Question about JVC HD-52Z575 52" Rear Projection HDTV-Ready Television
JVC HD-52Z575 My tv displays a reverse blue image all the time on screen. Is this an expensive repair?
  • Melissa Lambert Apr 08, 2008
    I am having the same problem where the color is reversed...has anyone seen this or know of the fix code?
You both need to have a service center come out and reset the TV using the reset jig. This will correct the reverse image problem.
Posted on May 11, 2008
JVC HD-52Z575 tv shows only a grey picture screen. I was watching a channel and tried to change channels and new channel won't come up, only grey screen.
JVC HD-52Z575 52" HD-ILA HDTV-ready rear-projection TV
www.amazon.com/JVC-HD-52Z575-HD...HDTV.../B...
Amazon.com, Inc.JVC HD-52Z575 52" HD-ILA HDTV-ready rear-projection TV ... The picture was artifacted and the color was good, but not great. ... From 5' some minor issues could be seen and the MPEG2 format did show its limitations, but at 10', it was a truly great experience! ... There is no true gray temperature, only high and low.
HOW TO FIX A JVC HD BIG SCREEN TV - YouTube
? 6:38
https://www.youtube.com/watch?v=r4v-xzUpQDM
Apr 11, 2012 - Uploaded by kyle dubb
Did your HD D.L.P. t.v. stop working? This movie clip will showyou step by step how to easily fix your big ...Missing: grey
JVC HD-52Z575 HD-ready rear-projection D-ILA monitor ...
Jan 10, 2016 | JVC Televison & Video
MY JVC52Z575 (D-ILA) HAS A REVERSED BLUE IMAGE OF ANY YELLOW IMAGE
I have the same blue shadow with reverse image on my JVC HD-52Z575 Did you see what the problem on yours finally was?
Feb 20, 2011 | JVC HD-52Z575 52" Rear Projection...
Jvc 52 rear orijection top has doulbe image in
Ur convergence is dead.Must know how to solders?Must replaced 2 convergence ICS and some or all it resistors.Tries websites Tv repair World.com,Tvrepairkits.com to buy a convergence to repair it ur self.The shop will cost u $300 for parts and labors.
Mar 14, 2010 | JVC HD-52Z575 52" Rear Projection...
JVC HD-52Z575 red screen
The solution is an easy fix. Ignore anyone telling you to take it to a service center or to replace the convergence driver. You need to access the service menu on your television by using your remote control:
DRIVE CONVERGENCE Adjustment (Using remote control)
•Use the inner RGB box pattern.
(1)Set the [SLEEP TIMER] key to 0 min.
(2)Press the [DISPLAY] key and the [VIDEO STATUS]key simultaneously.
(3)Press the [9] key to display the RGB box pattern.
(4)Select the R mode by pressing the [DISPLAY] key.
(5)Adjust the R mode to setting as same as G mode bypressing the [CH ]+ / [CH -] key.
(6)Select the B mode pressing by the [DISPLAY] key.
(7)Adjust the B mode to setting as same as G mode bypressing the [VOL] - / [VOL +] key.
(8)Check to see that the cross pattern is white. If thecross pattern is not white, readjust (5) to (6).
That's it, your color is now corrected. Yes, I know...your welcome.
Feb 20, 2010 | JVC HD-52Z575 52" Rear Projection...
Lost
You will need to have a service center come out to try to reset the TV using the reset jig. A JVC authorized service center will be the only ones that will have access to and training to use this jig. It is a good chance reseting it fix the color problem but it could also be something more serious.
Apr 22, 2008 | JVC HD-52Z575 52" Rear Projection...
Vertical lines problem
On your blue tube there is a crt broad that may have a bad capacitor 4.7uf 250 volts most likely it can be leaky not able to hold correct charge also it might have video ic on same broard breaking down, this will cause your problem unplug crt broad from bottom neck of tube turn set on see if problem goes away if so then it means you have problem with crt broad or it could be your tube.Hope this helps you out!
Jan 18, 2008 | JVC HD-52Z575 52" Rear Projection...
JVC HD-ILA PROJECTION T.V. #HD-52Z575
You both will need to have a service center come out to try to reset the TV using the reset jig. A JVC authorized service center will be the only ones that will have access to and training to use this jig. It is a good chance reseting it fix the color problem but it could also be something more serious.
Nov 29, 2007 | JVC HD-52Z575 52" Rear Projection...
JVC HD-52Z575 52" Rear Projection HDTV-Ready Television Logo
199 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
