the counter inside the printer which stops the printer unless it is reset. Follow the below steps to do the reset on your printer.
How to Reset Brother DCP 110C, 115C, 120C, 130C, 135C, 145C, 150C, 165C, 185C, DCP 195C Printer
May 25th, 2011 • Printer
How to Reset Brother DCP 110C, 115C, 120C, 130C, 135C, 145C, 150C, 165C, 185C, DCP 195C Printer:
1. Press the Menu, then Mono Start key then press the UP arrow key 4 times to make the machine enter the maintenance mode and "ERROR 46′ pops-up in the display.
2. Enter maintenance mode 80: Select 8 by pressing the UP/DOWN arrow key and push OK key and select 0 and push OK key
3. Now Press MONO arrow key several times until you see PURGE:XXXXX
4. Select 2 and push OK, Select 7 and push OK, 8 and push OK, select 3 and push OK and the purge counter is now reset to 00000.
5. Press STOP/EXIT key to go to root of maintenance mode
6. Enter code 99 to exit maintenance mode: Select 9 and push OK, Select 9 and push OK.
Jul 24, 2011 | Brother DCP-110C All-In-One InkJet Printer
Ringer off on line 2
To turn the ringer off (or on)
press the conf/ function key,
scroll to "ringer volume" using the up and down arrow keysand press the forward arrow key
press the down arrow key for line 1 and the up arrow key for line 2
select the desired ringer volume by pressing the up and down arrow keys or press the down arrow repeatedly till the screen says "ringer off?"
press the save key (right soft key) you will recieve a conformation beep.
you can exit programming mode by pressing the off key.
Jul 20, 2010 | Panasonic KX-TG2740 Cordless Phone
Multiple lights are lite when running a cycle....can't run certain cycles (bulky items, whites etc) spin light continuously blinks. have tried unplugging and restarting with no results
I feel you may have a Control Board issue. I would see if the Control Board will let you into Service Mode. If it does I would read the Diag code blocks 1 thru 40. The block only show up when an error event has been logged.
Bottom line I see no easy way out without least swapping out the Control Board for a start point.
You will need the FAV6800A/FAV9800A Service Manual to get started. See page 17 of the SM TO READ THE Diag codes
FAV6800A/FAV9800A Service Manual for reference. Sears Parts Direct for reference.
Here is a quick start if the Control Board will let you into Service Mode;
To enter Service Mode press and hold simultaneously the Enviro Plus and Spin Only keys until the machine beeps and the LED display reads 00.
From the Service Manual;
Display Diagnostic Codes
The diagnostic code display can be toggled on and off from Service Mode by pressing the Wrinkle Control key. The display will show a “d”. The diagnostic codes can be viewed by using the Set Delay Time arrow keys. The Set Delay Time down arrow key will cycle down the list one code at time each time it is pushed. The Set Delay Time up arrow key will cycle up the list one code each time it is pushed. The first time the Set Delay Time down arrow key is pushed, the newest code will be displayed. A code generated during or after the current cycle will be displayed with the rightmost dot “.” turned ON. Access Other Features While a diagnostic code is displayed, if the Normal
If you decide to give it a try jot down the code blocks and toss them back to us for review.
The Control Board p/n 25001217
Another vendor Clothes Washer Control Board - 25001217
Good Luck Rich
Dec 29, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Can you turn the beep noise off on the keys?
Yes. Press "Data Registration" then "Set" then "Set" .Now arrow down until you see Volume Control. Arrow down until you see Keypad Volume. Make that number "0" and press "Set". Press "Stop" button to escape to normal operation mode. Hope this helps.
Aug 26, 2009 | Canon LaserClass 9500S Fax
sc 542 is when the machine cant warm up to temperature for whatever reason usually entering service mode via clear 107 clear stop and rebooting clears the code if that dosnt work then the next step is call a service engineer
Feb 19, 2008 | Ricoh Aficio 2022 All-In-One Laser Printer
Setting clock
First select calender press enter. to set date press stop then use < arrows > to set year, up and down to set month, press stop to comfirm. Then use navigation buttons to select cuarrent date and press enter to confirm. To exit press menu button.
Use nav buttons to select clock, press enter to confirm the clock display will appear.
To set clock press menu for custom set up. Use down arrow key to find "set time" right arrow to kighlight set time press enter, then arrow keys to set time then enter then left arrow all the way to the left then down to exit, athen enter.
Hope this helps.
First hit setup then find settings, then enter. Use arrow keys to change time, then enter
Remote Difficulty
Looks like you are in trouble may have to buy origional remote.there are certain programmable remotes out there which give every function of the origional.most service centers have them,they have to be programmed by computer to suit each individual set.
May 16, 2007 | Pioneer PRO-1009W 57" Rear Projection...
Garmin GPSMAP 178C GPS Receiver Logo
Top Garmin GPS Experts
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
