Question about Samsung PCL5415RB 54" Rear Projection Television
Samsung PCL542R Chirping noise
My Samsung projection TV has started making a high-pitched chirping noise when I plug it in. No television display or audio.
Anyone experience same problem? Have a solution?
  • rudysalas Feb 17, 2008
    What's the best way to do that?
    Sergeant:
  • 395 Answers
The high pitch chirping noise is coming from the power supply. there is a short circuit with the switch mode power supply. check the HOT(horizontal output transistor) first then the power supply for shorts. on the HOT check for short between base to collector, and emitter to collector. base to emitter will show short because it in line with the primary coil of the fly-back transformer.
if you are unfamiliar TV repair have a tech repair this for you.
Posted on Feb 17, 2008
    Sergeant:
    Champion:
  • 310 Answers
There is problem in sound IC. First check it
  • khader ibrahim Feb 18, 2008
    I thought the problem is in sound side.
CHIRPING SAMSUNG PROJECTION TV
Chirping is set is in shutdown---most likely in High voltage area of set.
Jun 11, 2012 | Samsung Televison & Video
Blinking green light in front, high pitched chirping noise, no picture.
u may have a high voltage problem , 1 may be the flyback transformer , or may be u vertical circuit , need to take it to do tv shop for service
May 08, 2009 | Televison & Video
52 in. rca high def. rear proj. making high pitch noise
the set probably has lots of bad solder connection on the flyback and in the horizontal deflection circuit.
Feb 24, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
NO PIC & NO SOUND ONLY HI PITCH SOUND SURGE FROM BACK
Goto the site www.TvRepairKits.com and get their "chirping" TV repair kit. It will fix the problem of the dead set with high pitch sound or chirping sound.
Jan 01, 2009 | Philips 43PP9202 43" Rear Projection...
On off button blinking.
If your set is making a high pitch sound or chirping sound you can get a repair kit from www.TvRepairKits.com.
It will fix the no audio + no video + set makes chirping or high pitch sound.
Dec 27, 2008 | Philips 43PP9202 43" Rear Projection...
No picture or sound - TV makes chirping noise
The chirping sound is the power supply coming up then breaking down because there is a short somwhere in the high voltage. The most common fail in this area is the horizontal output is shorted ( 237470 ) but what cause this short could be simple cold solder joints or the High voltage transformer ( 239111 ) If you have noway to "ring" the flyback change both parts
Feb 13, 2008 | RCA Scenium D40W20 40" Rear Projection...
No picture on screen, chirping noise every second from back
again a good set the deflection modules on these sets are pretty reasonable you need to have a tech swap it but i highly suggest that than a new one the chirping is the set trying to start up but going into shut down
Dec 02, 2007 | Samsung HC-P5241W 52" Rear Projection...
No power just a chirping noise.
Chirping means the power supply is being loaded down by a short in most cases, likely a bad convergance IC
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Oct 21, 2007 | Philips 60PP9352 60" Rear Projection...
Samsung PCL5415RC Chirping noise
power supply discharging.even after the set is unpluged.
Sep 13, 2007 | Samsung PCL5415RB 54" Rear Projection...
Rich that chirpin noise is somthing over loding it try checking your horzotal output for short and diodes around the transformer...
May 20, 2007 | RCA P60921 60" Rear Projection Television
Samsung PCL5415RB 54" Rear Projection Television Logo
204 people viewed this question
Henry  Thomas
Henry Thomas
