Lcd montior failure
Standby light comes on then cuts out. i removed the board that connects power and noticed charring underneath a heat sink with a 5 pin connector to the board. have tested with a circuit tester and get nothing from the pins. can i get a replacement or would you advise a new board.
  • Anonymous Dec 28, 2008
    power cuts in and out. Cords are all good
    Scholar:
  • 198 Answers
Posted on Feb 20, 2008
Hello, I have a Samsung LN52B630 TV that quit working...noticeably after a confirmed lightning strike nearby.
Screen coming on when the main plug is removed is normal, that happens on most TV's...Are the spots that have no volts supposed to have voltage? there is a legend on the board to tell what voltages belong no what pin, check that
Oct 28, 2017 | Samsung Televison & Video
Sound stopped coming out from teh tv speakers. i have to run it through my stereo system
Hello, I am John at J. D. Electronics. You have a D4 model. This is caused by a defective spacer under the A / V board. This is not recommended for owner repair, since it involves removal of other PCBs, Sheilds and "spacers" and connectors. On the A / V board ( the one with all the jacks ), is an audio IC that normally runs fairly hot. Therefore, the MFG had to use an aluminum heat sink on the top and bottom of the IC. The problem is that there is a "clay like " spacer pressed between the bottom PCB at the audio IC and an aluminum plate, or heat sink, underneath that sets against the metal back of the LCD panel. Here is what happened; The "spacer " turns into a "sticky goop" causing the whole pcb move towards the Heat Sink under the A / V board. This causes the connections at A / V pcb at the audio IC to come in contact with the bottom aluminum heat sink, thus shorting out the audio IC and then no sound or popping noises. This is common on the D4 and D6 models.We charge about $325 for this repair since it is very time consuming. I have repaired dozens of these sets with this problem. I hope this helps! John
Jan 27, 2011 | Sharp Aquos LC37D44U 37 in. LCD HDTV
I have a 65' Mitsubishi projecton TV Model WS-55859. It will not "start" ie: no sound or picture. I hit the reset button and the green light flashes for about 1 minute. I then wait about 1...
Dean,
Most of the shut down problems with this model series are caused by the convergence IC's failing
causing one or more of the 5 amp micro fuses to open. These are located on the power supply board centered in the middle of the chassi. These micro fuses are small green componets, and kind of look like resisters. there are usuallly 5 of these and they are located left of the transformer. to check them, unplug the AC power to the set. Use a ohm meter and they will read open if they are bad. As far as the convergence IC's, they are mounted on the big heat sink also on the power supply board. You will need to remove the power supply board to replace these. Be careful to remove all the screws in the center of the board, around the edges, and on the back of the heat-sink. The IC numbers will either be STK392-540, or STK 393-110. Use extra care when unsoldering the old IC's to make sure you do not damage the solder pads. I do recommend heat sink compound being used on the back of the IC's to prevent premature failure. Radio Shack should carry some.
I hope this helps,
Skyassoc
Dec 08, 2010 | Mitsubishi Televison & Video
When I first put my tv on the volume is fine, after a few minutes a click sound is made and i lose the volume completely.
Sep 26, 2010 | Sharp Aquos LC-32GD4U 32 in. LCD HDTV
No power?
power board failed check the main board the 5 volt side may have a few capacitors blown. check all of them as usually when 1 starts to go rest can follow don't cost much to replace. the ones next to the heat sink are first to start to wear out, use the ratings that are on the old capacitors and replace the same 105c temp rating. and rating to failed capacitors, you will see the faulty capacitors they will have blown bowed tops or a liquid on the bottom of them
Jun 21, 2017 | LG 37LG30 37 in. LCD HDTV
I'm having serious issues with my Dell Dimension 9200 desktop. I left my computer on overnight and during the night I had a 5 minute power failure. Now when I try to turn the computer on, it does not boot...
though itz not known to me if u r using an ups or invertor or cvt..
is any light blinks up..??..esp. on the monitor or set dead..
DO IT ONLY IF U R A PROFESSIONAL..
however..plz do check the following as in order:..
the Hardware part:..
1) check mains/power supply..the fuse, switch, wiring n associated circuitry..
2) [in case of desktop] the smps itself may b defective/faulty..check the outputs of smps viz. 0v (black~ground); +12v(yellow); +5v (red, green~ps-on, violet~pg& grey~sb); -12v (blue);-5v(white); +3.3v(orange)..
check the battery n adapter [main power], in case of laptops..
replace with a standby n see..
3) unplug mains supply..pick open/remove the cmos battery..check (above +3v)..resit..
4) open the cpu n see if heat is generated..if not..replace the cpu n see..
5) open the CPU Heat-Sink with fan out of the socket..put some "Heat Sink Compound" (available in local electronics chip level spare market)between the cpu/processor and the CPU Heat Sink *** fan..resit/fit it tightly in position..
6) on main/mother board..see with a debug card for mb error..may b short..look for defective capacitors(espabove1000mfd)/mosfets..go through the mb's south bridge n the circuit lie around atx connector..the crystal clock generator (if cpu isn't heating up)..
7)see if the ram(s) is loose/faulty..open clean/remove carbon & or oxide formed on the teeth with an eraser n resit it..or replace with a standby n see..
8)remove/clean dust neatly..dust is non-uniform in nature n may cause jam/short circuitry/excess resistance n many more..resulting an increase in heat..
plz give priority to steps(2, 4 & 6)..
if u r not a professional, always better to seek advise from ur system admin/vendor....
Nov 16, 2009 | Dell Dimension 9200 PC Desktop
When powering up the system the power light comes on the HDD led comes on and then the system shuts off, tested battery, reseated RAM and tested using a known good HD. N/C
humm..if itz not the battery or hdd..i guess itz probably the system board..this is a typical insufficient Wattage/Oscillation/Frquency generation problem, in most of the cases..
retest the battery n adapter [main power], in case of laptops..
6) on main/mother board..see with a debug card for mb error..may b short..look for defective capacitors(esp above1000mfd)/mosfets..go through the mb's south bridge n the circuit lie around atx connector..the crystal clock generator (if cpu isn't heating up)..
Nov 16, 2009 | Dell Precision M90 Notebook
How to disable the resolution notice on VG930m
Use your monitor buttons to look for Resolution Notice and turn it off.
To disable the notice on ViewSonic 23" LCD Monitor , use the buttons on the
front of the montior to do the following:
* Press #1 button
* Use down arrow to highlight Setup Menu and press #2 button
* Use down arrow to highlight Resolution notice and press #2 button
* Select Disable and exit!!
To disable the notice on NEC LCD 1765 monitor
* Press button #5 on the monitor
* Scroll up and down the menu list with Montior Button #4 and then select
with Monitor Button #5. Go to "Advanced menu" set the Resolution notice to
OFF.
Nov 02, 2009 | ViewSonic Computers & Internet
Only standby red light comes on. power button or
There is a failure on one of the circuit boards, and or the power supply itself. The main uPC, or the power supply controller is putting the main power supply in to protect mode.
You would have to send the set for factory service to resolve this issue.
Jerry G.
Oct 10, 2009 | iLO 3200 32 in. LCD Television
Monitor will not turn on
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}Cause of power goingoff: There is a bad 1000uF, 16V capon the power supply board.
Solution: Replace cap. Radio Shack sells a 1000uF, 35Vcap for $2. This will work.
Why did the cap gobad? The cap is too close to a heatsink and over heated.
What does this capdo? This cap sends a signal to an ICwhich keeps the monitor 'on' after the power switch is pushed. When the cap is weak, AC ripple voltage isapplied to the IC and it sends a signal to shut the monitor off.
Opening the Monitor:These monitors are difficult to open.
The two plastic pieces snap together and must be pried apartwith a flat screw driver.
After removing the stand, you need to insert a flat screwdriver at the bottom of the screen where two slots are located. Then work the screwdriver around until the two plastic pieces are separated.
Remove the cover plate and unscrew the push button circuitboard.
Unplug the monitor cords from the driver board and removethe screen.
Unscrew the mounting screws from the power supply board andremove.
You will need to pinch the plastic support in the middle ofthe board to remove.
Cap Replacement:
Cap is located near a copper heat sink and the value will beon the side of the cap. It will be bulged up on the top. You will see burnmarks on the board surrounding the cap. Unsolder the cap.
Install the new cap and solder. Make sure you connect + ofthe cap to + marked on the board.
Be careful not to solder across joints.
Keep leads long so you can bend the cap as far away from theheat sink as possible.
Reassemble monitor and turn on.
This should solve the problem.
Sep 06, 2008 | Dell E173FP 17" LCD Monitor
Computers & Internet Logo
493 people viewed this question
David Payne
David Payne
