Question about Maytag Neptune MAH5500B Front Load Washer
Neptune washer relay kicks out at the start of spin cycle.
    Sniper:
  • 65 Answers
Open panel at rear of control panel usning phillips head and 5/16 the board attached to that panel will probably have a burnt r14 r1 or r21 resistor. this has been an ongoing problem with this model even a class action lawsuit.(lawsuit expired 9/2005) you can change the board but this will eventually happen again maytag directs you to do a full conversion kit rebuild about $400
Posted on Feb 18, 2008
2 Suggested Answers
FAV6800AWDIY
  • 526 Answers
SOURCE: Neptune FAV6800AW Top Load Washer: My Neptune washer is showing error code dc..Once i...
See this post Clutch Fix if you want to DIY I will help you.
Post back if you have questions……..Rich
Posted on May 23, 2010
SOMETIMES THE MACHINE DO NOT RINSE/SPIN? PLEASE ADVISE?
You may need a new cycle timer it isn't relaying the message to the machine to kick into the rinse spin cycle. Timer is easy to replace your self or call a repair man.
May 02, 2016 | Washing Machines
Why does the compressor starts off with short cycles then kicks on?
Could be a compressor start relay, overload and run capacitor. What is the model number of the fridge?
APPLIANCE 911
Dec 07, 2015 | Refrigerators
Eratic, sometimes door lock doesnt activate, when it does wahser starts but stop mid cycle and wont continue. Replaced door switch and pump
Repair needed on Maytag Neptune washer - Home Improvement ...
www.dslreports.com > ... > Home Improvement
DSLReports
Aug 5, 2007 - 19 posts - ‎8 authors
Forum discussion: We have a Maytag Neptune front-loader washing machine that ...the drain/spin cycle after a wash even though the timer continues to ... related circuit board failure" their Neptune washer will lock the door, turn on the ... then will either not start tumbling or will stop operation mid-spin cycle.
How To Fix A Washing Machine That Is Not Spinning or ...
removeandreplace.com/.../washing-machine-or-washer-dryer-is-not-spin...
May 13, 2013 - The absolute first thing to do to your washing machine that will notspin or drain (whether it. ... I was so fed up with the machine sometimes refusing to spin or drain the .... I just did a load and it stopped midcycle with e and f error codes.... I tried different cycles but all that happens is the door lock engages ...
Maytag Washer Troubleshooting - YouTube
Dec 02, 2015 | Maytag Washing Machines
After wash cycle, tube will not drain water?
Probably a blocked empty pump filter. Spin won't kick in until all the water is evacuated. If there is a little left, the machine will do the slow turn cycle that it does just before spin starts but not start the spin cycle because of the water in the drum.
You need to locate the filter and clean it. That should fix your problem. Once this is done, remember to keep the filter clean every few months.
Jun 23, 2011 | Whirlpool Washing Machines
Hi I have a Bosch WSL1662 Maxx washing machine. The spin cycle does not work properly. What could the possible cause be. I have cleaned the outlet of the washing machine and the problem is still...
Jun 23, 2011 | Washing Machines
I have a FAV6800AWC Top Load Maytag Neptune When in spin cycle you cannot keep it balanced, makes a banging soud (loud) and kickes washer off
It sounds like the spin basket rear support is loose. The support is part of the spin basket & does not come separately. This type of repair will more than likely need the spin basket replaced & possibly the outer tub also. It will cost you $200-300 to replace the assembly.
Hope this helps.
Shane
Mar 13, 2011 | Maytag Neptune FAV6800AW Top Load Washer
My Neptune washer turns off after about 40 mins into a 58mins cycle. I can't get it to re-start on that programme, but it will re-start on a spin cycle and spin quite satisfactory. where is the filter to...
this neptune dosent have a filter sump.... remove 1 screw off both door hinges and non hinge side lift door up and off remove front panel pump is on floor bottom right side
Jan 27, 2011 | Maytag Neptune MAH5500B Front Load Washer
Washer not spinning in spin cycle
My maytag neptun mah4000ww washer stop spinning in spin cycle.
Now it stop spin even during regular cleaning cycle. What to do?
How mach it may cost?
Jul 10, 2010 | Maytag Neptune Washer
Maytag Neptune MAH5500B Front Load Washer Logo
138 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
