Question about Maytag MAV7200 Top Load Washer
In running our washing machine today, the pump started making a loud clacking noise almost like it had some foreign object lodged in it. I elected to let the unit continue to run since it was full of water in hopes it would last long enough to complete the cycle and I wouldn't have gallons of water to drain. I could then replace the pump. No such luck. As it reached the final spin cycle, it now does not work but of course if full of water. Does this unit have any sort of reset capability (either a switch or through time) and if not, any suggestions on draining the unit. Also, is there anything else I should consider may be wrong if it cannot be reset. My hope would be to have it complete the cycle and then replace the pump...an probably a new belt. Thanks
  • 5,911 Answers
There's no reset switch that I know of. This particular model has a belt driven pump with no electrical connection. Changing the timer is not going to do anything. It cost about $50 to $60 if you find it to be bad and need to replace it. You can find parts for your washer at repairclinic.com. Just type in your model number and you will be provided a pictorial parts listing. This is a bit premature, you may just have a broken drive belt. But...you have that full tub of water. If you just need to drain the tub in order to make repairs, here's a couple of suggestions that I have used:
1. If you own a small submersible pump, you can drain the tub quickly by placing the pump in the bottom of the tub and run a garden hose outside or into a deep sink (if available). Ensure you have removed all wet clothing to make sure you don't clog the pump.
2. Another method is to remove the drain line from the standpipe and use a wet/dry shop vac to pull a vacuum. This will work if the pump isn't lodged with anything. This method is going to be slower if you don't have a vacuum of large capacity. These wash tubs generally hold about 35 gallons of water. So...if you have a 10 gallon capacity shop vac, you may have to empty it 3 or 4 times before you get all the water out. If the pump is clogged, you can still drain directly from the tub.
If you don't own either, I would recommend that you obtain one or the other somehow. Unless, you wish to try to bail all that water by hand. You will need to empty the washer of all this weight in order to check the drive belt as most Maytags have their drive belts system UNDER the washer. I wouldn't try tipping the washer back with a full tub of water. I hope this helps you. Post back with comments if you need further assistance.
Posted on Feb 18, 2008
I have a maytag fav6800aww and it doesnt want to drain the water and it makes a loud noise coming from the pump. i already replaced the pump and it still has the same symptoms. what should i do to fix this...
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Nov 25, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Makes screaming noise while washing. MAV7200. Belt or Bearing? Fixable by DIY?
MY MAYTAG WASHER IS MAKING A NOSIE WHILE WASHING A GRINDING NOISE DON'T KNOW IF IT THE BELT OR BEARING? WHAT DO I NEED TO DO?
Jul 20, 2010 | Maytag MAV7200 Top Load Washer
Not cycling, draining or spining
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Jun 07, 2010 | Maytag MAV7200 Top Load Washer
My maytag washer makes a clacking sound when it spins or aggitates
Use a wedge of wood or a non marring tool to lift the front of the top cover and tilt it back on the hinges. Be careful of the load lid when lifting it back so it will not fall freely back making a loud noise. On each edge of the washer there are support rods in rubber shock absorbers. My guess is the rubber is deteriorated and you need to order new ones.
Jan 21, 2010 | Maytag Washing Machines
While in spin cycle it makes clickety clack noise
Most likely something stuck in the drain pump. Remove the drain pump and inspect the inside of the pump for a foreign object.
Nov 02, 2009 | Kenmore 22422 Top Load Washer
Make loud noise during spin cycle
Washer may be out of balance, Move closes around in washer and restart
Oct 24, 2009 | Maytag Atlantis MAV6000 Top Load Washer
My Maytag HAV2557AWW Loud Noise
pull hoses off the pump and see if there is anything stuck in it
Jun 12, 2009 | Maytag HAV2557 Top Load Washer
Making noise from pump
The pump is the problem you described.
the tub will move to one side at times due to belt tension. if it is not dancing around it shouldn't be a problem.
May 25, 2009 | Maytag HAV2360A Top Load Washer
Loud noise -- water pump??
Yes you definately need a new pump assembly part number 21001906 $59.95. That is a maytag part number and it is a very common repair. The new pump is a revised design and will look different but will mount the same. Axcess through front panel.
Nov 25, 2007 | Maytag MAV7200 Top Load Washer
Maytag MAV7200 Top Load Washer Logo
179 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
