Question about Sony DAVHDX265 System
Can't hear regular t.v. from the home theatre speakers
I have the monster cables it was set up before i took it down to do some work now i can't remember what goes where. I can hear the dvd's but when watching t.v. i can't hear anything coming from the speakers. what do i do.
  • dau_sai40 Aug 20, 2008
    I have a Sony DAV-HDX625 home theater system but i could not make it work with my emprex lcd-hd tv. How can i make the tv's audio come out through the home theater system?
By accident, I switched my Sony tv settings mode to channel 4 and the sound can through the speakers.
Posted on Mar 05, 2008
Hi, I just bought a Philips HTS3540 home theatre system and I am having problems hearing the TV (Sony Trinitron) through the home theatre system. The DVD / CD / Radion work fine on the philips, but I...
Ok my situation is similar-i did exactly as u described here bobhifi and it worked initially . Then after some weeks suddenly the Aux display now shows 'AV1 Coax' and no sound is coming out of my LG DVD speakers except under Tuner and DVD modes. Pls help
Mar 28, 2011 | Philips Televison & Video
I cant get the lg lhb977 to work with my cable box. what do i need to set up to hear regular tv not just blue ray and dvds
All i did was run regular red and white audio cords rom my cable boxs audio output to the lg lhb977's regular red and white audio input. and press function enough times on the front of the system till it gets to "AUX" and then it worked for me. As long as you go to ur actual tv options screen and try to set ur speakers to "external speakers" rather than "tv speakers". hope it works
Oct 13, 2009 | LG LHB977 Theater System
LG dvd player connected to 5.1 home theatre
Dont now your sytem but check Home theatre sytem must be switch to 5.1 display and not dvd display. if stil no sound check in setup off dvd for soundsetting like PCM, RAW , 5.1etc and select each one till you get desired sound.
Presume your conections from dvd to hometheater is conected 5.1 cables or 1 digital cable and not stereo(2cables)
Jan 05, 2009 | LG RH177 DVD Recorder/HDD Recorder
Problems with hearing sound from bravia LCD tv through bravia DAV-HDX275 theatre system
The fiber optic port on back on your bravia tv is only for when your using a over the air antenna and watching local atsc channels in your local market. You need to run the fiber optic from your hd cablebox if it has one or your hd sat box if it has one. If you don't have a set top box with the fiberoptic port on it you can use a digital coax cable from the cable or sat box to sound system. The only other way to get sound if you don't have a cable or sat box is to run the red and white rca audio cable from the tv to the sound system and got to the audio setup on tv and turn the tv speakers off and you might have to adjust the audio to fixed instead of variable.
I’m happy to help further over the phone at https://www.6ya.com/expert/brandon_60dfebff379d64bd
Nov 05, 2008 | Sony BRAVIA DAV-HDX267W Theater System...
No sound from plasma to home theatre
First off it's always best to start from scratch when it comes to home audio. LoL. Many times I've been in this situation.
So with everything disconnected. You should have your HDMI, COMPONENT, RCA(R,W,Y)
HDMI and COMPONENT are the exact same thing and in all preference COMPONENT is far better thand HDMI for the pure fact that each wire is in it's own casing and insualted to avoid feedback from the other wires.
Anyways, with everything disconnected we begin
From you Cable/satellite box- Run your HDMI cable from you cable box to your HDMI 1 input on your tv.(If your speakers were to work on your tv you would automaticaly get sound and picture)
That should be all that you should be running from you cable box. Now that we have one thing running we go to the next thing.
From your TV run your audio out (RCA Red/White) to your amp. Usually your preference but more than likely your TV IN on your amp.
With your amp now set on TV, you should automatically get sound from your tv. and if your running an HD cable box even though your only running RED/WHITE to your amp, you will still be receiving Digital sound.
Most new amps Should have a digital input and if your running and 1080iUp this one RCA plugin will give you dolby digital sound from your dvd player to your amp. Then running a video rca up to your tv, will give you the picture, while the digital out on your dvd player to your amp will give you dolby digital sound.
It's a basic simple step to get sound. Like a continuing current. So just as long as you have your cable to -- tv -- home theatre. Everything should work. Otherwise I would go and check your cables and make sure they are not faulty.
I hope this confusing walkthrough helps.
Jun 23, 2008 | Panasonic TH-42PX60U Television
Hooking Up The Theatre System to the TV and Cable.
this means you likeley have your cable box connected correctly, if you have it connected to a standard definition input (AV in or coaxial) make sure the that the dvd player is not in progressive mode.
Jan 27, 2008 | Panasonic SC-HT680 System
SPEAKERS TO DMR E55 DVD RECORDER
Using a receiver to operate speakers?...accordianman
Nov 08, 2007 | Panasonic DMR-E55 DVD Recorder
Home theatre problems sound
Did you try to connect AUDIO OUT from your TV to AUDIO IN on your package?
Oct 04, 2007 | Sony DAV-C700 System
Please help with getting 5.1 sound from my TV!
You must run a Digital Optical cable from your PS3 to your reciever. Then press your function button on your recievers remote until you see SAT/CABLE on your recievers display. Next go to your PS3 settings and go to Sound settings, then Audio Output settings, and select Digital out (OPTICAL) then your done. This is the only way to get true digital sound from your PS3 to your reciever.
Oct 01, 2007 | Sony DAV-HDX500 System
Sony DAVHDX265 System Logo
312 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
