Philips 30PF9975 30 in. HDTV LCD Television
Problem for Philips 30PF9975 30 in. HDTV LCD Television
15PF9936/12 Flat TV
By Marnix on Feb 17, 2008
I get a picture for a few minutes then the picture disappears and I am left with only the sound. Then after another few minutes the sound goes also and all I am left with is a blank screen.
AB
blank black screen after fewe minutes or sometimes seconds. Sound ok
is there anyone with a solution. modelnr is 30pf9946
Comments:
Feb 20, 2008
- Is known problem at servicepoint if there is no white/yellow light present/visible at the (lower) backside of the flattv. This is indicatorlight of a certain condensator. If ther is no light than servicepoint needs to instal new condensator.
Solution #1
posted on Feb 20, 2008
Not Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
need new tv
Solution #2
posted on Sep 18, 2009
Not Rated)
arthurtaylor
Rank: Master
Rating: 83%, 3 votes
I had this problem on my 42" Philips. Just got it yesterday and worked fine on the tv stand. As soon as I mounted the TV to the wall via wall mount system, I had the exact same issue you did. Figured it out today.
The wall mount was putting pressure against the center of the back of the tv (tv set had a slightly rounded back plate, and the mount was a flat plate). As soon as I put spacers (part of the wall mount hardware set) between the wall mount braket and the tv so there was no contact except at the mounting holes, the tv worked fine.
My theory is the pressure pushed the tv back plate against some board components which caused them to overheat (no air flow); or put pressure on internal connectors. I dont know.
Hope this helps, may not apply to your situation.
Was this helpful?
Yes
No
Popular Solutions for Philips 30PF9975 30 in. HDTV
Questions and Unsolved Problems for Philips 30PF9975 30 in. HDTV
Do you recommend Philips 30PF9975 30 in. HDTV LCD Television?
Answer
Answer
one day working fine , the next day no power getting to the set, checked power outlet. Even tried... (More)
Answer
i have a 30 philips flat screen that was working great then all of the sudden the screen went black... (More)
Answer
I have a 30'' Philips LCD flat screen TV hooked up to a PS3 with an HDMI cable. Whenever I switch to... (More)
Answer
I am going insane..... I have just purchased one of these and I cant get any sound, unfortunately... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Philips 30PF9975 30 in. HDTV...:
Top Flat Panel Television Experts
Rank: Guru Guru
Solutions: 773
Experience: 30 Years of professional repair and design.
Ask Me
Find more Flat Panel Television Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
