Question about HP Photosmart 2575 All-In-One InkJet Printer
Black lines when scan and copy documents
When I scan and copy, I get a few thick black lines on the new document. Tried the cleaning steps suggested at the HP website with no results.
  • ne1410s Feb 18, 2008
    I did save it as a b/w photo after scanning but sttill ends up with thick black streaks.
What is happening is that there could possibly be streaks on the scanner glass pane. Also check the printer heads and rollers. If the heads are dirty then it will give streaks in the print. If the rollers are dirty or are flatten right out or are chipped and mar then that will also cause streaks in the printing.
If you are also using re-filled ink cartridges or you are using the refill kits on old cartridges that could also cause the quality of your prints to go down.
Posted on Jun 30, 2008
The scanner unit in the printer is broken. simple as that. you will probably find that if you try to scan to your computer the results are the same
Posted on Mar 12, 2008
    Problem Solver:
  • 9 Answers
It is because coping is not the best way to get a perfect copy on the printer, Try scanning with computer using black and white photo it will come out much better if you are doing a pic. then use color picture.
Posted on Feb 17, 2008
  • Tom Beaver Feb 25, 2008
    Try doing the scan and save i last talked about but use color picture and that might work or it might be on the original document or on the scanner glass.
Canon IR 2870 copy with a thick black line in the middle of the page.
There are three possible sources of black lines on copies: the original, the scanning process and the printing process. As a general rule, if the line only appears on some documents, the source is the original. If the copier is also a printer but the lines only appear when copying, the source is the scanning. if the lines always appear, the source is a defect in printing. Since black lines can be intermittent, it is best to check all possible sources.
Faint lines on the original might be more obvious on copies. Adjust contrast and brightness settings to reduce the appearance of lines. Lines at the edges of copies can be due to an original being smaller than the copy. Set the copier to enlarge the original, so the edges of the original are outside the edges of the copy, to eliminate these lines. If the original has folds, creases or pasted-on sections, ensure the original is as flat as possible.
Clean the copier glass, using a glass cleaning product. All rollers and belts should also be cleaned, and trays vacuumed, to ensure dust is not carried onto the glass. Copiers with a document feeder move the original past a small area of the document glass. As the original moves, a single speck of dust in this area will cause a line on the copy, from top to bottom. When copying, always ensure the original is completely dry, including any correction fluid and pen markings. https://www.instantprintersupport.com/
May 30, 2018 | Canon Office Equipment & Supplies
I have a Epson cx11 and get a black vertical line down the middle of scans and copies
Check your flat bed and Document feeder scanning glass need to be clean, if any dot or dust in scanning glass of document feeder it will appear a line, check this points first
1- Check printouts from computer or FAX if it is clean problem in scanning section
2- Check using Copying a blank paper using only Flatbed if it prints without any line its problem from document feeder Scanning glass
So solution is clean the Document feeder scanning glass using wet cloth, note careful about wet cloth switch off the machine and clean it
Feb 04, 2013 | Epson AcuLaser CX11NF Printer
Thick black line on scanned document
Try to wipe the scanner glass clean with a soft lint free cloth.
If the "thick black line" also appears when making a copy, then there's something wrong with the scanner hardware. If this is the case, I highly recommend you to contact Lexmark Technical Support for additional assistance.
Oct 08, 2011 | Lexmark X4530 InkJet Printer
I am scanning a photo. I have translucent lines running horizontal through the picture before i print it.
Documents scanned/copied from the document feeder pass over a thin glass area where scanning occurs. Clean this area if sent faxes, copies or scans have black or white vertical lines.
  1. Lift the document cover to expose the platen glass.
  2. Wipe the ADF scan area (C) with a clean, soft, lint-free cloth moistened with water.
  3. Then wipe with a clean, soft, dry, lint-free cloth making sure there are no residues left, especially on the platen glass.
  4. Close the document cover and make a copy of a text document to confirm the black line has disappeared.
Dec 20, 2010 | Canon PIXMA MP780 All-In-One InkJet...
A thick black vertical line appears whenever i
you have a problem in your scanner assembly, clean or replace it
Apr 03, 2010 | HP Officejet 4355 All-In-One InkJet...
Black line through the middle of the document
The thick line is either because of dust sticking to the glass or a module problem. Try different brightness settings and scan white paper. If the thickness varies and also the sides of the black strip are jaggered (step like) then it is dust on Glass. use isopropyl alcohol to clean, dont use solvents. If the teickness is same for all levels of brightness and has a sharp edge always, it could be scan module problem.
S. Mohan
Oct 05, 2009 | Canon DR 3080C Path-Through Scanner
Black bar printed in the center of copied document
try copying the document to your computer and then from computer take a print out.
Aug 23, 2009 | HP Photosmart 2575 All-In-One InkJet...
Vertical line appears in scans using the ADF, but not with copies
happened to me after i fed a page with not-too-hard whiteout on it. the feeder makes the page run through a different piece of glass and i just had to clean it.
Aug 18, 2009 | Brother MFC 7840W Printer
Hp Photosmart c5280 1/ 2inch thick black line
There is something on your scanner glass. Clean the glass with glass cleaner. If this happens when using the automatic document feeder, open the top side cover where the paper feeds into. There is a narrow glass strip there. Clean that as well.
If this fails, the scanner head has a bad sector on the CCD and will need to be replaced. You will probably find that it will be cheaper to replace the printer entirely if that is the case.
Jun 22, 2009 | HP LaserJet 3055 All-In-One Printer
BLACK LINE 1" THICK ON FAX COPY BEING SENT OUT
I bet your incoming pages are clean right? The Laser is not used for outgoing faxes.
Lift up your document feeder and clean the scanner glass that the documents are scanned across
Feb 24, 2009 | Brother IntelliFAX 4750 Plain Paper Laser...
HP Photosmart 2575 All-In-One InkJet Printer Logo
784 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
