Question about Rio Carbon MP3 Player
Rio Carbon upgrade
I have a couple questions...
First, the charge on my battery is nowhere near the 20 hours claim, more like 4-5 hours. Is it possible to find a replacement anywhere to swap it out?
Next, it seems the storage inside is a seagate microdrive...has anyone ever attempted to swap this drive with a 8 or 16gb CF card? I would think that getting away from a mechanical drive would help battery life alot!
Finally, I find that some songs on my carbon will cause it to reboot. I'm not sure if it's wacky characters in the ID3 or not...any thoughts?
I have the most recent firmware installed...
I don't have a lot invested in my Carbon (it was a gift from Microsoft of all places, from the pre-Zune era), so if I were to foul up an upgrade, the worse case scenerio would be I have a new 5gb microdrive for my camera!
I appreciate any feedback!
fz
  • frankz May 05, 2008
    I will try to upgrade the storage...still curious if a non mechanical flash would work.
Fz,
Battery
I have had my Rio since they first came out and have had no problems. It gets daily use and has seen many drops and lots of travel. I got 23 hours when new, now more like 15+.
I have not found a replacement battery yet but will post when I do.I found the company but not a distribution source.
Hard Drive Upgrade
If you are going to replace your hard drive because of the issues you mentioned, you might be interested in what I just did:
I just (today) upgraded my drive because the 5GB was not enough. I love the Rio simple interface and wanted more space so I took a chance and bought an 8GB Seagate drive. I just finished installing it and it works great.
Upgrade procedure:
0. Buy the drive
I Used Seagate ST1.2 Model: ST68022CF
I got the certified repaired drive for about $35 at digitalet.com. I figure if it dies, I have music backed up anyway and it was cheap.I didn't want to spend much on a test. I will now look for larger capacity drives to see if they work as well since I like the Rio form factor so much.
I purchased the drive here:
http://www.digitalet.com
Digitalet Item #42399184
8GB Seagate ST1 Compact Flash CompactFlash CF II Card
Price: $33.95
Inventory SKU: DMC-ST68022CF-R
1. Offload music
... from existing 5GB Drive. I simply used Windows Explorer and dragged the entire Music directory on the Rio to my laptop HDD. This preserved the music in folders which I like.
2. Open the case
I found instructions somewhere on web but cannot remember where. At the end of the day, it is an exercise in patience and feel. There are 4 clips that hold the back cover to the unit. Use 2 small flat ***** drivers or a thin metal blade.
3. Remove existing drive
Remove the drive from leaving the cable that goes from the board to the drive attached tothe board (you can remove it but I wouldn't). The end of the cable has traditional pins that mate to a CF card so be careful not to damage them as you remove the cable.
4. Install new drive
Being careful not to damage the pins.
5. Turn on the power and Flash the firmware
You will see the message UPGRADER on the display .Go to the Rio support site and download the firmware. Follow the instruction on the site to upgrade the firmware. http://www.digitalnetworksna.com/support/rio/
6. Reload Music
Once upgraded, the drive is formatted by the Rio and you are ready to reload your music files. There is about 7.6GB free space after the upgrade. I used the Rio Music Manager to reload the music onto my player.
-end-
Posted on Mar 12, 2008
Rio carbon player does not start it reads UPGRADER. I tried resetting needle in hole but still reads UPGRADER
try puting a cf card in it or look up problem on google if this doesnt help hold in menu and power for 4 seconds see if this helps in undoing the upgrader message if not try connecting it to a windows pc with xp or 7
Aug 13, 2011 | Rio Carbon MP3 Player
Is Rio Carbon compatible to Vista New computer not recognising Rio
it appears that it is. should be automatically recognized by vista. if not it may have failed. try unplugging the batteries for about 20 minutes.
Nov 30, 2009 | Rio Carbon MP3 Player
My rio carbon says upgrader and won't switch on any help thanks
http://www.digitalnetworksna.com/support/rio/product.asp?prodID=215
Go here and download the firmware.
First Reset your player, Do not turn back on. Plug it into your usb cable. Download your updates then run them.
Do not touch your player till your done.
It worked for me. Right now it started to charge. I
I went here for a solution. Then ended up providing one. He he he. Good Luck.
Nov 25, 2008 | Rio Carbon MP3 Player
Pearl rio carbon mp3 player 5gig
The microdrive is probably broken. Some people have claimed that if you give the sides a sharp tap then it has worked again but if this doesn't work then you probably require a new player. I have managed to replace the microdrive with a CF card in my Rio carbon, this has worked for many people may not work for you (you can read this: Replace broken hard drive with CF card if you want to try)
Hope this helps,
Mowcius
Oct 31, 2008 | Rio Carbon MP3 Player
Rio Carbon 5 GB: Battery loses power fast when player is turned off
The battery is not normally something that wears out on a Rio Carbon but if it used and charged wrong then it can either be conditioned to a shorter time or wrecked. Because it goes flat when turned off but keeps charge when on makes me slightly confused but anyway... I would advise charging it up fully and then flatten it fully - just leave it playing while you're out or something. Do this a few times and this may solve your problem. This will put maximum charge into your battery and it might solve your problem. If not then try taking the back off and look for a short circuit or obvious hardware fault.
Hope this helps,
Mowcius
Jul 29, 2008 | Rio Carbon MP3 Player
No content message???
Perform a firmware upgrade as instructed on the rio website - it will wipe everything clean. Make sure the player is fully charged or this upgrade will kill the player.
Oct 29, 2007 | Rio Carbon MP3 Player
Rio Carbon stuck "WRITING"
The writing message may appear for a good forty minutes after completing the firmware upgrade - make sure your player is fully charged and just let it sit for an hour on that writing status - it will stop eventually.
Sep 10, 2007 | Rio Carbon MP3 Player
Rio carbon upgrader message
Hi Linda, Your Rio Carbon is telling you that something is messed with its firmware and it can be resolved with an upgrade. You have to determine the exact model of your unit and download the firmware from http://www.digitalnetworksna.com/support/rio/. Again you must choose the exact model. There are two ways of updating firmware updater or internet updater. complete instructions are also available. further you would need to connect your Rio to a PC to perform the upgrade. Good luck and pls post back should you need further information. Kind regards.
Aug 20, 2007 | Rio Carbon MP3 Player
Stuck in Upgrader etc
well i own one too and thats probly the hard drive being stuck...just smack it against something hard , like sorta bump the rubber armor against the heel of your hand or a countertop...worked good for me...ya have to do it a few times...dont worry rio is defunct so theres really no warranty to think of anywayz
Feb 22, 2007 | Rio Carbon MP3 Player
Battery just quite on my carbon
I read about this place - Immergut Battery Haus Inc. 540 West Main Street New Holland, PA 17557 (717)355-5288 someone got a battery for a rio riot from them for just 20 $. But taking the battery out wasn't so simple, you should call them to consult. Good luck
Nov 28, 2005 | Rio Carbon MP3 Player
Rio Carbon MP3 Player Logo
631 people viewed this question
Top Rio Audio Players & Recorders Experts
Mohammad Abumuailek
Mohammad Abumuailek
Joseph Hoffmann
Are you a Rio Audio Player and Recorder Expert? Answer questions, earn points and help others
