Question about Kenmore Elite 45986 Front Load Washer
Kenmore front loading HE3 makes knocking sounds during spin cycle
Our HE3 front loading washing machine is making a knocking sounds as if there were base balls inside during spin cycle.
  • 5 more comments
  • Lumen5 Feb 17, 2008
    Hey, sorry to hear about your troubles mine were solved fairly easily.  I got advise from a fellow through epinions.com.  He advise me to take the back cover off and tighten the 15/16" nut in the center of the pulley and it worked!  It took me all of 20 minutes to do this.  No more knocking.
  • sporkles Feb 19, 2008
    Yes, our washer is knocking too. The belt seems to be off the pulley and the nut that holds the pulley on doesn't seem to tighten anymore. I can't believe a $1000 washer would go bad after less than 5 years. What total crap they sell today.
  • Nigonsf Jul 10, 2008
    Continue to have a knocking sound when in spin cycle. Replace the worn pulley on the back and shimmed up the pulley to be tight and centered. Still makes the noise. Checked to see if the bearing seemed to have any "play" as I turned the drum from behind and it did not seem to grind or have any extra play.
    Still trying to make the machine run quieter and was wondering what the issue might be?
    Nigonsf
  • Anonymous Mar 15, 2014
    is there a ball in the outflow pipe of a logixx 9 front loading washing machine?
  • Anonymous Mar 18, 2014
    When washing no sound, when spin dry starts can hear the sound, it gets louder as machine spin increases
  • Anonymous Mar 22, 2014
    Washing machine makes banging noises during use.
  • Anonymous Mar 29, 2014
    I have a GE front loading washing machine, during spin cycle, I smell and see smoke ,and the stainless steel drum burnt my arm. What is causing this and how can I fix it!!
Ours started knocking several months ago and then progressed to a high pitched sound when in the spin cycle. I manually turned the drum and heard and felt a bearing roughness. I lifted the drum assembly and felt a fair amount of play, which I think the initial knocking noise came from. On the sears web site a new rear drum mount cost 293.00. Today we went and bought a LG model wm2455hw at Home depot, on sale until 2/20/08. I couldn't see paying to repair a machine that only lasted four years.
Posted on Feb 17, 2008
SOURCE:
Why Electrolux front load making knocking sounds during spin cycle. Model ewf1087
Good Morning Friend,
I understand your Electrolux washer, model# EWF1087, is making knocking sounds during the spin cycle. In researching your model number, I show that your appliance was manufactured in Australia. If this were manufactured in the U.S., I would suggest making sure that the load was balanced. Balance your wash load and if you are still having trouble, I suggest contacting the manufacturer in Australia. Hope this is helpful.
-Best Regards-
WP
Jun 22, 2014 | Electrolux EW1200i Front Load Washer /...
Noise during high speed spin cycle
sounds like the bearings need replaced, when replacing bearings you need to replace all of them to ensure proper function and life longevity.
Dec 11, 2007 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
While spinning makes a knocking sound
is that a top load or front load washer?
Feb 28, 2014 | Whirlpool Washing Machines
No spin cycle
Suspect there is heavy load in the spin cycle which makes it trip off. You need to check the free movement of the drum and also the motor.
Nov 20, 2013 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
I have a kenmore he3 the erroe code says "sud" can
SUDS LOCK (to much detergent detected during the wash cycle)
he motor control unit senses a suds lock condition by analyzing the current draw on the drive motor. If "Sud" is displayed a potential suds lock is detected. This may signify a bad pump, an extra heavy load, excessive detergent, or excessive suds.
Potential Causes
• If too much detergent was used, run the unit through a Rinse/ Spin cycle then a Normal cycle without adding any detergent. This should clear the unit of the excess detergent.
• Check the drain hose and make sure it is not plugged or kinked.
Dec 16, 2010 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Loud knocking during finial spin cycle
replace the balance springs from the bottom of the tub to the frame there weak and letting the tub rock
Jan 18, 2010 | Washing Machines
Kenmore HE3 washer started knocking and shaking during spin.
indicates that the tub support rods have failed at the air dampners
the fix is new rods from the service agent spares and a re levelling if the tub ,not the machine
Nov 20, 2017 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Kenmore HE3
usually the only reason for this is out of level these machines spin very fast. if you have it on carpet it will also shake quite a bit it is best to cut a piece of plywood for the washer to sit on so it is easier to level up
Apr 27, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
2,538 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
