Question about Car Audio & Video
Pioneer P626 car audio in 1991 Lexus LS400
Radio and tape work fine get ERR when CD is activated, tried romoving fuse to radio but no help.... any ideas
  • Anonymous May 19, 2008
    radio and tape work fine get ERR when CD is activated,
With radio off I pressed the CD button and CD came on with no error code and works fine.
Posted on Feb 20, 2008
My hazards and turn signal lights do not work. I own a 91 lexus ls400! So far I've replaced the flasher relay under the dash. But they still don't work. Help please!
Have you checked fuses? Test them, don't rely on being able to see they're blown as they'll sometimes have a fine crack that's hard to see.
Mar 31, 2015 | 1991 Lexus LS 400
1990 lexus ls400 cassette player will not read or play my cassetes. i put in my cassettes but my front tape flap doesn't close and it automatically switches back to the radio.
The player has to seize the cassette as it is inserted and seat it in the correct position to be played. Sometimes the manual eject linkage becomes defective or misadjusted, preventing the cassette from seating correctly. The eject button may depress fully without causing ejection or it may depress but not cause ejection.
Dec 03, 2013 | Nakamichi 90 94 Lexus Cassette Tape Radio...
Brake lights and rear deck light do not work on 1991 Lexus ls400. I checked all fuses,bulbs, and Brake switch and they are fine. Help?
Have you probed the tail/brake lamp socket to see if power is there or you just assume it is? also make sure the ground is good for the brake lights Do that if not done already and let me know.
Jun 22, 2012 | 1991 Lexus LS 400
How do i turn on the radio in a ls400 1998
The Nakamichi radio in the 1998 Lexus LS400 is turned on by pressing the large round button on the radio in. This same button also controls the volume by turning it clockwise or anticlockwise. The radio will use the same audio input that it used when it was turned off. The input can be changed using the series of buttons on the right side of the radio, tape, cd, fm, am.
May 24, 2012 | 1998 Lexus LS 400
My 91 lexus ls400 stopped firing up. It turns over but no go.
check/change the crank sensor and check your ignition module
Jan 15, 2010 | 1991 Lexus LS 400
Lexus LS400 back taillight out
It's the top right kick panel fuse and should be a 15 amp.
Apr 19, 2009 | 1991 Lexus LS 400
1994 lexus ls 400, cd player
Hello I just purchased a 1991 Lexus LS400
I have one of those 6 cd changers and got "err" when I started up the CD.
Here is what I tried and the result
1. I took out the CD,s replaced with new ones and it played but only for a bit, then even the new CD's got the err message
2. I then though maybe dust and/ or dirt so I took out the 6 pack of CD's and blasted compressed air into the unit from a can of computer cleaner compressed air. Lost the err message but then came back
3. Read a few other ideas on the problem and then tried the old hair dryer trick. (I am a long term live a board boater and have brought back may mis-behaving electronic devices that have moisture issues with the hair drier) However the hair drier did not do away with the err message.
4. two more boating tricks I thought of... I wiped down each leaf of the CD pack with rubbing alcohol
and actually got a good deal of dirt off the plastic, finally and probably the solution I sprayed some "wire dryer" a light spray then a mist.( Wire dryer made by Gunk is a spray can of a liguid we used all the time to get cars started in the cold weather, even got a better connection by spraying on battery wires to get the sailboat diesel started with an almost dead battery.)
I Waited a few minutes put back the cd holder and it worked.
It has been about 6 hours and it is still running like a champ.
could have been the combination or just the wire dryer...not very scientific maybe it will help
Jan 12, 2009 | 1993 Lexus Ls 400
1994 lexus ls 400 radio reads err when i try to play cd changer.
Hi
How can I find the code for my 1994 Lexus LS400 radio.
Please replyat : shahramanwari@cox.net
With regards.
Sep 16, 2008 | Car Audio & Video
Radio locked 1991 lexus ls400
do you know how to reset radio code lexus ls 400 /1991
Aug 14, 2008 | 1991 Lexus LS 400
Car Audio & Video Logo
265 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
