Question about Acer Aspire 5630 Notebook
Display The display flicker and distorts, sometimes only for a second but can last until the notebook is restarted. Possibly connection issue??
  • 58 Answers
Could be connection issue, or driver issue. reinstall the video drvier, if still no go, then reseat the video cable.
Posted on Feb 17, 2008
Colours are distorted, the screen flickers and the cursor lags.
Lap tops require special in/out plugs for connection to tv.Then keyboards keys to select the display function. Check your manual for this info
Apr 14, 2014 | HP Compaq 6735s Notebook
Hi, I started to have an issue with a display of my Tecra M5. The laptop is 2 years old and there has been no problems with it before.. Last week I attached a 32" LG LCD TV to my Tecra as an...
the 32 inch LCD may have a lower display resolution that the LCD on your system. Ensure that the display settings for the LC are at the MAX resolution and 60 htz
Jul 31, 2011 | Toshiba Tecra M5-S433 Notebook
My other computer, G4 Macbook Pro, has a screen issue. When it is turned on and in process of coming up, the screen shows large sections of odd colors such as light pink or light green or light blue. Then...
Connect an external display to the computer. If the lines and distortion shows up on the external display its the video card, which is attached to the logic board. So, the whole logic board will need to be replaced.
If the lines and distortion don't show up on the external display the issue is the LCD module, which will need to be replaced.
Jan 30, 2011 | Apple PowerBook G4 Mac Notebook
Some pixels of a certain color are showing green and flickering on my LCD display. If I plug it into an external monitor its ok. any Ideas?
The issue is with Inverter board of the display for flickering and the pixel issue is with LCD itself.needs to be change
Apr 12, 2010 | Apple MacBook Mac Notebook
ASUS eee701 - Display is flickering in black/white version
If the entire display is flickering, tha'ts typically a hardware issue. Try tilting the screen back and forth, or pressing gently on the area just above the keyboard to see if you can replicate the issue. If it flickers then, you've got a bad cable or a plug.
It's unlikely, but if it is a software issue you can try dowloading new drivers for the video card. Go to the ASUS website, enter in your model information, and see if you can find drivers for the video component.
http://support.asus.com/download/download.aspx?SLanguage=en-us
Hope that helps.
Mar 08, 2010 | ASUS Eee PC 701 Notebook
Fujitsu Siemens Lifebook C1020 laptop display and booting problem
change the ram memory ...this issues appear when the ram memory is not functional like it should..if you have a way to borrow some just to try ..you will make an ideea
If you have more than one boards in the laptop..remove one by one ..and try to boot with the other/s until you locate the one with problem..
Jan 30, 2010 | Fujitsu Siemens LifeBook C1020 Notebook
Laptop malfunctioning
Connect any Desktop monitor to the Laptop and check whether the Display. if the display is fine on the Desktop monitor screen then it can be identified as the Laptop screen malfunctioning.
And if the Display has the same issue that on the Laptop screen
then it can be treated as the Display card issue.
However, it seems to be Harwre related issue. Get the laptop veriufied under Technical supervision to repair the Laptop's display card or the Laptop screen to be replaced if the display is fine on the Externally connectd Monitor.
Aug 04, 2008 | IBM ThinkPad T40 2373 Notebook
Inspiron 8500 - Display issue
with the external monitor attached press <FN><F8> to toggle between internal and external display. if still nothing then it sounds like the video card.
MANUAL
Check all the connections (especially the ground screws) that was a problem with one I worked on last year.
May 29, 2008 | Dell Inspiron 8500 Notebook
Monitor flickering and adjustment buttons locked
If the refresh rate is not properly set the monitor may have a wavy or an appearance that lines are going down ... This may also cause a flickering affect.
Distorted or skewed image on monitor. Issue: Distorted or skewed image on monitor.
Cause: This issue can occur from any of the below possibilities.
  1. Windows issue.
  2. Loose or defective cable.
  3. Refresh rate issue
  4. Interference.
  5. Bad monitor.
Solution: Windows Issue If your monitor has a proper display until it gets into Windows 3.x, Windows 95, Windows 98, Windows NT, Windows 2000, Windows ME, or Windows XP please see document CH000121 for software or setting related issues.
Loose or defective cable You may receive a distorted image when the cable is loose or defective. Disconnect the video cable going from the back of the computer and verify that no pins are bent, burnt or broken. Once verified re-connect the monitor cable.
Refresh rate issue If the refresh rate is not properly set the monitor may have a wavy or an appearance that lines are going down or across the monitor slowly or fast. This may also cause a flickering affect. Additional information about how to change the refresh rate can be found on document CH000558.
Interference A distorted image can be caused by magnetic or other types of interference. Verify no speakers, fans or other magnetic devices are close to the monitor.
Bad Monitor If the above possibilities have been checked it is likely that the monitor is bad. To verify this it is recommended that the monitor be temporarily disconnected and then connected to another computer. This can be a friends computer, a work computer, and/or a computer at a service center. You can also help verify a defective monitor by connecting another monitor to your computer. Note: Connecting your possibly defective monitor to another computer will in no way harm the other computer.
Good Luck/Please dont for get to Rate.Thank You.
Jan 17, 2008 | Samsung SyncMaster 940N Flat panel Monitor
Blank screen
hard drive problems try to restart the computer and press the F8 key in the first 5 seconds this will display the page with some options choose last good know config or save mode if last know good config does not fix it try save mode if you can acces the hard drive you may have re install windows if no acces get new hard drive
Jan 01, 2008 | Acer Aspire 5610-4648 Notebook
Acer Aspire 5630 Notebook Logo
27 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
