Question about Microsoft Windows XP Professional
Missing MSIEXEC.EXE I've restored my computer to a previous date and now when i'm trying to install any program its saying that "MSIEXEC.EXE file has encountered an problem and needs to close " also receiving an error message reporting that MSIEXEC.EXE is missing Help me as soon as possible
  • 64 Answers
Try this:
To unregister and re-register Windows Installer:
Click Start, and then click Run.
Type in the Open box: msiexec /unregister and then click OK.
Type in the Open box: msiexec /regserver click OK.
Posted on Feb 17, 2008
I'm trying to re-install 'firefox' but I get an error-Your Firefox profile cannot be loaded. It may be missing or inaccessible.-how do I fix this?
Try rolling your computer back to an earlier date. Assuming you have created a restore point, open your Control Panel, select System Recovery, and Restore to Previous Settings. You will not lose any files but may lose recently installed programs including Viruses.
Mar 06, 2015 | Computers & Internet
I'm trying to re-install firefox,but get error"Your Firefox profile cannot be loaded. It may be missing or inaccessible."
Cant download skype, problem with toolbar, error 2738
Take a look in Event Viewer I looked in Event Viewer to find out what MSI-file that generated the error message and found:
Log Name: Application
Source: MsiInstaller
Date: 23.09.2010 21:58:26
Event ID: 1040
Description:
Beginning a Windows Installer transaction: C:\ProgramData\Skype\{D103C4BA-F905-437A-8049-DB24763BBE36}\SkypeToolbars.msi. Client Process Id: 6564.
2. Running MSIEXEC with logging options I started a "Command Promt" and used the command: "cd C:\ProgramData\Skype\{D103C4BA-F905-437A-8049-DB24763BBE36}" to navigate into the folder containing the MSI-file.
Now using the command: "msiexec /i SkypeToolbars.msi /lv log.txt" (msiexec options: /i = Install, /lv = Log + Verbose output).
After clicking away the error message I just wrote "log.txt" in my "Command Promt" to open the log-file. Near the bottom of the log-file I found this line:
DEBUG: Error 2738: Could not access VBScript runtime for custom action
3. DEBUG: Error 2738 After a quick search at Google I found out this error indicates that the VBScript engine is not registered on the computer.
The solution for a Windows Vista or Windows 7 32bit:
- Click Start -> All Programs -> Accessories
- Right click "Command Promt" and click on "Run as administrator"
- Write "cd %windir%\system32" and hit Enter
- Write "regsvr32.exe vbscript.dll" and hit Enter
- You should now get a message that says: "DllRegisterServer in vbscript.dll succeeded."
- Click "OK"
The solution for a Windows Vista or Windows 7 64bit:
- Write "cd %windir%\syswow64" and hit Enter
- Click "OK"
4. Try again... Now I tried once more to run "msiexec /i SkypeToolbars.msi /lv log.txt" (I kept the /lv log.txt option to look for changes if the installer would fail again).
If you still get the same Error than continue to step 5.
5. Cleanup registry first, then re-reg My installation still gave me the same error, so after some more searching and reading on Google I found a solution that explained what I tried before (with the regsvr32.exe) and also an alternative step if that one should fail. The alternative step was to remove the Registry Key pointing to vbscript.dll.
The alternative solution for a Windows Vista or Windows 7 32bit is then:
- Write "reg delete "HKCU\SOFTWARE\Classes\CLSID\{B54F3741-5B07-11CF-A4B0-00AA004A55E8}" /f" and hit Enter
- Click "OK"
The alternative solution for a Windows Vista or Windows 7 64bit:
- Write "reg delete "HKCU\SOFTWARE\Classes\Wow6432Node\CLSID\{B54F3741-5B07-11CF-A4B0-00AA004A55E8}" /f" and hit Enter
- Write "cd %windir%\ syswow64" and hit Enter
- Click "OK"
Now using the command "msiexec /i SkypeToolbars.msi /lv log.txt" the installer started perfectly, ran all the way thru and Finished.
Conclusion This message indicates that VBScript engine is not currently registered on the Computer running the installer.
Vbscript.dll must get registered to solve the problem.
Ref: http://community.spiceworks.com/how_to/show/1577
Apr 25, 2011 | Computers & Internet
Start up and desktop icons missing
This could happen due to various reasons like :
1. Any recent update done.
2) Virus infected
3) Windows missing/corrupted files.
There are several steps to resolve the issue.
Try one after another and check if that fixes the issue.
Step 1
Try this Fix
Click on the Download link and install the Fix No. 195 ( Restore Desktop Icons and Taskbar )
Download Link
Step 2
Press CTRL-ALT-DEL to bring Task Manager.
Click on New Task and type appwiz.cpl and click OK
This will re-run add/remove programs.
Remove/Uninstall all new program you installed before having this problem, Also remove the Windows XP Hotfix
Restart your PC.
The access to the taskbar , icons will all come back and Install a new Antivirus.
Step 3
If None of the above steps work, try a System Restore to previous date
Click START - All Programs - ACCSESSORIES - System Tool - System Restore
Choose the date before the system started giving trouble. ( The Date will be in bold ( highlighted ) which indicates the system can be restored to that date with all the settings on that date )
*Note : Doing system restore will uninstall any software/program you have installed from the date you choose the system restore till current date, However it will not delete any files created )
Hope this is helpful.
Nov 10, 2010 | Dell Dimension 9200 PC Desktop
1304 error when trying to install microsoft office student 2007
To resolve this behavior, use the following methods.
Method
: Re-Register the Windows Installer
To re-register the Windows Installer, verify the location of the Msiexec.exe file on your hard disk and in the Windows Registry, and then re-register the Windows Installer. To do so:
WARNING: If you use Registry Editor incorrectly, you may cause serious problems that may require you to reinstall your operating system. Microsoft cannot guarantee that you can solve problems that result from using Registry Editor incorrectly. Use Registry Editor at your own risk.
Note Because there are several versions of Microsoft Windows, the following steps may be different on your computer. If they are, see your product documentation to complete these steps.
Verify the location of the Msiexec.exe file on your hard disk. To do so:
Click Start, and then click Search.
Click All files and folders.
In the File name box, type msiexec.exe, and then click Search.
In the search results, make a note of the location of the Msiexec.exe file.
The location of the Msiexec.exe file should be similar to the following example, where Drive is the drive where Windows is installed, and %Windir% is the folder where Windows is installed:
Drive:\%Windir%\System32
An example of this is C:\Windows\System32.
Note In Microsoft Windows 98-based computers, the Msiexec.exe file is located in the Drive:\%Windir%\System folder.
On the File menu, click Close.
Verify the location of the Msiexec.exe file in the Windows Registry. To do so:
In the Open box, type regedit, and then click OK.
Locate, and then click the following registry key:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Servic es\MSIServer
In the right pane, double-click ImagePath.
In the Edit String dialog box, make sure that the string in the Value data box contains the correct path of the Msiexec.exe file on your hard disk that you determined earlier in step 1.
For example, if the Msiexec.exe file is located in the Drive:\Windows\System32 folder on your hard disk, the correct path of the Msiexec.exe file in the Value data box is the following path, where Drive is the drive where Windows is installed:
Drive:\Windows\System32\Msiexec.exe /V
If the Value data box does not contain the correct path, make the appropriate changes to correct the path, and then click OK.
Quit Registry Editor.
Start your computer in safe mode, and then register the Msiexec.exe file. To do so:
Shut down, and then restart your computer.
Press F8 after you receive the following message:
Please select the operating system to start
On the Windows Advanced Option menu, use the arrow keys to select Safe Mode, and then press ENTER.
If you use a dual-boot or multiple-boot computer, select the appropriate operating system from the list that is displayed, and then press ENTER.
Log on to the computer.
In the Open box, type the following line, and then click OK:
msiexec /regserver
Shut down, and then restart your computer in standard mode.
If the issue persists and you still receive the error message that is described earlier in the "Symptoms" section, follow the steps in Method 2.
Method 2: Reinstall the Windows Installer
To reinstall the Windows Installer, rename the damaged Windows Installer files, and then reinstall the Windows Installer. To do so:
In the Open box, type cmd, and then click OK.
At the command prompt, type the following line, and then press ENTER, where Drive is the drive where Windows is installed and where %Windir% is the folder where Windows is installed:
attrib -r -s -h drive:\%Windir%\system32\dllcache
For example, type
attrib -r -s -h c:\windows\\system32\dllcache
At the command prompt, type exit, and then press ENTER.
Restart your computer.
Update the Windows Installer files on your hard disk to the latest version. __________________
Feb 22, 2010 | Microsoft Office Professional 2007 Full...
My laptop boots and reboots on its own... When I login it logs the user off
Hello ! i want you to try something re install the operating program on this computer   .the operating program might be corrupted  . thats why its behaving that way  .also run an anti virus  to check the hard disk for program infections .ie before X P installation .
best of luck
Aug 04, 2009 | Acer Aspire 5600 Series 5630-6951 Laptop
Missing Control Panel+Run Command+Active Desktop
HI! QUESTION. HAVE YOU, OR CAN YOU RE-INSTALL WIN98 FROM CD? IT SOUNDS LIKE THE BEST SOLUTION MIGHT BE TO DO A RE-INSTALL OF THE ENTIRE WIN98 FROM THE CD. IT SOUNDS LIKE THE FILES MISSING MIGHT HAVE BEEN PERMANENTLY DELETED AND IF YOU CAN LOCATE THEM ON YOUR COMPUTER, YOU MAY HAVE TO RE-INSTALL THE 98 OS TO GET BACK RUNNING. ONE THOUGHT, THIS MIGHT BE AN EXCELLENT TIME TO UPGRADE TO WIN XP,SP2 WHICH IS AN EXCELLENT PROGRAM AND HAS BETTER RESTORE FEATURES. I PERSONALLY USE XP,SP2 ON MY ONE DESKTOP MACHINE AND IT RUNS MY WIRELESS NETWORK AND HAS BEEN VERY STABLE. I REALLY HOPE THIS HELPS YOU. IF YOU HAVE MORE QUESTIONS, PLEASE REPLY. I'LL HELP.
Oct 31, 2008 | Microsoft Windows 98 for PC
Error 1719
Error 1719 occurs when the msiexec.exe program becomes disassociated with .msi files. Under Windows XP x32 this is usually fixed with rebooting into safe mode, renaming the msiexec and DLL's and letting Windows File Protection reinstall them. This doesn't always work in x64.
Error 1719 occurs in x64 when the 32-bit version of msiexec is registered as the msiserver. Here's the fix:
  1. Open regedit ( Start -> Run -> regedit.exe -> OK)
  2. Go to the following key: My computer\HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\MSIServer
  3. Look at the ImagePath entry. For Windows XP x64 it should read:
CODE - C:\WINDOWS\SysWOW64\msiexec.exe /V
If it doesn't edit the registry to match that.
4. Restart the Windows Installer service from the Admin Control Panel -> Services CP
OR
Click on the below link or copy the URL and paste it in your web browser.. Follow the steps....
http://support.microsoft.com/kb/315346
Thank you......
Oct 01, 2008 | HP Computers & Internet
I can not install OfficeSuite. I have Windows Vista home Premium. I had downloaded updates all afternoon and it still shows error 1719 Window installer not correctly installed. Help!
Download:Windows Vista Service Pack 1
I tried personally in WIN-XP worked same applies to Vista.
Error Message:
Error 1719. The Windows Installer Service could not be accessed. You may be running in safe mode or Windows Installer may not be correctly installed. Translation:
This message might appear when you’re trying to add or remove a program that installs via a Windows Installer MSI (Microsoft Software Installation) package file. The Windows Installer Service is the standard method for installing and uninstalling software on Windows XP. It keeps track of all of the components that need to be installed for a particular program to run and ensures that any files that are shared by programs are not removed when one of those programs is uninstalled. The Error 1719 is an indication that some Windows Installer Service files are missing or have become damaged. Solution:
The first thing to try is re-registering Windows Installer in the Windows registry. Make sure that no other programs are running and then click Start, Run, type msiexec /unregister in the Open field, and click OK. Next, click Start, Run, type misexec /regserver in the Open field, and click OK. Restart your computer and try installing or uninstalling again.
If you’re still getting the error message, the next step is to try reinstalling the Windows Installer files. In order to do this, you’ll first need to rename the existing files.
First, click Start, Run, and type msiexec /unregister in the Open field, and click OK.
In My Computer, click Search and locate the following three files: msi.dll, msiexec.exe, and msihnd.dll. They are hidden files so you’ll need to select Search Hidden Files And Folders under More Advanced Options. When you’ve found the files, rename them, by removing the .dll and .exe extensions and replacing them with an .old extension(for example msi.dll becomes msi.old).
Once you’ve renamed the files, WinXP will automatically replace them with a new copy from the dllcache (a hidden folder where copies of important system files are kept in case you mistakenly delete or rename critical system files). Restart your computer and try to install or uninstall the program again.
Finally, if neither of the above processes corrects the problem, boot into Safe Mode, and go through the above steps again, first re-registering and then reinstalling.
or
Go through the following links:
http://www.vistax64.com/vista-general/45784-windows-vista-error-1719-help-3.html
Hope this will be helpfull
Please rate me...
Thanks & Regards.
Nandu
Sep 02, 2008 | Computers & Internet
Error
it looks like windows installer is corrupted
rename the file to use as a back (C:\windows\system32\msiexec.exe to msiexe.old.exe), download and reinstall this
Dec 10, 2007 | Nova Development Photo Explosion Deluxe...
Microsoft Windows XP Professional Logo
955 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
