Question about Kenmore Progressive Bagless Upright with Inteli-Clean SystemVacuum
How to take the brush out?
A string is stuck inside the left side of the brush of my Kenmore Progressive Bagless. How do I take the brush out to remove the string?
Thanks for your help.
  • KenMoreHelp Dec 05, 2008
    You are right. It wasn't easy to take the bottom out. Unscrewing the screws was only the easier step. Dealing with how the cover was jammed in place was the harder part. It is ok now. Thanks for your help.
    Problem Solver:
  • 7 Answers
This is actually incredibily difficult on this vacuum because of the no belt, dual motor setup. Try cutting the string from the outside without opening the vacuum.
Posted on Dec 05, 2008
    President:
  • 1,673 Answers
There should be screws on the bottom plate covering the brush roll, take those out and it should come off and then you can access the brush roll.
Posted on Feb 17, 2008
I need to replace the belt
maybe the belt slip off or look on the brush`s for where the belt goes, should be on one side or the other.
Feb 15, 2014 | Kenmore Progressive Bagless Upright with...
Agitator doesnt turn
There is actually a reset button on the agitator, I would try pushing this switch first to see if this fixes it. The button is located on one of the sides of the agitator housing, I'm not sure if it's the left or the right side, or on the top of it.
Look on the sides of the part of the vacuum that is on the floor and see if you can see a small red pole on either side. If you can't find it here, look on the top of the part of the vacuum that touches the floor for a brush overload reset switch.
Try pushing that poll whenever you find it. This switch is a protection mechanism that will shut the brushes down to protect them if something gets vacuum up inside of the brush, it will automatically shut itself off to prevent any damage.
Simply push this overload switch down, and this should hopefully fix your problem.
If this didn't, please let me know and I can walk you through some more advanced troubleshooting.
If this was helpful, please be so kind and rate my repair, or leave feedback.
Thank you!
Chris Jones
GoVacuum.com
May 18, 2010 | Kenmore 31913 Progressive Direct Drive...
Agitator unit on Kenmore Progressive 116.25915503 won't spin. I have cleaned out all hair and string wrapped around it. Belt is good. It seems to spin on one side but stuck on the other. Could string be...
Pry the end caps off the brush bar, you will find hair and string wrapped up tight in the end. the bearing may also be shot, you can try and oil it up a bit to keep it spinning. <!-- from fixya rte -->
Oct 21, 2009 | Kenmore Vacuums
Loud noise/Sounds clogged
You could have a clogged air filter and vacuum is not getting air to motor. You could have hair and string buildup on ends of roller brush. You can put a vaccum hose over a broom handle to clean it out. Also, check the little elbow of the hose at the bottom f vacuum where it bends.
Aug 28, 2009 | Kenmore 35912 / 35913 Progressive Upright...
Only suction to attachments
Something is stuck in the throat of the floor head, between the brushes that turn, and where the hose connects at one side (usually right hand side) of the floor head.
Reply back what you find.
Feb 04, 2009 | Kenmore 35912 / 35913 Progressive Upright...
How do I take the brush out?
Most of these progressive drives have a bottom plate that you can take off, then you can get to the brush roll asm. There will be several screws.
Feb 17, 2008 | Kenmore 31913 Progressive Direct Drive...
Kenmore Progressive Bagless vacuum cleaner
Check down by the brush roll to see if the inlet is clogged. This type of problem usually means there is a clog. But you do have a year's warr. on this, if you can't figure it out, then take it a Sears repair shop.
Jan 15, 2008 | Kenmore Progressive Bagless Upright with...
Kenmore Progressive Bagless Upright with Inteli-Clean SystemVacuum Logo
200 people viewed this question
Top Kenmore Vacuums Experts
Chris Nomland
Chris Nomland
Marvin
Marvin
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
