Question about Durabrand Portable DVD
MAnual/Reset Parental Control Code
I Recently wen to watch a movie. it was blocked by the parental control feature.
this feature hasnt been used in a while. and i am wondering if anyone knows how to reset the code.
  • 3 Answers
According to the manual, "If you forget the password, you can erase your current password by pressing the number 8 button on the remote four times, thn press the enter button to confirm the setting. PASSWORD: 8888"
A picture of an unlocked lock indicates that Parent Lock is NOT active.
Parent Lock Levels:
1: Kid Safe 5 : PG_R
2: G 6 : R
3: PG 7 : NC _17
4: PG_13 8: Adult
It also says that it takes 3-5 seconds to reset the unit to the factory default. I hope this helps! Karen
Posted on Mar 23, 2008
  • oliver underwood
    oliver underwood Jul 07, 2014
    Does anyone know how to set a password, I have selected "Kid Safe" and hit enter but it doesn't save and still plays 18 rated films without asking for a password. Any suggestions please?
How do I change Parental Control on ROKU?
Parental control is one of the features available on roku. This feature restricts the children to access the movies and TV shows based on the rating of the movies and TV shows.
Roku doesn't provide any true parent controls. But the parental control workaround is simpler one. Only a few channels on roku have the parent control. Such channels are Amazon Instant Video, Netflix, and Redbox.
Initially, you have setup your roku account and add the channels from the channel store by using the PIN.
    1.Sign in to your roku.com/link account.
    2.Click the update button which is next to the PIN reference.
    3.Then choose the choice "A PIN is required when using your Roku account to make the purchase or add any item from the Channel Store."
    4.Put the 4-digit PIN and save the changes. After that, you can watch the channel by installing them from the roku channel store.
    After finishing the watching the channels delete it.
    If you deleting the paid channels means there are no issues because you need not pay again for reinstall. For re-install it you have to sign in again.
    For some channels which have parental control, that doesn't require to delete the channel after watching.
    If you want more information about the roku call 1-844-965-4357 to get instant help.
Apr 07, 2014 | Computers & Internet
I NEED A CODE TO WATCH CERTAIN PICTURE. CAN YOU HELP?
hi
do the following to exit the code option.
p { margin-bottom: 0.21cm; }
1.Press MENU to see the menu.
2.Press VOL+ or VOL- to highlight SET.
3.Press CH+ or CH- to select PARENTAL CONTROL.
4.Press VOL+ or VOL- to see the SECRET CODE screen.
5.Press the Number buttons to enter your four-digit secret code.
[The code will appear on the screen as you enter it. The code "0000" is the default of the
TV. If you have not set up a code previously, then "0000" is the code.You cannot use "0000" after you set your own code (unless you reset the code to "0000").]
6.Press CH+ or CH- to select MASTER ENABLE, BLOCK UNRATED,or BLOCK NO RATING.
MASTER ENABLE: This is the "master switch" for Parental Control. When ON, all blocking/censoring is enabled.When OFF, all blocking/censoring is disabled.
BLOCK NO RATING: All programming with NO content advisory can be blocked if this feature is ON and MASTER ENABLE is ON.
BLOCK UNRATED: All unrated programs (based on Movie Ratings or TV Ratings) will be blocked if this feature is ON and MASTER ENABLE is ON.
7.Press VOL+ or VOL- to turn the blocking option ON or OFF.
8.Press TV/AV/EXIT to remove the menu from the screen.
ok
Jan 13, 2011 | Philips Magnavox 27MS343S 27" TV
How to reset the parental control code - I forgot the code and want to reset with a new one
This is what I found in the instruction manual on this and I posted it here for you. Try using 3355 for the code and everything else listed here. If that doesn't work, try the very last tip which tells you how to do a factory reset and repeat the first step using the 3355 as the code.
Here's the instructions from manual:
Parental Control
Parental Control allows you to block certain channels or programs so children cannot view
programs that are not age appropriate.
To enter the Parental Control menu, you need an
access code. The first time you enter, use access
code 3355. See "Setting an Access Code" on
page 33 for information on creating a new access
code.
You can set the following options to block
content:
• Channel Lock — Blocks selected channels
• Movie Rating — Blocks movies based on their rating (G, PG, PG-13, R, NC-17, and X)
• TV Ratings — Blocks TV shows based on their rating
• Block Options — Turns on or off all your parental control settings
NOTE: You can use Clear All to unblock the channels and programs that you have set.
NOTE: If the Block Control in the Parental Control menu is enabled, all the sub screens in POP (POP1,
POP3 and POP12) mode will be blank
Setting an Access Code m
After you enter the Parental Control menu for the first time, you can set your own four-digit access
code. If for any reason you lose or forget your access code, you can use the default code.
1 In the Parental Control menu, select Change Code.
2 Using the number pad on the remote control, enter a new access code.
3 Select Exit.
Reset the original factory defaults. Press Menu on the remote
control, select Setup, and then select Factory Reset
Jul 28, 2010 | Dell W4201C 42 in. Plasma HDTV
Need to reset code
Found this on another site, from personal experience but its very well written so here you go.
The Playstation 2 is not only a video game system, but also a DVD player as well. In many families, the Playstation 2 serves as the "kids" DVD player, which means that many parents choose to take advantage of the parental lock feature to limit what kinds of movies the Playstation 2 will play back.
There could be instances where you entered in a parental code months ago, and now can't remember it. Or, you may have purchased a used Playstation 2, and you never knew the code to begin with. If you or the prior owner set a parental lock code, the Playstation 2 won't play back many movies without entering the code first. You could try to hunt down the original owners, or start inputting every code possible starting with 0000, but it's easier to reset the password and disable parental lock using a secret code.
Here is the procedure to reset the parental lock code:
  1. Bring up a screen where the unit asks you to enter in the parental code. You can either insert a restricted disc, or enter the DVD setup menu and go to "parental control" under custom setup.
  2. When the screen asks for the code, press the SELECT button, then enter in the code "7444".
  3. The level adjustment under Parental Control dictates the strictness of the player. The lower the value, the more strict it will be. Either increase the value to lower the restriction, or disable the lock entirely by setting it to "off".
  4. Once you have made your adjustments, be sure that the DVD tray is empty, and press the RESET button on the front of the Playstation 2. It is imperative the tray is clear of any DVD or game for the unit to save your settings.
A note for parents: If you're wondering what is stopping your child from using the above procedure to circumvent your rules, you can verify that they haven't reset the parental control very easily. Since the above procedure eliminates the old password entirely, all you need to do is see if your original password still works. If it does, they did not use the above procedure to break the rules. If it doesn't, they might be trying to pull the wool over your eyes.
Please rate accordingly
Justin
Jul 28, 2010 | Sony PlayStation 2 (PS2) Console
Magnavox child lock help
hello The parental control menu enables
you to limit access to programs that
may contain objectionable material
or are not suitable for viewing by
children. The default access code is
0711
0711.
The following table provides details
about the menu items:
Component Function Range / Options
Lock Enable
Enables the parental control lock. When
enabled, channels with objectionable viewing
content are blocked and can only be
accessed with a password. You can block
channels according to the movie or TV ratings
of the channel’s programs.
Off, On
Movie Rating Helps you block programs based on their
movie ratings. See “Movie Rating” on
page 25 for more details.
TV Rating Helps you block programs based on their TV
ratings. See “TV Rating” on page 26.
Change Code Changes the password for the parental control
lock.
Press the number keys to
change the password.
Reset Resets all channels and programs to their
default factory settings.
regards
shaun
Parental Control Menu
Lock Enable
Change Code
Reset
Back
Main Menu
Sound
Size
PIP/PBP
Parental Control
Channel Setup
Setup
Exit
Press Right to Enter
Press New Code
Off On
TV Rating
Movie
Mar 13, 2010 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
I bought a used ps2 and it had a parental control code so i can;t watch movies at all
7444 is the password reset for PS2 parental control. Enter that and you should be prompted for a new password.
Sep 11, 2009 | Sony PlayStation 2 (PS2) Console
Parental password?
Jun 06, 2008 | Sony PlayStation 2 (PS2) Console
Parental control password
i don't know if you changed the parental control code or not but when it comes to put the code press select and then insert 7444 and it will delete the password and will ask you to put the new one then add any three digit number and then when the movie starts press select and go to setup and then parental control tab and turn it off now there will be no passwords..........
Jan 16, 2008 | Sony PlayStation® 2 Console
Video Game Console
Start a DVD, then stop playback. Clear "resume play" (press stop twice), goto the Control Panel, the select SETUP, then ADVANCED SETUP. Select PARENTAL CONTROL, then press Select. Enter the number 7444.the old password is clear, now you can set a new one and change the rating.
Dec 23, 2007 | Sony PlayStation 2 (PS2) Console
Parental Controls feature
Hey Aurora, After you put your password in, go back and change the password using blanks spaces. Then it should reset to 'parental control off'. Let me know if this works. Some Sanyo models are different to reset.
Jul 21, 2007 | Sanyo Vizon LCD-15A2 Television
Durabrand Portable DVD Logo
1,225 people viewed this question
Top Durabrand Televison & Video Experts
matt martin
matt martin
Are you a Durabrand Televison and Video Expert? Answer questions, earn points and help others
