Question about Sharp XR-10X Multimedia Projector
Not showing entire image on screen
When I view the screen, there is a true right edge of the picture. But on the left edge, there is a shadow line about a foot in the viewing area. you can still see what's suppose to be the true left edge in the shaded area. We changed the type of viewing(front, front ceiling, rear, rear ceiling) but that left edge was still lined by a shadow. Its like there is a piece of tape on the lense.
  • 1 more comment
  • jsingh Feb 18, 2008
    As I stated earlier, turned on my pj today and a quarter of the left side is dark, it looks like something is blocking it. I looked into the lense and did not see anything covering the light and could not tell whether something might have dropped or moved. This shadow border line running vertically is covering at least a 1/4 of the image.
  • jsingh Feb 21, 2008
    nothing I have downloaded really breaks down steps for the actual disassembly and adjustment of the lens component for me. I could attempt to open the projector body but that's where I'm clueless to the next step....
    The projector model is a Sharp XR-10X series DLP Projector. I didn't run it off a computer. I used my dish satillite box to watch the fight this past weekend. I also hooked up my DVD player.
  • Sharp Master
  • 19,396 Answers
The lens may be out of place, I will see if I can find service manual or diagrams to disassemble the projector safely and fix the problem.
Posted on Feb 18, 2008
  • 110 Answers
It's possible that your projector doesn't natively support your display resolution, but to know more it would be best if you could provide the following details:
Projector Model
PC Model
Windows Version
Windows Resolution/Refresh Rate
Display type (if laptop) cloned/extended, etc
There is a line, like a shadow on the right side of the screen all the way up and down. What is that from?
Your TV uses a "Light Tunnel". A part which has various filters to create the proper "color" of light needed to produce the picture. Sometimes, one of these filters slips, causing a shadow to appear in a corner or along an edge. The appearance is this defect is more of a shadow and does not have a sharp, defined edge (like a letterbox image would). You can replace the entire light engine to repair this or just replace the light tunnel. The light tunnel repair is much more difficult... I would recommend a service call, as this is not a simple procedure. I hope this helps.
Mar 17, 2010 | Samsung 61" Slim-Depth DLP HDTV
Model 50UX58K - picture has distortion & shadow on right side of screen
Hi, if the shadow is colored lines then you probably need the convergence ICs and possible reisitors near them replaced .
If the shadows is just like a ghost of the image or a bar from top to bottom, then check if it does it on every input (dvd for example) , there are blanking bars that you can't see past the edges of the picture and when you have a bad cable signal you can see the ghost of the blanking bar sometimes. if it does it does not show the shadow when watching a DVD then its a signal issue with your cable/satelitte .
If your convergence is the issue, try the adjustments first and if that doesn't correct it, you can replace the ICs using kit # x480293 or stk392-110 (2 ICs) soldered in very technical for even a technician.
repairman cost about $250-$350
hope this helps
Sep 01, 2009 | Hitachi 50UX58K 50" Rear Projection...
Has horizontal lines and glare on the screen
I hope camera still able to show saved pictures correctly in playback mode and gives horizontal lines and glare only in camera mode, in live view.
If it is true then your Canon A85 camera got bad ccd imager problem.
Canon will fix it free of cost, click Canon CCD Imager Advisory for details.
Aug 13, 2009 | Canon PowerShot A85 Digital Camera
Exact same problem on 47" Regza: multicolored vertical lines
If you wish to get some details; visit the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Apr 23, 2017 | Toshiba REGZA 47HL167 TV
Hannspree HF229H monitor and Windows XP. Images stretch to fit.
I had this same issue.
Go into the monitors menu, go down to "Image Settings", go to "HDMI Mode", select "PC Mode"
Hope this fixes it for you. It worked for me.
Feb 16, 2009 | Hannspree 22" widescreen LCD Flat Panel HD...
Vertical gray stripe on left edge, all pics and text gave a blur
any vertical or horizontal line (any color any size) showing stable on the screen that is the hardware damage at the LCD panel back board ( call panel driver board) . it repair complicate but easy to do change LCD panel (common parts). you need find a PC service dealer to do so.
Feb 07, 2009 | Dell E207WFP LCD Monitor
Kp-51ws510 red shadow convergence...
you need to replace your convergence ic's STK392-560's they both need replacing I will post a link where you can get the ic's and picture installation instructions as well as free online tech support should take about 45mins to repair if you do it yourself and save you alot of money
Apr 26, 2008 | Sony KP-51WS510 51" Rear Projection...
Sony kp-65wv600 blue arch line on left side
in the menu does it have a convergence menu? try doing that.
Feb 20, 2008 | Sony KP-57WS500 57" Rear Projection...
Can't view entire screen
make sure that you tv is set to the "standard" format and then try changing the aspect ratio on the cable box.
Jan 26, 2008 | Mitsubishi WD-52631 52" Projection HDTV
Sharp XR-10X Multimedia Projector Logo
174 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
