Toshiba switching off!
my computer has started turning itself off with no warning at all while i'm working on my computer!if i have it plugged in, with the battery in or just plugged in without the battery!its annoying because i cant rely on my computer now as i have essays to write. it gives NO warning....what can i do?i have been told its a hardware problem?how easy is this to fix?
    Genius:
  • 3,587 Answers
You may want to check the power save or screen saver settings first, to ensure that's not the issue. is it the whole computer or just the monitor?
Posted on Feb 17, 2008
Factory reset toshiba satellite M105 S1021
Hold down the F8 key while you turn on the computer to start recovery. WARNING !!! This will delete your data and put the computer back to the way it was coming out of the factory.
Toshiba M105 S1021 Satellite Celeron 1 46 GHz User Manual Restarting The...
Feb 13, 2017 | Toshiba Computers & Internet
I have bought a new toshiba A665 a week ago. I have a problem saying. ' A problem in the cooling system has been identified. Switch off ur computer and return it for service.' Cooling fan is working but...
At a week old, get a replacement or fix it right away. Fix should be free, but no computer during service.....
Toshibas run too hot, in my opinion.... so you have to keep after the fans and keep lint cleaned out of it....
Overheating will yield un stable system,
Feb 26, 2011 | Toshiba (K000831860) Cooling Fan
TOSHIBA SATELLITE M105 S3064 LAPTOP TURNS ITSELF ON AGAIN AFTER SHUT DOWN AND WHEN LID IS CLOSED DOES NOT GO INTO STANDBY, SHUTSDOWN THEN TURNS ITSELF ON AGAIN I am using the Computer that does it, its...
it may caused by virus, scan with premium antivirus
the secong chance, this caused by your powes option setting, chec it at control panel then set it costumized by your self, if this dindnt work, reinstall your pc
Jan 17, 2011 | Toshiba Computers & Internet
How can i restore a toshiba satellite a 135 to factory settings without a recovery disk
To reinstall your laptop to the factory settings / "out of the box" settings, please follow these steps. It worked for me, and should work for you.
ALL DATA WILL BE ERASED ON YOUR HARD DRIVE IF YOU PROCEED. YOU WILL NEED TO ENSURE THAT YOU HAVE THE POWER ADAPTER PLUGGED IN. DO NOT SWITCH OFF OR RESTART YOUR COMPUTER DURING THIS PROCESS.
* 1) Hold down the power button for 10 (ten) seconds to switch off your machine.
Please note: Holding down the power button on the machine forces it to switch off. Any unsaved data will be lost.
* 2) Press and hold the 0 (zero) key and at the same time, tap the power button once to switch on your notebook.
* 3) When the machine Starts beeping; release the 0 key.
* 4) When prompted by the warning screen; select Yes to continue with the system recovery.
* 5) Select Recovery of Factory Default Software; click Next.
* 6) Select Recover to out-of-box state. Click Next again.
* 7) Click Next to Start recovery.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Nov 26, 2010 | Toshiba Computers & Internet
Wifi switch is turned on however, when i try to search for a wireless network i get a message saying that i need to turn on my wireless switch
So I understand that your wifi card doesn't work?If that is correct go to Toshiba site and check their support-from the other computer-of course.If card is dead, you will need usb wifi.
Nov 15, 2010 | Toshiba Satellite Pro L300 Notebook
Hi i can't switch on my girlfriends Toshiba
Hi, first things i would try is to switch it off all togther, remove the battery and power lead and leave it sit for 10 - 20 minutes to let any residual power drain from it.
once you have done this just plug the power supply back in without the battery and try to switch it on, if it works ok, plug the battery in and see what happens if it fails to start up after this its most likely the battery is at fault.
if it will not start up just on the power adaptor then there is likely to be a hardware fault with the laptop itself that may need someone with some computer repair experience to fix for you.
hope this help.s
Jul 18, 2010 | Toshiba Satellite L300D-ST3501 Notebook
The power was turned off. Now get a warning: system resume failure. What to do to restart?
When you get the resume failure message, push and hold the power button until the unit turns itself off (usually around 5 seconds). Once it is turned off, press the power button again to turn it on and it should boot right into windows for you.
Jun 03, 2009 | Toshiba Tecra 8000 Notebook
System warning pop-up
Are you sure that nothing is overheating? If your cpu fan is turning too slow it won't disipate the heat. Do you have a program showing cpu temp:? I would take the access off the bottom and make sure the cpu fan is clean. If that is not the problem I believe you can turn the warnings off in the bios settings
Jun 08, 2008 | Toshiba (K000016310) Cooling Fan
Computers & Internet Logo
Alun Cox
David Payne
David Payne
