Question about Brother HL 1650 Laser Printer
Service call Error E50
How do I reset the fuser unit counter?
  • thesquire Feb 17, 2008
    Hi Goldflack,
    This didn't do the trick, I still keep getting the message that the fuser needs replacing, but this is only because the counter has counted up to the number of times the manufacturers have decided on. If I can reset the counter it should work OK again.
    Thesquire
  • thesquire May 12, 2008
    Problem solved! scrapped the old printer and bought a new Samsung to replace it.
You just think.. lol
Posted on May 12, 2008
    Sergeant:
    Champion:
  • 310 Answers
Just turn of the printer and turn off the system, after a few min turn on both, i thing it will solve or contact me
Posted on Feb 17, 2008
  • khader ibrahim Feb 18, 2008
    Thanks for reply me, i thought it will work.
    When any problem occurs means first we want restart. This is the solution for most of the things.
Ho do I reset my MFC8480DN after replacing the fuser unit?
This is the fuser reset procedure from page 563 of the service manual:
5.1 Resetting the Periodical Maintenance Parts Life
? Resetting the Life Counter of the Fuser Unit
<Function>
This function allows you to reset the page counter of the fuser unit and increase the number
of replacement times by one.
<Operating Procedure>
(1) Press the [3] and [9] keys at the same time in the ready state.
The "Reset Menu" will appear on the LCD.
(2) Press the [ ] button a few times to select "Fuser".
(3) Press the [OK] button.
The "1. Reset / 2. Exit" will appear on the LCD.
(4) Press the [1] key when resetting the life counter of the fuser unit. Press the [2] key if not
resetting.
(5) The "Accepted" will appear on the LCD if pressing the [1] key. The page counter of the
fuser unit is reset, and the number of replacement times is increased by one. Then, the
machine returns to the ready state. If pressing the [2] key, the machine do not reset the
page counter and the "Fuser" will appear on the LCD.
Feb 10, 2015 | Office Equipment & Supplies
E studio 520 code c447
All error code soloution of fuser unit Fuser Unit Error Status Counter
Purpose
When a fuser unit related error (error code C41, C43, C44 or C45) occurs, the set value of the fuser status
counter varies, depending on type of error.
Displaying and checking the set value of the fuser status counter can analyze a cause for the error. If
any of "2 to 9" is set at the fuser status counter, the fuser unit will not be operated for safety reasons.
After the fuser unit related error is resolved, if "0" is set, the fuser unit will be operated as usual. If any of
"10 to 19" is set at the fuser status counter, the fuser unit will be operated as usual, even if "0" is not set
after the fuser unit related error is resolved.
C41: Thermistor or heater abnormality at power-ON
C43: Thermistor abnormality after abnormality judgment
C44: Heater abnormality after abnormality judgment
C45: Thermistor abnormality during printing
C46 to C49: Reserved
Description
When this code is used, the current set value of the fuser status counter is displayed. Only "0" can be
manually entered, in order to restore the fuser unit to its normal operation, after the fuser unit related
error is resolved.
For further reason why the counter value differs despite the same error code, refer to 5.1.7 or 5.1.8
[Fuser unit related service call] in the Service Handbook.
0: No error 10: C47 (Reserved)
1: C41 (Once) 11: C47 (Reserved)
2: C41 (Consecutively occurs) 12: C48 (Reserved)
3: C46 (Reserved) 13: C49 (Reserved)
4: C43 14: C47 (Reserved)
5: C44 15: C48 (Reserved)
6: C45 16: C49 (Reserved)
7: C44 17: C47 (Reserved)
8: C45 18: C48 (Reserved)
9: C44 19: C49 (Reserved)
* Default: 0
Setting Timing
Use this code to resolve the fuser unit related error (error code C41, C43, C44 or C45). Resolve the
error, and set "0" (or reset the counter), in order to restore the fuser unit to its normal operation.
Caution
Remember to resolve the fuser unit related error, and then reset to "0." also 447
Jan 17, 2014 | Toshiba Office Equipment & Supplies
Error code c43
Purpose
Description
error is resolved.
* Default: 0
Setting Timing
Caution
Jan 14, 2014 | Toshiba Office Equipment & Supplies
Call for service C 430
Purpose
Description
error is resolved.
* Default: 0
Setting Timing
Caution
Dec 31, 2013 | Toshiba estudio 255 Copier
Ihave konica minolta bizhub 43 i replaced anew fuser unit but its still showing consumable error replace fuser unit how can i solve this
Enter in the service mode: press Utility key-Metercount-(Details if exist)-Stop -0 0 -Stop -0 1 select a special parts life or in the counter mode consumable and reset the fusing unit counter.
Feb 04, 2013 | Konica Minolta Office Equipment & Supplies
TOSHIBA E STUDIO 207 ERROR C 44
Purpose
Description
error is resolved.
* Default: 0
Setting Timing
Caution
Jul 08, 2012 | Toshiba E Studio 207
KYOCERA ECOSYS FS-1118 ERROR-C-6400
Error code relates to the fuser unit.Suggest that it is replaced.
Nov 16, 2011 | Kyocera FS-1118MFP Laser Printer
E50 error on Brother HL6050DN. Page count was
Hi
Error E50 comes up on the printer when there is an issue with the fuser unit of the printer. It is either the fuser unit is faulty or fuser unit is not clean. This what you can do to get the error fixed--
All "left" and "rights" are when facing the front of the printer. Remove the electrical cord from the back of copier by pulling. Remove bottom tray. Remove the smaller tray that comes out the back that has a LTR/A4 lever. Open front of machine to take out toner and drum just to make it lighter. Leave open. Take off top cover (4 screws and two wire jacks to unplug). Remove screw on back right side near bottom. Remove screw on front left near bottom that holds left side cover. Remove screw on back left near bottom (it holds a piece in the back and the side cover). Slightly pull out that back, left plastic piece (it won't come out all the way yet) and wiggle things around to get the left side cover off. That back left piece that didn't come out all the way has a plastic *** holding it in. To be able to press that *** is why the side cover is removed. Press *** and pull the back left piece out while wiggling things around to get the 3 plastic pieces in the back to all come out. This exposes the fuser. Remove the two wire jack connections. Remove the two screws holding fuser in. One of those screws is big with a spring - don't worry, the spring stays in place. The other screw looks normal, but it is a little longer than the other screws so remember where you lay it. Find the 2 black wires on the fuser leading to the problem piece. Remove the single screw holding it in. Pull it out and clean the wire connections. Now put things back together.
And after this is done reset the printer by--
Switch the machine on. Wait until the yellow data light goes out. Now hold down the 'GO' button AND the '+' button together four about four seconds. The LCD panel will now display a 'RESET COMPONENT LIFE' message. Use the + and - keys to select the fuser unit, and reset it. Turn the printer off. Turn it on again and it will work. Now reset the drum counter , and also the toner cartridge counter in the same way.
Please accept the solution and revert for further assistance.
Thanks
Rylee
Jul 07, 2009 | Brother HL-2040 Laser Printer
Turning it on it displays ERROR E50.please help
You have a fuser malfunction, replace the fuser unit.
Mar 06, 2009 | Brother HL 5250DN Laser Printer
Error message C4551 anyone? pretty please.
C3451: Heat. Heater Trouble
You have to check machine fuser unit .
May be paper on the fuser unit. Check fuser unit rollers.
After check fuser unit you have to ececute a "trouble reset".
Turn on your machine by press and hold "utility counter" botton, after some seconds press to display "TROUBLE RESET" and turn off and on machine.
C4551: Cyan laser Malfunction
Check cyan laser connection and execute trouble reset.
Bye.
Oct 03, 2007 | Konica Minolta bizhub 250 All-In-One Laser...
Brother HL 1650 Laser Printer Logo
475 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
