OKI C5400 Laser Printer
Problem for OKI C5400 Laser Printer
OKI c5400
By 1sharkboy on Feb 17, 2008
POOR PRINT quality , blurry images:
I have cleaned the LED bars and wiped all down with alcohol swabs. I have double images or blurry images (text is clean and clear) I also have 'dirty' white backgrounds where it should be white.
Same Problem
Apr 24, 2008
-   I have the same problem with my C5100n, which I've had now for about 5 years. When this shows up, I end up inevitably changing the fuser unit. Sometimes wiping down the LED's help. One time, when it was only black dots and shadows, I ended up replacing the drum for the black toner and the problem went away. I think I damaged the drum when I tried to not-so-gently remove a paper jam. I just ordered a new fuser which I think will take care of my latest problem, albeit an expensive fix.-   technomom
Solution #1
posted on Sep 11, 2009
Not Rated)
57 varieties
Rank: Guru  Computer Hardware  Expert
Rating: 88%, 535 votes
Assuming that you are using the same paper and have not changed any of the consumables you should do the following:
1. Clean LED head with lens cleaner or soft tissue.
  1. Remove the toner cartridge and give it a few shakes then reinstall it.
  2. The Toner Could be low so Change toner cartridge.
4. Make sure that the paper is not damp as this will cause fading and poor quality printing and images.
  1. The image drum may have been light contaminated so remove it from the printer and store it in a totally dark place for several hours then reinstall it.
  2. If the image drum is dirty then wipe it very gently with soft tissues, being careful not to scratch it.
  3. Open the top cover and check to be sure that each toner cartridge is fully seated and that each toner cartridge lock lever is pushed all the way back.
  4. Press the top cover release latch and open, then close, the cover.
  5. Check MEDIA MENUTRAY1 MEDIA TYPE and set as required. Do the same for TRAY2 and MPT.
  6. Check MEDIA MENUTRAY1 MEDIA WEIGHT and set as required. Do the same for TRAY2 and MPT.
  7. Possibly set the value of media weight in the menu to the next heaviest one.
  8. Check PRINT MENURESOLUTION setting and set to 600 x 1200DPI
  9. Check PRINT MENUTONER SAVE MODE and make sure this is OFF
  10. Check PRINT MENU – MONO PRINT SPEED and make sure this is set to MIXED SPEED
  11. Check the COLOUR MENU – DENSITY CONTROL and set this to AUTO
  12. Check the COLOUR MENU – AUTO DENSITY and set this to EXECUTE
  13. Check the COLOUR MENUCMY 100% DENSITY is set to ENABLE if you want a glossier black finish.
Was this helpful?
Yes
No
Popular Solutions for OKI C5400 Laser Printer
Questions and Unsolved Problems for OKI C5400 Laser Printer
Do you recommend OKI C5400 Laser Printer?
Answer
Answer
need to know how to reset the oki c5400n to factory defaults
Answer
i have a canon ip 1000 pixma printer. Off late the balck cartridge stopped printing and only the... (More)
Answer
how do I clear a name header that prints on each page
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For OKI C5400 Laser Printer:
Top Printer Experts
Rank: Guru Guru
Solutions: 773
Experience: 30 Years of professional repair and design.
Ask Me
Find more Printer Experts
Top Printer Repair
(800) 836-9287
Celebrating 14 Years Of Outstanding Printer Repair...
Laser Repair 911
(972) 907-9771
Printronix, IBM, Tally, Genicom, TallyGenicom,...
Sinca Printers, Parts & Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
