Question about Philips HTS3400/37B System
System will not power on!
When I press the power button the red light goes out but then comes back on and the unit does not power on. Any ideas?
My systems does not turn on. It seems to be locked in stand by mode. If I unplug and replug the red power light goes on,\, but when pressd it starts to blink as if in stand-by. Help
  • 4,889 Answers
The fuse has blown out and some CAPACITORS ON THE POWER BOARD. You will need to replace the fuse first and then look for blown out capacitors on the powerboard using a multimeter... Just in case you locate the faulty capacitors just note down the values on them and google for them. Shouldn't be hard, anyways if can't find them i will be right here to help!
Regards!
Eagle.
Posted on Feb 17, 2008
  • 2,336 Answers
If you already tried the hard boot/reset by unplugging it and plugging back in, I would suggest to remove all the speakers connected and try to power it back on.
If that does not work, the system does have a internal failure and it goes into standby mode to protect itself and it will not power up until the failure has been fixed.
I would suggest to take it to a technician to troubleshoot it or if you are electronically incline and want a challenge, you can try to fix it yourself.
Let me know if you need any more assistance.
  • Philips Master
  • 19,396 Answers
Hi, did you try switching on both from remote and button?
Try first disconnecting from the power and connecting back, as already suggested.
Then first check this link out, it is the official solution for your problem, but it may not work:
http://www.p4c.philips.com/cgi-bin/dcbint/faqview?slg=ENG&scy=&ctn=HTS3400/37B&refnr=0015959&dct=QAC&session=20080217131905_84.9.43.114&searchtext=reset%20unit
Here is the prcedure to reset the unit to factory settings, try it, if it works then your system should turn on in the middle of the procedure :
Press OPEN/CLOSE on the front panel, while pressing down OPEN/CLOSE, press numerical keypad “1” on the remote control. The blue DVD background appears on the TV screen.
If all these solution do not work, then the electronics or button may be faulty, in this case I will need more details to solve your problem.
In addition here is the user manual:
http://www.p4c.philips.com/files/h/hts3400_37b/hts3400_37b_dfu_eng.pdf#search='red%20light'
hope it helps
    Genius:
  • 3,422 Answers
Have you performed a "hard start". This is done by totally unplugging the unit from the wall and waiting for 15 seconds. See if that helps...
Goodluck..
Recently, when I take the ipod off the Zeppelin, I hear this strange sound, not a hum, but higher in pitch, from the speakers, and when the blue light starts flashing like it's in standby the sound warbles...
there are issues relating to the older models, until the power supply board ahs been replaced and the unit tested, it is hard to say, b and w are fixing units because of the known problems, so check with their service desk.
Nov 26, 2010 | B&W Bowers and Wilkins Zeppelin iPod Music...
So I connected 8 speakers to this system and I might have blown it out. when i connect it the red standby light comes on. then when i press the power button the screen goes blank as if turning on but...
Audio output shorted out or blown fuses in power supply check all fuses if fuses are good your Audio out put transitors or I.C has been shorted out as a result of impedence over load in future dont connect speakers in parallel in those small Audio units.
Natureisland technician
Commonwealth of Dominica
Nov 06, 2010 | Sony CMT-HP7 CD Shelf System
My ps3 wont power up
try powering the system up by HOLDING the on;off button , it will reset all your audio and video settings . then plug the system using the AV cables (default) .
else, you should take it to an assastance centre for hardware issues checking . can be a problem with your RAM or GPU units that makes the system unable to startup it's firmware .
Jul 27, 2009 | Sony Playstation 3 (PS3) Console
LG DLP RU-44SZ51D Lamp Indicator blinks red
44 inch lg dlp hdtv no picture or sound press power button standby light turns yellow and then back to red
Mar 04, 2009 | LG RU-44SZ51D 44" Rear Projection...
I have a denon 1720 dvd player. When you press the power button it comes on for 3 seconds then the power button turns back red and powers off. If you press the eject button within the 3 seconds the tray...
same equql problem....?????
Can you help?
i have a denon 1720 dvd player. When you press the power button it comes on for 3 seconds then the power button turns back red and powers off. If you press the eject button within the 3 seconds the tray opens and the power button stays green. As soon as you close the tray the power agin goes to red. i have a denon 1720 dvd player. When you press the power button it comes on for 3 seconds then the power button turns back red and powers off. If you press the eject button within the 3 seconds the tray opens and the power button stays green. As soon as you close the tray the power agin goes to red. Can you help? thanks thanks
Dec 21, 2008 | Televison & Video
No power R49w36
Its probably just a fuse. I would replace all the fuses and see what happens. Let me know how it goes
Oct 02, 2008 | Zenith R49W36 49" Rear Projection HDTV
My system seems to be locked in stand-by. When I unplug and replug the red power light comes on, but bwhren pressed just starts blinking like in stand-by. Help
Jan 12, 2008 | Philips HTS3400/37B System
Philips HTS3400/37B System Logo
846 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
