Question about Radio Communications
D-104 Silver Eagle Mic Squeels
I have a D-104 power mic that squeels,I was informed,all I had to do was add a capacitor.My question is what cap & where?
  • 204 Answers
Hi, usually when they refer to putting a cap in, their talking about adding a .01mfd disc cap to the white audio lead wire up inside the bottom of the mic. Just follow the cord into the bottom of the mic, by taking the bottom off. find the white(audio) wire where it fastens to either the board or the terminal strip. Just unsolder the white wire and add the cap and resolder the other leg of the cap back where the white wire was removed. Some people even use a cap and resistor combo. Sometimes using a .001 cap from the audio line to ground then a 4700 ohm resistor will work in extreme cases.
http://www.qsl.net/wa2mzf/d1044.jpg
You can experiment with different combo to see what will work for you. Hope this helps you out, let us know,,, Mechanic
Posted on Feb 18, 2008
Can you help need the wiring for astatic silver eagle mic to wire up to the yeasu ft-757-gx radio
The best info I can find iis
radio mic
pin5 blue mic ground
pin6 red ptt
pin7 screen
pin 8 white mic
Jan 30, 2015 | Astatic Radio Communications
Wire a sliver eagle to a cobra 2000
1 is white 2 is blue 3 is Black 4 shield 5 is Red
Sep 30, 2014 | Astatic D-104 Mic Microphone With Stand...
How to wire a Golden Eagle Astatic D-104 Mic to a RCA Cb Co-Pilot 14T303 4 pin connector
i have a gold eagle mark 4 i like two put a 776 mike back on it but i do not know the w coed .thank you .
Jan 27, 2013 | Magnum DeltaForce CB Radio
I need to wire a D104 Silver eagle to a Presidential Madison, I think I have it right but no reception??????
silver eagle d-104 power mic what color of wire goes where on a tram d-201a 4pin
Jan 15, 2011 | Radio Communications
Can the soundcard be replace om a ga-m55sli-s4 motherboard? Whenever i check the mic on the playback feature it squeels....
You can't really replace the integrated sound card on motherboards without some work thats not really worth it. I would suggest just buying an add-on pci sound card that has all the features you need. If you need a basic one, you can get them for cheap, ~$12, or even a used good one for <$40.
As a note, when you add on a PCI sound card, you may have to disable the integrated one/enable the PCI one through the BIOS. Not usually a big problem though.
Aug 13, 2009 | Gigabyte GA-M55SLI-S4 Motherboard
RCI 2970 squeels until you unplug the external speaker and plug i
Strange! I used to run almost the same kinda setup but with a super scanner omnibeam, i modded mine myself. At 1 time i had a squeal problem it was in the mic if i remember correctlly i ran a external wire from the screw on the spring inside the mic where the cord comes out to the radio chassis and it stopped it give it a try. I used a simple speaker wire, also you might want to try grounding the radio to the power supply. Sounds like a ground problem! I have a awsome mod for that radio that would enable you to run a regular amp with it and also would enable you to talk local without engaging the amp in the radio using only 4 watts! Let me know how it works out for you with the squeal? if intrested in that mod contact via email at (noteethontop@yahoo.com). put 2970 in the subject line. Take care.
Jan 17, 2009 | Radio Communications
Mike to CB
This has worked for me in the past
Pin 1: Shield and Blue (Mic shield and PTT ground)
Pin 2: White (Mic Audio)
Pin 3: Red (PTT)
Pin 4: No Connection or Mic Return
Note: The Yellow and Black wires are not used.
I hope this helps,
Thank you,
Shuttle83
Nov 03, 2008 | Radio Communications
Radio Communications Logo
610 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
