Question about Technics SUV500 2-Channel Amplifier
Technics SUV500 Amplifier
When I play my tuner through my speakers everything sounds fine. However when using my turntable, CD player or Auxiliary input I only get sound from the left channel. The sound coming from the right speaker is barely audible.
The amp is nearly 20 years old.
Can anyone suggest what could be wrong please given the inconsistencies?
Many thanks
Dan
    Sniper:
  • 99 Answers
Check for dry solder joints on the inputs.
Technics amps are prone to these after a few years.
Hope this helps.
Posted on Mar 10, 2013
  • 682 Answers
Check volume balance between right and left-then change inter connection between sound source and amplifier with new cabel(i prefer gold plated type connectors)(see radio shack).
after that if the problem excit your fault in output transistors or output stereo ic depend on circuit design.
Posted on Mar 05, 2008
My su-g95 technics Stereo integrated amplifier wont play any noise. and when i adjust the volume it makes a popping/crackling noise. i am 100% sure all the speakers were hooked up correctly.
Well it sounds like your amplifier IC's are working correctly since you are hearing that pop. I have the same amplifier and every 10db increment it pops. Have you tried every input? Possibly try starting at a low volume, plug an RCA plug into CD or any other input, and touch the center prong of the other end of the cable. You should get a 60hz hum if your in the USA, otherwise it will be 50-55hz. Regardless it should make noise.
Sep 29, 2011 | Technics SUV500 2-Channel Amplifier
SURROUND AND CENTER SPEAKERS WORK FINE BUT NO SOUND COMING FROM FRONT SPEAKERS. WHAT COULD BE THE PROBLEM?
Can you fill in something about the speakers and how you have them attached? Since this is a stereo amplifier one wonders how you have anything but the front speakers powered unless you're using THIS amp for just the one pair and driving it from an AV receiver pre-out.
http://www.hifi-pictures.net/amplifiers-home/Technics%20SU-V500/amp.htm
What else is missing from this problem description?
Feb 02, 2011 | Technics SUV500 2-Channel Amplifier
I have a Technics Stereo Receiver SA-GX 500. There is very little sound coming out of all the speakers (A and B) as well as the headphone jack. I have made sure that the speaker button is depressed (A, B...
All sources or just one? Make sure the Tape Monitor isn't engaged unless you're using an external tape deck or processor. A turntable will only work on the PHONO input.
Aug 08, 2010 | Technics SUV500 2-Channel Amplifier
Distorted sound on Technics SL-1200/1210
You could be getting acoustic feedback from the speakers to the TT's. Lower the volume or somehow isolate them from room sounds and vibrations.
Jul 05, 2010 | Technics SL-1200 Turntable
SUV500 2-Channel Amplifier: Hi! can I connect another technics cd-player,sl...
yes you can connect another cd player to the DAT input of your amp.
input connections like DAT, TUNER, CD, AUX etc (except phono) is just to differentiate between what sources are connected, the amp cannot tell what source is connected and will output the sound no problem.
as for the remote operation, if the 2 technics cd players are switched on at the same time they're going to do what you command from the remote together but you'll obviously be listening to 1 at a time.
May 17, 2010 | Technics SUV500 2-Channel Amplifier
Su-v55a technics amp cuts off when volume up to 2
usually meens it is protecting itself from destruction
check your wires and speakers for problems
Feb 09, 2010 | Technics SUV500 2-Channel Amplifier
Technics turntable plays but no sound with Sherwood receiver
The problem is the fact that the new receiver has no phono input. The phono input has an extra stage of amplification built in. Your receiver is working fine. You need to purchase a phono pre-amp. These run around $20. Connect the turntable to the preamp and the presmp output to any line level input on your new receiver and everything will work as expected.
Dan
Apr 12, 2009 | Sherwood RX-4103 Receiver
No Sound When Records are recorded to Computer via the Microphone
use tape1 record out to the Line in jack on your computer. you should then be able to record to .wav, .mp3s etc. with an audio program like Nero.
Dec 22, 2008 | Technics SUV500 2-Channel Amplifier
Technics SU-X955 amplifier. which speakers ?
Helo you have to use speaker of the same wattage you have now chage crossover to get new clear digital soud
Feb 11, 2008 | Technics SUV500 2-Channel Amplifier
Technics SUV500 2-Channel Amplifier Logo
351 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
