Question about Whirlpool Calypso GVW9959K Top Load Washer
Machine just freezes and doesn't work - on occasion
The machine often just freezes up and none of the buttons work. If the lights do go on, it gets stuck on "Wool" mode and stays there, but does nothing else. You can't push start. None of the buttons work. Usually when the washer does this, it mysteriously will start working again maybe days later. It is stuck once again in Wool mode (but it does not RUN in wool mode, the light just stays stuck on that mode). Help!
When I press the start button it some times will not start or it my start instantly. Holding the start button down for a period off time it may start. The circuit board has been replaced once because it refused to start.Does Whirlpool have any fix for this problem. Very frustrating and expensive.
Ken
  • 1 more comment
  • JRA52551 Apr 12, 2008
    Got the exact same problem. Sometimes it would clear itself but has gotten progressively worse. Took the whole top assembly apart and could not find anything wrong. Put it back together and it worl a couple of cycles then went back to the wool mode. I dont think it is the keypad but I may be wrong. I think it is a machine control board intermittent fault with the microprocessor. Will ipdate if I verify this.
  • ddiers Apr 24, 2008
    none of the buttons work, its almost as if it has no power going to it. Checked plug and it does have power. I think the matching dryer to this machine did the same thing while it was under warranty. Is there a reset button or something?
  • Conklin6103 Apr 28, 2008
    I am having the smae problem except my washer is stuck on Normal mode. When you push the start button, sometimes it works and sometimes it doesn't. When it does start is starts to fill but then immediatley freezes back up and won't start again.
    Sniper:
  • 65 Answers
Both seem to be touchpad problems
Posted on Feb 18, 2008
Husqvarna sewing machine freezes and stops sewing
Is it a mechanical machine or computerized? If mechanical, it could need a good cleaning and oiling. Mechanical machines need to be oiled, and if not, the old oil solidifies and prevents the mechanical parts from moving.
Mar 15, 2015 | Husqvarna Sewing Machines
Ice getting to thick and not dumping
go to the freeze timer which has off and on dip switches. take some freeze time out by moving the first switch to off this will shorten freeze time. Also check the harvest assist solenoid and plunger when it go's into harvest. make sure the machine is cleaned and check the cube plate to make sure that none of the plates are not loose this will cause ice to freeze between the loose spots and will not let ice come off the plate.
Jul 21, 2014 | Ice-O-Matic ICEU220HA Undercounter Ice...
Everytime my notebook gets started up it freezes about 45 seconds later
It seems alot of people have had similar issues with these PC's.
Sounds like it could be a virus or registry error. But could also be a hardware error. Does the machine run hot? If so, try cleaning the vents and running it on a hard, flat surface. If that doesn't work I would try running an anti virus and/or anti malware program (in safe mode if that's on option) If that doesn't find anything, then you could try reinstalling the O/S.
Is there a recovery partition on the hard drive?
If none of the above works, then it is probably a hardware issue, hard drive or RAM error, something like that.
Mar 16, 2012 | Sylvania Computers & Internet
My LG washing machine has power but no light display and doesn't work. I washed a bathrug and when I returned the machine had power (makes a tone when the on button is pushed), but none of the...
I have a LG WM2016CW and after I washed a med. rug none of the lights on panel wwould not work but it did ding when I pushed the start button. so after reading other solutions one said something about checking the door switch so I tried washer n woulnd'nt work so I opened the door and pushed on the door switch and it started. thank you I hope this works for u...
Oct 11, 2011 | LG WM2016C
"Clean" light keeps flashing. Machine doesn't
Hello & Welcome to FixYa
Flashing light is reset by pressing two buttons in sequence 3-4 times, to reset your dishwasher press these buttons in sequence:
High temp wash-heated dry-high temp wash-heated dry
Please get back to me if you have any other questions.
Kevin
Jul 15, 2011 | Kenmore Dishwashers
Washing Machine stops in cycle.
The ECU seems bad.
Look for the service manual inside and do the diagnostic test to see what is wrong.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 06, 2009 | Washing Machines
After static shock, keypad on fax machine is not working...everything else ok
Most office machines are properly grounded and don't suffer from static problems as severe as this. The machine is not repairable. Before you replace the machine, make sure that your electrical outlets are properly grounded. Then buy a line conditioner that will protect against this.
Nov 30, 2007 | Brother IntelliFAX 1270E Plain Paper Fax
Whirlpool Calypso GVW9959K Top Load Washer Logo
197 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
