Question about Canon PowerShot SD600 Digital Camera
Sticky zoom button
For some reason, ever since New Years (which means I don't remember how it happened), my zoom button on my Canon SD600 has been sticky. It will still zoom, but it takes much more effort, and it will zoom more than I want it to, and I can't get the right amount of zooming because it just sticks. Is there anything I can do to fix this?
  • Anonymous Sep 09, 2008
    yes same here
I put some isopropyl alcohol on a cotton swab and gently cleaned the area around the zoom button, and now it moves freely.
Posted on Feb 18, 2008
I have a Cannon Powershot S5IS and the zoom leveler button (around the shutter button) is sticky. If not used for a long time it will be sticky and will also get sticky if in warm weather outside or in the...
Take your camera to a Canon authorized service center and see if they can try to clean the button area. This might solve your issue. Other than a cleaning they will most likely have to replace the button assembly and/or top cover depending on how the camera is designed.
Hiram
Photo Tech Repair Service
110 East 13th Street
New York, NY 10003
212-673-8400
Jul 05, 2011 | Canon Cameras
I just bought a canon Gl2 camera used on Ebay. I did the routine check, and everything seemed cool. I messed around with the zoom, and noticed that when I zoom in, at about 50 percent, it gets really...
This happens when the internal focus lens is off track, usually caused by impact and can usually be repaired fairly inexpensively. However, it’s not a user serviceable problem and will need to be repaired by a qualified service technician.
My name is Rick and I’m a professional repair technician with over 20 years in the business and have repaired many of these. I’m semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
Sep 14, 2010 | Canon GL2 Mini DV Digital Camcorder
Will my Canon SD600 suport a SDHL flash memory card?
I assume you mean SDHC.
The SD600 was designed to use SD cards. The SDHC specification is backward compatible, meaning that SD cards will work in SDHC devices, SDHC cards will not work in SD devices. This is a hardware incompatibility, not updatable in firmware.
Sorry, but that's just the way it is.
Feb 24, 2010 | Canon PowerShot SD600 Digital Camera
Camera won't power up
You might try cleaning the battery compartment of the camera to make sure that the contacts are not corroded.
Jan 07, 2009 | Canon PowerShot SD600 Digital Camera
Canon MVX250i Zoom
found the solution somewhere else on the net: just leave the camera lying with the batterie taken out for a while and it works again
Jan 01, 2008 | Canon MVX250I Mini DV Digital Camcorder
Canon sd600 lens error
Manually rotating sensor rotor inside camera and cleaning gear fixed the Canon "lens error" for me.
I placed instructions with photo's here: http://www.avh.dds.nl/Fix-Canon-SD600-Lens-Error/
Aug 22, 2007 | Canon PowerShot SD600 Digital Camera
Powers off
e18 is a lens error message, the lens is stuck or bent, and wouldn't come out, that's why camera shuts off after it tries to do so at the start, not much you can do, but replace the whole lens assembly
Aug 21, 2007 | Canon PowerShot SD600 Digital Camera
Canon SD600 Lens error
Press the power button on and hold it down while extending and twisting the telescopic zoom lens. It might fix your problem. In any case it could not make it worse Good luck!
Aug 10, 2007 | Canon IXUS V2 Digital Camera
Can't zoom
To my regret you can't repair it by yourself and it should be repaired in a professional lab. Following the repair cost you should decide, whether it worth it.
May 02, 2007 | Canon PowerShot SD600 Digital Camera
Canon SD600
Hello, You are facing several problems that must be first taken care of. The lens assembly is not sealed ermetically so if beer got into it..that's bad because no service center can dissasemble the lens assembly to clean them. However you should take your chance. First of all the camera needs to be dissasembled. Second, it's main board and buttons must be washed in something called izopropilic alcohol. Then the internal battery and external one must be removed and eventually a firmware update should be done. You may have all of these done in a service center, they aren't that expensive repairs. If after this repairs the pictures will come out blurry or distorded this means that the lens assembly was damaged. I think however that you should try these first. Please go to a service center, try the smaller ones, generic "camera repair service", not the larger ones working for large corporation (they tend to be expensive). Ask them for a cost estimate before actually repairing the camera. For more informations please reply back here. Good luck.
May 01, 2007 | Canon PowerShot SD600 Digital Camera
Canon PowerShot SD600 Digital Camera Logo
323 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
