Question about Epson DFX-8500 Matrix Printer
EPSON DFX 8500 ERROR CODE E5 THEN POWERS OFF
HELP I HAVE A EPSON DFX 8500
WHEN I POWER ON THE PRINTER THE PRINTER CARRIAGE SLAMS TO LEFT SIDE THEN DISPLAYS AN E5 ERROR CODE
IS THE PRINTHEAD RESPONSIBLE FOR THIS PROBLEM?
ALSO THE FAN ON THE PRINTHEAD WIIL NOT GO ON.
HELP
PETER MARTINS
  • peter martins
    peter martins Feb 18, 2008
    thanks so so much great help
    i will look at the fan i did notice that the fan on the printhead was not working.
    you think that my be the problem?
    AGAIN THANK YOU SO MUCH YOU SAVED MY NECK
    Scholar:
  • 84 Answers
It would sound like a defective encoder sensor, almost ANY copy repair shop can fix this for you, you can try to buy the manual and fix it your self but that is NOT recommended
Posted on Feb 18, 2008
  • Epson Master
  • 19,396 Answers
Error E0005 in your printer means fan motor error. Your printer is overheating and then turning itself off because the motor is faulty the other problemd (printer turning off slmming etc.) are consequence of this.
  • 1 more comment
  • Ginko
    Ginko Feb 18, 2008
    E5 says your main problem is motor fan. Then first check that all contacts for fan motor are ok, if they are you may need to replace the part. In addition here is list of error codes:
    Display
    Meaning
    C0001
    CPU error (reserved)
    C0002
    CPU error (programming command error)
    C0003
    CPU error (illegal instruction)
    C0004
    CPU error (unsupported FPU instruction)
    C0007
    CPU error (address misalignment)
    C0009
    C0010
    CPU error (tag overflow)
    C0017 to 31
    CPU error (unsupported interrupt)
    C0036
    CPU error (unsupported coprocessor instruction)
    C0128 to 254
    CPU error (unimplemented instruction)
    C0255
    CPU error (break error)
    Axxxx
    Software error
    Bxxxx
    Software error
    Dxxxx
    Software error
    Fxxxx to Zxxxx
    Software error
    Display
    Meaning
    E0003
    Fusing unit error
    E0005
    Fan motor error
    E0006
    Scanner mirror motor error
    E0009
    Laser light error
    E0014
    Communication error for engine controller and video controller
    C1200
    EEPROM write error
    C1400
    Engine initialize error
    and user manual
    http://www.epson.ru/resources/massmedia/...
    cheers
  • Ginko
    Ginko Feb 18, 2008
    let me know
  • Ginko
    Ginko Feb 20, 2008
    Hi, I hope this helps in solving your problem. If you find that one of our solution had been helpful, then please rate the helpful solution.
    Many thanks
    Ginko
    Brigadier General:
  • 3,614 Answers
HI, you got a mechanical error on your printer this is because it got a paper jam problem and that may result that your printhead slams. Try to look if there's something in your printer that preventing the gear inside to move. If so re install again the driver software of your printer.
I have a problem on my printer epson dfx 9000 with erro code 01 turn off your priner any one with solution? Please?
the encoder strip under head carriage may dusty , power off, clean it with a tissue and try again
good luck.
Apr 16, 2014 | Epson DFX-9000 Matrix Printer
E 4
Hello Scott148,
Basically an "E4" Error Code means that the Carriage Assembly is locked, or stopped during operation. There is no Home Position Sensor for the carriage assembly. The Home Position is detected using the Carriage Encoder Sensorand Timing Belt, as the Printhead Assembly hits the rubber bumper on the left side of the carriage assembly. If blowing out the sensors has no effect, then the most common problem with an "E4" service condition on a "DFX-8500", is a bad/failing REAR COVER INTERLOCK SWITCH. After that, its usually a failing/bad Carriage Motor. The interlock switch is basically the safety shut-off switch for the Top Cover, located on the back left side of the printer, from the front. A metal arm/protrusion on the top cover, pushes in on the switchs lever when it closes. If the switch is going bad, then it cannot always tell that the top cover is closed. That switch shuts down the Carriage Assembly operation for safety reasons, when the top cover is opened. You can remove the wires connected to the switch and jump them with a paperclip, to bypass the switch for testing purposes only. Once bypassed, if the "E4" Code is gone, then you know that you need a new switch. If the "E4" is still there, then its of course possible that the Carriage Motor that drives the timing belt and printhead assembly is also going bad, but there's no easy way to test it, like a failing switch. At least you can eliminate the switch first as a possible problem...TECH NOTE: On any FATAL ERROR service error, if the printer is not shut off with-in 12 seconds, the power automatically shuts off for a minimum of 5 minutes. If you try to turn on the power at 4.5 seconds, it will just add another 5 minutes to the counter
May 26, 2010 | Office Equipment & Supplies
Reset Epson DFX-8500 Matrix Printer
Remove power cord for at least 10 seconds AND delete print job manually from Windows(?) Open Control Panel>Admin Tools> Services. Stop print spooler service. Delete contents of c:\windows\system32\spool\printers folder, restart print spooler service, plug printer back in.
Aug 14, 2009 | Epson DFX-8500 Matrix Printer
Error 4and 3
epson dfx 8500 error coad 4and 3 the power supply was dead .
Apr 29, 2009 | Epson DFX-8500 Matrix Printer
Epson R320 carriage jammed
The ink cartridge is probably not inserted correctly.  Unplug the printer and manually move the carriage to a location where you can take the ink cartridge out.
Remove it and reinsert it, making sure that it is fully located, before applying the power.
Make sure that there is nothing blocking the carriage movement, such as some remnant of paper.
Oct 21, 2008 | Epson Stylus Photo R220 InkJet Printer
E4 Error It blinks all led flashing E 4 after making a jam noise, then turns off after a while
It seems your printer,s carriage is jam or carriage encorder is out of carriage sensor
Oct 15, 2008 | Epson DFX-8500 Matrix Printer
Error e5
E-5 error on dfx --carriage load measurement, you will need a servicer.
Feb 18, 2008 | Epson DFX-8500 Matrix Printer
Epson DFX-8500 Matrix Printer Logo
700 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
