Question about Motorola Mobility RAZR V3
Razor phone broken apart
If my phone is broken apart could it be put back together?
    Brigadier General:
  • 7,752 Answers
Yes it can be
Posted on Feb 17, 2008
How do I take apart razor to lubricate the motor?
Oster Classic 76 hair clipper - take apart to clean or fix ...
? 9:53
https://www.youtube.com/watch?v=nu8UaoCxtxo
Feb 20, 2010 - Uploaded by darwincollins
It is an amateur video demonstrating how to take apart a Classic 76 clipper. ... your clipper with Oster Kool Lube 3 Clipper BladeCoolant Lubricant Cleaner. .... Motor did not slide out but all wires shredded and motor was in pieces ... What's that little button just below the '76' for and how do you know exactly ...
MOTOR TEST Checking the motor on broken Hair clippers ...
? 0:32
https://www.youtube.com/watch?v=TaWUxcdGBSg
Mar 29, 2015 - Uploaded by You can Fix It!!!!
Testing motor on shears clipper trimmer razor shaver. How doyou know if the blades or motor are brok... ... oils oiling oileddisassemble disassembling take apart taking apart .... 3:21. How To ' Change Cord ' Change Switch ' How To Repair Wahl Clippers ' - Duration: 2:24. by ronsclassickuts 13,453 views.
How to sharpen a Norelco electric shaver - Instructables
www.instructables.com/.../How-to-sharpen-a-Norelco-electri...
InstructablesYou will need a small brush to clean shaver and heads, also a flat piece of ... I then take a tool I made from a broken Norelco razor and a writing pen which ... Mix a 1;3solution of White toothpaste [1] and Mineral Oil [3] on the back of a ... Disassemble[keep the screens & blades mated] and spray with Bathroom Cleaner. 5.
Taking Care the Right Way to Keep Electric Razor Like New
Dec 06, 2015 | Health & Beauty
I have a Philips Norelco 7310XL razor and I have a problem. I recently moved, and in the process, something happened, and my razor isn't working. When I turn the razor on, the blades turn slightly and then...
It sounds like maybe one of the blades is damaged and it is jamming the whole thing. Try taking apart the head assembly and then insert each head one by one turning the shaver on in between each one. This should identify if one is damaged and causing the problem
If you require new heads, you will find them at shaveroutlet.com. See link below
http://shaveroutlet.com/norelco-philips-hq8-spectra-sensotec-replacement-heads-p-251.html
Sep 18, 2010 | Philips Norelco 7310XL Electric Shaver
RAZOR v3 -- i have 2 batteries, both good, 2
try taking out the sim and blow the stuff out of it. Then put it back together and see what happens
Dec 29, 2009 | Motorola Mobility FOR MOTOROLA RAZR RAZOR...
I dropped the razor and the 3 heads fell off, nothing is broken, but I can't figure out how to put it back together Help!
all you have to do is put them back in there place you should have two legs that spring out from the blades align them with the 2 holes on the shaver and push them in
Oct 21, 2009 | Philips Philishave HQ8150 Electric Shaver
My son rode his E100 scooter through a puddle and didn't tell me until a few days later. The scooter won't turn on now and I've tried to re-charge the battery. Is there anywhere I can send this scooter for...
Your problem could be one of two things. The motor could have short circuit or the components under the deck could have short circuit. The problem is, when your son ran the scooter through the puddle the water acted like a conductor. Connecting the positive and negative poles together until the water dried out(creating a short circuit). I suggest, if you're handy, to take the deck off and check for corrosion both the battery and the controller. If that's not the problem then check the motor (you're probably going to have to take it apart). Just a quick tip, be aware of everything you apart. Where it goes and how fits on there. It will make it a lot easier to put back together. Once you find the problem replace the part either by finding the replacement at razor.com or at electricscooterparts.com. If you not handy then send the scooter to razor for repair, but it might take a while to get back. Best luck.
Oct 16, 2009 | Razor E100 Electric Scooter
I have a verizon razor but the ear speker went out
This is a common issue with the Moto Razor and can only be fixed by replacing a part. This phone uses different speakers for speaker phone and talk modes.....If you have an old razor laying around that is the same model, you can use its speaker if you believe or can prove it works......otherwise you can buy one for a few bucks. Here is a randomly selected site that sells these parts.
1. Remove the 4 plugs over the screws on the flip top and the screws themselves. 2. pop the top apart and up at the top you sill see where the speaker just sits in there. 3. Replace it the way you saw it in there 4.put it back together Now you can hear your friends without speaker phone!!!
Good Luck!!!! ANd pls rate this post
Oct 13, 2009 | AT&T LG CU720 Cell Phone - Silver
I can only hear people talking through speaker phone
This is a common issue with the Moto Razor and can only be fixed by replacing a part. This phone used different speakers for speaker phone and talk modes.....If you have an old razor laying around that is the same model, you can use its speaker if you believe or can prove it works......otherwise you can buy one for a few bucks. Here is a randomly selected site that sells these parts.
Sep 25, 2009 | Motorola Mobility RAZR V3xx Cellular Phone
Conair GMT200 Assembly
Hey dude i had the same problem n_n. Attach the screws in place and try to screw one by one gently. Soon this pressure will keep the spring tighten (instead your finger's pressure) then it will be easier to reassemble the component. I know you'll fix it n_n.
May 20, 2009 | Conair GMT200TD
Motorola Mobility RAZR V3 Logo
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
