Question about LaserJet 3052 All-In-One Printer
Hp a;; in one laser printer 3052 problem
Dear Sir
The problem I face with hp 3052 it works ok with PC interface but when we try to scan any document for xerox copying there is a vertical line coming on copy . I trid to clean the accessable part but no solution.Please help me out
52 scanner error
Posted on Sep 20, 2008
Please insert your originals into the automatic document feeder hp 3052
It is looking for a document to scan. Either a copy job was started and interrupted or the device is not sensing a document in the adf. If scanning, ensure document is flushed and is fully inserted. If not scanning, cancel all jobs. If scanning and document is flush and fully inserted, check sensor/flag which may need replacement if all else is good.
Feb 21, 2015 | HP LaserJet 3052 All-In-One Printer
HP Laserjet 3052- Printing problem
Your printer's drum must be cleaned or replaced if damaged.
Aug 09, 2008 | LaserJet 3052 All-In-One Printer
How can I scan to email. I can scan and reprint plus I can scan to memory card
To use this feature in Windows, a destination must be programmed in the scan setup before scanning to a destination. See Set up the product Scan To button.
Load the originals that are to be scanned face-up in the automatic document feeder (ADF) input tray, with the top of the document forward, and adjust the media guides.
Lift the flatbed scanner lid and load the original that is to be scanned face-down on the flatbed scanner with the top, left corner of the document located in the lower-right corner of the glass. Gently close the lid.
On the product control panel, press Scan To.
Use the arrow buttons to select a file destination.
Press Start Scan or OK to scan the document to a file.
Scanning to e-mail is supported by any e-mail program that supports the Messaging Application Programming Interface (MAPI) protocol. Many versions of popular e-mail programs seem to be MAPI-compliant. See the support information for your e-mail program to determine whether or not it is MAPI-compliant.
-or-
Nov 25, 2010 | HP PhotoSmart C5150 All-In-One InkJet...
My hp laser jet 3052 cannot scan documents in pdf.It is only giving options to save either in jpeg, tif, bmg format. There is no pdf format.
You may need to purchase a scanner to get a PDF like Acrobat Reader. But if you managed to save to PDF before, try to reinstall the software and add software and choose OCR. Most of the HP PDF capablility is together with its OCR software.
Aug 22, 2010 | LaserJet 3052 All-In-One Printer
My HP 3052 won't print color. Prints in black and white fine but no color! Thanks
The LaserJet 3052 is a Black and White only model. It does not PRINT in color. It will SCAN in color.
Jun 21, 2010 | LaserJet 3052 All-In-One Printer
When trying to copy papers do not feed but if you scan they will
HP LaserJet 3050z, 3050 All-in-one, 3052, 3055, 3390 and 3392 versatile printer - Error reported: Document Feeder Jam ISSUE: How to correct the HP LaserJet 3050z, 3050 All-In-One, 3052, 3055, 3390 and 3392 versatile printer if this error is reported: Document Feeder Jam SOLUTION:
  • Clear the jammed media from ADF (HP LaserJet 3050, 3050z).
  2. Remove any jammed media with care.Take out the page gently. NOTE: Take care not to tear the paper. c01075162.gif
  3. Close the ADF cover plate.
  • Clear the jammed media from ADF (HP LaserJet 3390, 3392, 3052 and 3055).
  1. Open the ADF cover plate. NOTE: Check whether all packaging straps inside the ADF are removed. c01075163.gif
  2. Unload the jam clearance component.Lift the two handles with both hands until the component clutch is released.Rotate and lift the jam clearance component, and then put it aside. c01075164.gif
  3. Lift the green handle, and rotate the paper picker until it is opened. c01075165.gif
  4. Gently remove the page without tearing it.If you feel resistance, go to the next step. c01075166.gif
  5. Open the ADF cover plate, and loosen the media gently with both hands. c01075167.gif
  6. When the media are stopped, pull the media out gently along the shown direction. c01075168.gif
  7. Close the cover plate of the flat scanner (HP LaserJet 3390, 3392, 3052, 3055). c01075169.gif
  9. Insert the jam clearance component to reinstall it.Press the two reeds until the component is properly engaged.Install the clearance component correctly. Otherwise, paper jams will continue to occur. c01075171.gif
Have a good day
Jun 22, 2009 | HP LaserJet 3055 All-In-One Printer
I also face same problem for Hp J4580 printer
open hp solution centre and click on settings
point to scan settings and click on scan to setup
then move all the items on the left to the right and then click on ok or update the device and now try to scan this should definitly work
Jun 21, 2009 | HP OfficeJet J4580 All-In-One Laser...
Hp psc 1513 all in one series scan problem
reformat your system so that you can install properly your HP printer, this time the system are being invaded with spywares & viruses...
Jun 18, 2009 | LaserJet 3052 All-In-One Printer
LaserJet 3052 All-In-One Printer Logo
290 people viewed this question
Top Laser Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Alun Cox
Are you a Laser Office Equipment and Supply Expert? Answer questions, earn points and help others
