Question about Bissell Lift-Off(R) Revolution(R) Turbo Upright Vacuum
The male and female connector lift off parts are burnt.
The vacuum still works fine but I have stopped using it since I discovered the burnt parts. What parts do I need to order to fix this? I can find the male part number. Do I need to replace the motor?
    President:
  • 1,673 Answers
Call Bissell and they will have you take it your nearest warranty repair shop, it will be replaced with a new one under a replacement warranty for these vacuums.
Posted on Feb 17, 2008
The power brush on my Kenmore canister vac #116 2761 works intermittently Depending on how I hold it. Seems to be a problem with the contacts on the wand????
all you can do is clean them contacts that you see on the wand
use wd40 .
an a brillo pad or such.
look at the female connector on the end an see if u can tighten an clean it .
Jan 04, 2015 | Kenmore Vacuums
How to replace the cord in dyson's dc07
Things You Will Need
  • Dyson DC07 power cord
  • T15 Torx-bit screwdriver
  • Small can
  • Camera or cell phone with camera
  • Flat-head screwdriver, 3/4-inch or smaller
  • Needle-nose pliers
Tips
  • Do detach the black wire that goes to the motor as it does not require removal.
Warnings
  • Do not work on the power cord when it is plugged in.
  • Do not force the plastic-covered connectors from the switch or you could break the male ends. Pull them off firmly but gently to avoid breaking the terminals.
  • Do not apply too much force to the plastic arms that hold the housing in place. The plastic arms are fragile and may break easily.
References
1 - Unwrap the power cord from the Dyson DC07. Detach the handle of the vacuum cleaner by pressing the release button. Pull the handle from the hose. Slide the hose down the wand and push the button at the bottom to release the hose from the machine.
2 - Press the button at the top of the dust bin handle to remove the canister bin assembly from the Dyson DC07.
3 - Lay the machine on with its back with the power switch facing upward. Locate the Torx screw directly beneath the switch actuator. Remove the Torx screw, turning it counterclockwise. Place the screw into a small can so you do not lose it.
4 - Remove the switch box housing held in place by the Torx screw just removed. Carefully pry upward on the two plastic arms that clip the housing in place. Take a picture with your cellphone or camera of the open housing to make it easier to reinstall the wires where they belong in the channels and spaces provided.
5 - Center the needle-nose pliers on the female connectors from the power cord attached to the switch. Apply equal force to pull them from the male ends of the switch. Also detach the two wires that connect together within the housing, identified by the clear plastic connector between them. Depending on your machine\'s manufacture date, the wires might have different colors. For example, they may be white and brown, all white or one could be blue. Disconnect a total of four wires -- two from the switch and the two connected together. Leave the other wires alone.
6 - Trace the electrical cord on the machine until you reach its protective cover where it enters the Dyson DC07. Lift up the cord protector to remove it from the vacuum. The cord protector has slotted sides that fit within the plastic. Slide the cord protector from the power cord.
7 - Remove the plastic covers that protect the female ends on the power-cord wires that connect to the switch. The new power cord does not come with these. Insert the tip of the flat-head screwdriver through the top of the plastic connector with two internal ridges. Lift upward and away to pull the wire free from the connector. Repeat for the other wire. Push the female end into the plastic connector until it snaps into place. Repeat for the other power-cord wire.
8 - Thread the new power cord through the cord protector. If you have trouble pushing the wires through, reach in with the needle-nose pliers to pull both wires through the rubber protector.
9 - Reconnect the two separated wires back together by inserting the male end into the female end of the other wire. Reconnect the two wires from the power cord to the switch. Reinstall the switch housing on the machine. Align the wires in the channels provided to keep them from being pinched or pulled out when you reassemble the housing. Look at the photo you took earlier as a guide, if necessary. Insert the wire that goes to the motor in this channel and the white wires connected together to the left of the switch in the area provided.
10 - Put on the switch housing cover and secure it with the screw you removed earlier. Reassemble the vacuum in the reverse order you dismantled it.
Aug 27, 2014 | Dyson DC-O7 Bagless Upright Cyclonic...
Cant charge it the red light blinks fast when i push power button
I had the same problem but discovered on opening up the unit that the motor was a bit stiff to turn. I therefore prised off the fan and removed the waterproof shroud only to discover some corrosion on the front bearing. A drop of WD40 did the job and now its working again good as new.
Apr 24, 2014 | Karcher WV50 Window Vacuum
It stopped working while I was using it . I tried to plugged in different electric outlets but it still dead. What should I do or look into in order to get it back to normal?? thanks
I would start by taking the wand apart. Be sure vac is unplugged from the wall outlet! You should be left with two pipe pieces, and the beater bar. I would also pull the hose from the canister unit itself. Once all the pieces are pulled apart, check the two or three prong wire connectors on each piece, both the female and male ends. If you have any dielectric grease, use a dab on each electrical connection. Once you reassemble, and still not powering up, wiggle the wand back and forth at the connection near the canister, and after the hose near where the switch is. If the vac cuts on after wiggling it, then you have a loose connection, and will need to tighten the female ends on the electrical connections, by squeezing them together slightly with a pair of pliers. Please rate if this works or does not work. Thanks!
Jan 03, 2011 | Kenmore 23612 Progressive PowerMate Bagged...
Power Head keeps cutting in and out while vacuuming???Canister motor keeps running but the power head starts and stops like there is a short or some loss of connection somewhere. Any ideas?
The electrical terminal at the top of the extension wand may be loose or corroded. Unplug the vacuum and remove the wand from the hose assembly. Look at the 2 prongs and clean off any corrosion using a a Q-tip or scrape with a screwdiver if it's more persistent. After cleaning reconnect the wand to the hose and try it again. If the prongs are not corroded, they might be loose instead or they might not be aligned properly. If this is the case then bending the prongs very slightly may help realign them. The part that may be giving you the trouble is called the terminal cover (PN 8191782). It costs about $10 but the problem is knowing the procedure to actually replace the part. CAN ANYONE EXPLAIN HOW TO OPEN UP THE EXTENSION WAND TO REPLACE THE TERMINAL COVER ??
Jan 14, 2010 | Kenmore 23913 Progressive PowerMate Bagged...
Power head does not activate
have you pushed the rest switch on the top housing? It may be on the side?
Aug 28, 2009 | Kenmore 25512/ 25513 Progressive Canister...
Bissell 6595-1 with broken electrical connector
YES! If you haven't contacted Bissell yet (or bought a new vacuum) do so. They sent me a nice refurbished machine for free.
Dec 12, 2008 | Bissell 6595 Lift Off Bagless Upright...
Beater bar won't turn on
Depending on which model you have, need new belt and/or brushroll. If a brush roll motor, maybe it is bad. If this is a lift-off, check the male and female connection and see if they look ok or are burnt up.
Jun 22, 2008 | Bissell Vacuums
Male plug needs to be replaced.
I had same problem with my lift-off, i sent email to Bissell explaining what the problem was and where to get replacement parts. They sent me emial back saying they will send me refeb replacement vacuum becasue this part has been discontinued (I think there is a prolem with lift-off and Bissell is trying to make it right for their customer without official recall). I did get my fedex lable and i sent entier length of cord from my lift-off back to them. I should be getting my refeb vacuum soon.
---Pete
Apr 05, 2008 | Bissell Lift-Off(R) Revolution(R) Turbo...
Powermate connection flickers
I had the same problem. Sears has replacement parts for mine (Model 11625813506) here: http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=11625813506&pop=flush
Rather than pay $10 for a new cover terminal (which I probably couldn't install myself anyway), $99 for a whole new wand, and possibly $108 for a whole new hose (ridiculous prices, btw), I took a small flat head screwdriver and scraped off the dirt/corrosion on the terminal pins. This didn't resolve my problem, but I noticed the connection between the extension wand and the "Power mate" hose handle was loose. The handle could wiggle/slide about 1/8" when connected to the wand, creating the loose connection. I used the screwdriver to bend the pins down slightly (in the direction away from the wand tube), to compensate for the loose connection. This worked like a charm, fixed the intermittent circuit contact completely, and was very easy to do. I'd highly recommend trying this, before doing anything more complicated.
Feb 09, 2008 | Kenmore 23612 Progressive PowerMate Bagged...
Bissell Lift-Off(R) Revolution(R) Turbo Upright Vacuum Logo
110 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
