Question about iRobot Roomba 4210 Bagless Robotic Vacuum
Brush keeps running
Whern I install the battery the brushes start spinning in place -Wheels not moveing - without the power button on . the brushesw also spin when its being charged. It does however move and clean when I depress the start and max buttons. I've tried almost everything to attemp[t to get them to stop to no avail. Please advise.Tim
  • baygetter Nov 11, 2008
    same problem
  • cleangirl Apr 29, 2009
    Same problem ... anyone know how to fix this?
    Sniper:
  • 61 Answers
The problem is in the Roomba itself. It can't be fixed-- time to call support.
Posted on May 13, 2009
My Power head on my Dyson Animal DC39 will not stay spinning. Suction Issue?
There should be a red insert on the right-hand side on the cylindrical bulge behind the brush cylinder. Check that this is moving when you push the button. The red insert should stay pushed in for the brush to rotate. The insert moves in an out as well as rotates in order to lock in the 'in' position. Mine is a little sticky on the rotation and I need to shake the brush head a little in order to get it to rotate and lock.
Jan 05, 2013 | Dyson DC39 Animal Canister Vacuum
What are these 2 blinking lights on my irobot roomba?
"The Charge Indicator Light is located immediately to the right of the power button on Roomba Red and Roomba (sage). On Roomba Discovery and Discovery SE, the Charge Indicator Light is incorporated into the power button. Please refer to the table below to determine what the Charge Indicator Light is telling you.
* Pulsing Amber - Charging
* Green - Fully Charged
* Amber - Partially Discharged
* Red - Almost Fully Discharged
* Flashing Red - Fully Discharged"
At the end of a cleaning mission, Roomba will tell you if it has successfully completed it's mission or not:
GREEN = MISSION COMPLETE
YELLOW = MISSION ABANDONED (Check robot's brushes, etc.)
YELLOW RED POWER BUTTON = BATTERY DEPLETED (Scheduler Models)
RED YELLOW POWER BUTTON = BATTERY DEPLETED (Discovery Models)
number of beeps after ?uh-oh? :
No beeps: A wheel is stuck or is not touching the ground. Pick up the robot, place it down securely on the floor and touch the clean button to restart the cycle.
1 beep: The main brushes cannot turn. Turn over Roomba and remove the brush guard by pushing the two yellow tabs. Remove the brushes, clear any obstructions, and replace them again.
2 beeps: The side brush cannot turn. Turn over Roomba. Look to see if something is wrapped around the side brush. Remove the side brush with a screw driver and check for string or hair that may be wrapped around it.
3 beeps: The vacuum cannot run Remove and empty Roomba?s bin.
4 beeps: A wheel motor cannot run Your Roomba may be stuck or something may be wrapped around a wheel. Look for something wrapped around the wheels. Push them in and out and make sure they turn easily.
5 beeps: The cliff sensors have failed or are blocked. Turn over Roomba and clear any debris that might be caught underneath the front bumper in the cliff sensors. You can also use compressed air to clean them out.
6 beeps: Wheel obstruction or robot attempting to drive over an obstacle. Turn over Roomba and remove any obstructions that prevent the wheels from seating all the way up into Roomba?s body. Also, remove any obstacles that Roomba could drive over.
7 or 8 beeps: Not applicable Roomba?s beep codes do not include 7 or 8 beeps. If you are getting an error with 7 or 8 beeps, try counting again or contact iRobot Customer Care.
9 beeps: Sensor error Please contact iRobot Customer Care.
10 beeps: Roomba is stuck Pick up Roomba and start it again somewhere else. Use a virtual wall or other barrier to keep Roomba away from the
place it got stuck.
Your Roomba may be experiencing an issue where the battery is deeply discharged and may need to charge longer than the standard 3 hours. (or 7 hours if you have a standard charger)
Even with the charging light showing green (this indicates a fully charged battery) the robot is still charging. If your Roomba exhibits behavior where it charges for a short time then runs for a short time you will need to do the following.
1. Plug the charger into Roomba (if you have a home base be sure to plug directly into Roomba instead of using the home base, this will ensure the robot's charging cycle is not interrupted.)
2. After the Roomba's charging indicator goes to solid green please keep the Roomba on the charger for an additional 72 hours. (3 days)
3. After the 72 hours (3 days) has passed, turn your Roomba on and begin a normal cleaning cycle. If this works successfully it may take several uses for the battery to get back up to the performance it once had.
If this does not correct the problem, please call customer support at 877-855-8593
Nov 22, 2012 | Vacuums
Brushes not spinning
Side brush? Main brush? both? How did you find that they are not spinning? To properly test, place the front wheel on the table edge and hold the wheels up in the machine (dont hold the tires) , Then start the clean mode.
If it doesnt spin then you need to open the roomba and remove the motor to see if it is just binded up with lint. If the motor spins with your fingers then test the motor with a power supply to see if it is possibly burnt out. If it works on a power supply then your issue is on the main board and it needs replacing.
Jul 09, 2010 | iRobot Roomba 4210 Bagless Robotic Vacuum
I have cleaned & cleaned this thing! It runs for about 2 mins & stops, says "Clean Brushes"! and now it's very noticeable it's not picking up well... but is picking up a bit. I take the dust bin...
Ok, this is a "Brush Height Adjustment" issue. It will probably work great on a hard surface but on carpet the brushes bog. If you've taken the unit apart already...Sorry....do it again. When you do, you'll see a String which allows the brushes to "Float" on different surface heights. Loosen the screw a little and pull a bit more string through. Re Tighten the screw and put it together enough for a test run. Now reset the roomba.To reset the Roomba, power the Roomba on, and press the Spot, and Dock buttons together for at least 8 seconds. Until it plays a tune. The clock, and any schedule is erased at this time. Try running the Roomba with the dust bin removed to see the brushes spin easier.
Second method, is taking off the bottom cover, and removing the battery. While it's removed, and not plugged into the charger, press the clean button for at least 20 seconds. This will erase the memory. Replace battery, and cover. Run the Roomba to see if the brushes start to spin. You can also remove the brush housing by removing the 4 screws and reseating it, to see if it was a bad connection, since you have the bottom cover off.
Mar 26, 2010 | iRobot Roomba 560 Robotic Vacuum
Roomba keeps saying "Clean Brushes"!!
Have you made sure the brushes aren't clogged with thread and hair, and that the brush bearings are still good?
1) remove the brush guard.
2) remove the brushes
3) remove any hair or debris using the cleaning tool
4) replace the Roombas brush bearings
5) replace brushed and brush guards
If this doesn't work then, try the following:
  1. Power off the Roomba.
  2. Remove the dirt bin.
  3. Place the robot upside down on a flat, padded surface.
  4. Check for any dust or dirt obstructing the Cliff Sensors (with Roomba upside down, the sensors are located in the four rectangular areas just inside the edge of the front bumper).
  5. Next, press the front bumper in to make sure it springs back.
  6. Make sure both yellow brush caps are installed correctly
  7. Make sure the main brush and the flapper brush each have a yellow bearing installed correctly.
Mar 26, 2010 | Roomba Robotic Floor Bagless Vacuum
Brush roller on windtunnel won't spin
It sounds like you need to replace the actuator arm or the cable to it. Look for Hoover part 43143046 for a start. I've got a similar problem.
Mar 21, 2009 | Vacuums
Roomba keeps saying clean brushes yet are clean!
Make sure you take off the little cap at the end (the one that spins -- just grab it and pull it straight off) and clean under it too. The rest of the brush may look perfectly clean but what happens is that hair gets stuck under spinning cap and, like a slowly growing washer, it pushes the whole brush toward the gear box. When it gets pushed over enough, the large yellow ring starts to rub against the side of the brush deck making it harder for the motor to turn the brush and you get that "remove and clean brushes" message.
Jan 30, 2009 | iRobot Roomba 530 Robotic Vacuum
Motor shaft wont turn on EL2050
Have you tried running the brush motor without a belt on it? Does it not spin without the belt? If so, you may have worn motor brushes (not too expensive parts, but make sure you order both brushes, or make sure they are sold as a set). If your motor is in good condition (you can check the brush motor by hooking it up to a momentary power source NEVER apply constant power to a motor that is not mounted to either the machine or something to keep it from running away) There is sometimes a switch down towards the brush head assembly that could be bad.
Jan 19, 2009 | Electrolux Central Vacuum
Auto brush on hoover windtunnel doesn't spin anymore
I have a Windtunnel S3765 with the same problem - and it has very little use so I'm confident it isn't wear. I find that the wheels do not raise the agitator brush sufficiently high to reduce the drag caused by excessive contact with the carpet. If I raise the front a bit the brush spins as it should. It also works if I take the housing apart and use it without ..... but this is tricky.
Unfortunately I haven't figured out a way to hold it up efficiently. I am toying with afixing something to the bottom of the housing to raise the front enough to give the brush a little more room.
Dec 20, 2008 | Hoover U6630-900 WindTunnel Bagless...
4296 Robotic Vacuum _ Brush quit spinning
i had the same prob. i contacted i-robot and was told the motor that turns the brush is shot. there is no replacement part. they offered to replace my i-robot with a new one from the 400 series. at about 60% of a new one. that's the only option that i know of.
Apr 09, 2008 | iRobot 4296 Robotic Vacuum
iRobot Roomba 4210 Bagless Robotic Vacuum Logo
101 people viewed this question
Top iRobot Vacuums Experts
Shehu Pro
Shehu Pro
Are you an iRobot Vacuum Expert? Answer questions, earn points and help others
