Question about HP Pavilion dv1000 Notebook
DV1000 Shut Off For The 4th Time
I've had my HP Pavilion DV1000 for 2 years now and this would make the 4th time in two years the computer just cut off and will not come back on. The first year along it turned off 3 times. I sent it back and they "fixed" it so they said and the last time I sent it in they said the problem was solved and it wouldn't happen again.
I don't know what else to do. I'm a culinary author and everything I've ever done is on that computer. I'm sure you're saying "why didn't you make a backup". Well I did and then the damn CD ROM drive stop working. It won't read a disk anymore and it will not burn anything...I'm just stuck!!!!!
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 56 Answers
1.when this situation occurs remove the battery and insert after 1min.
2.now start again
3.if it does not start now again remove the battery and also RAM after 5min insert both again
Posted on Feb 17, 2008
I have hp pavilion dv1000 computer. i was using skype v3 for two years with no problem. then i installed skype v5.3. Since then my microphone doesn't work. It looks like some setting got changed. I...
I think you are right.
Try changing your audio-settings, until your mic works again.
I've you still need help, i can remotely control your computer to fix this problem
Good luck,
DJ Skywalker
Jun 19, 2011 | HP Pavilion dv1000 Notebook
Is this hp pavilion dv1000 battery a cheap one?
From the link you gave its seen that its comparatively lower than the other series.. Brand: HP Laptop BatteryBattery Info:
Li-ion, 4400 mAh, 11.10V, Black, 310.00(g), 205.15 x 59.20 x 37.50 mm
Rating: rate4.gif
Capacity Voltage Price($) 4400 mAh 11.10V C $ 57.79
8800 mAh 11.10V C $ 79.69
Availability: In stock
Notes for charging Hp Pavilion dv1000 Series battery :
  1. You must fully drain the Hp Pavilion dv1000 Series battery until the laptop goes into hibernation for your first use it.
  2. Store it in a cool and dry area. Do not expose battery to water or other moist/ wet substances.
  3. Do not forget to take away your Hp pavilion dv1000 battery from the laptop if you will not use it for a long time.
  4. Know that after that plug in your charger and allow it charge for 12 hours or depending on what the technician has told you. 12 hours is the max and you can use it while charging .
  5. Charge new Hp Pavilion dv1000 Series battery for three times at first. After that it will take less than 2 hours to fully charge your Hp Pavilion dv1000 Series battery.
  6. It is normal for HP laptop battery to become warm during charging and discharging.
  7. Learn that this is recommended so that the Hp Pavilion dv1000 Series will heat up for the time allowing ions to reawaken.
Jan 20, 2010 | HP Pavilion ZV5000, ZV6000, ZX5000 Series...
Whether DDR is compatible for hp pavilion dv1000 or only sdram is compatible. With which ram can i upgrade.
According to the maintenance manual only 266Mhz Ram can be added to the notebook.
This would be SDRAM.
Hope this helps!!
Kind regards!!!
Jan 06, 2010 | HP Pavilion dv1000 Notebook
Laptop turns off when charger is plugged in !!
Charger is bad and is not putting out the correct voltage which causes the computer to shut down. Battery probably isn't much good either if it only lasts for one hour. Get new batter and charger. Ebay'ers will help you find one cheap.
Jun 01, 2009 | HP Pavilion dv1000 Notebook
HP Pavilion DV1000 Screen Replacement
Here's the HP manual for it, too many instructions to post and the pictures should be helpful. Just take your time, figure out what you're going to do twice and then do it once. Much cheaper to take a few hours longer than you'd figured on than to fix a self-made problem:
http://h10032.www1.hp.com/ctg/Manual/c00312379.pdf
(Starts at 5-31)
Oct 17, 2008 | HP Pavilion dv1000 Notebook
DV1000 Motherboard repair
You have to look for a bad connection on MB. You have a broken trace from openning and closing. You need micro-soldering iron to fix it.
Sep 14, 2008 | HP Pavilion dv1000 Notebook
HP Pavilion dv1000
Ur laptop getting viruses.Better to install any Antivirus software and Scan once in a week.If u want audio drivers then go to this website www.hp.com.
There u click on chatting session and download the any drivers.
Thanks
Mar 13, 2008 | Computers & Internet
HP Pavilion dv1000
I found out how to fix the no sound problem on The HP Pavilion DV1000 Look under Dv1310 thats the model number the driver your looking for is SP30262.exe
Feb 27, 2008 | HP Pavilion dv1000 Notebook
HP Pavilion dv1000 Notebook Logo
44 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
