Question about Saeco Incanto Classic Espresso Machine
The brew unit cannot be removed
I have a Incanto Cappuccino. How can I resolve this problem? After descaling the machine the unit has stopped in the wrong position and the macihe does not turn on.
I had the same problem. I apparently turned it off mid-cycle. The upper-left portion of the brew group stopped higher than it should have. I had to force the brew group out, breaking a small plastic cover in the process. I don't think that part's too important. Then I observed the orientation of the gears and visualized what orientation they needed to be in to re-install the brew group. I pressed all the sensors to trick the machine into thinking the brew group was installed and started the brew process. I released the sensors once the gears were in the necessary orientation. I re-installed the brew group and was back in buisiness.
Posted on Jul 10, 2008
  • 515 Answers
If you had this problem, just turn the machine off and then on again, the machine will do the selftest and go back to start position. If the machine is dead, then the thermal gone off. Go can reset it by take off the back plane and find the elemet, some models have two thermals, in the centrum off the termal is a reset pin.
  • 40 Answers
Have you had the problem fixed? Is the brew group unit blocked ( is that what you mean by wrong position?)
Posted on Jun 20, 2008
I have a Royal Cuppucino from Saeco makes a loud clapping sound sometimes not always.What is the problem?
If the sound you describe is from vibrating pump then you should try to descale the machine and this will help to reduce and posibly to remove to problem completly. You can try performing the descale also in one week after.
Jun 01, 2012 | Saeco Royal Cappuccino Espresso Machine
I have a Saeco Incanto Classic. There is hardly any water coming through the coffee dispenser even if I only use the preground doser without inserting coffee. While the little water comes out it makes a...
Sounds like the the shower screen under the red o-ring in the brew group needs to be cleaned, you can remove the screen and clean or you can purchase some espresso machine soap puro caff or puly caff, and run it through the brew group using the preground method the clean out coffee oils.
Aug 26, 2011 | Saeco Incanto Classic Espresso Machine
I have a Saeo Incanto Tondo S Class coffee maker. It grinds coffe bean but coffe is not coming out. There is no water in dregs but only grined coffe powder. I can get steam and hot water and I do not find...
Hello Saaddition,
I understand that your coffee maker is not producing coffee. However, it is operating normal in all other respects. This is usually a common problem when the machine needs to be descaled. You may also need to clean the brew unit. Here is the link to the manual for you Saeco Incanto Rondo C class coffee machine it give you all of the directions to clean and descale.
One other question did you remove the dregs drawer with the machine off. If you did you will need to do cleaning to reset the machine as removing the dregs drawer with the machine off will not allow it to brew coffee.
Thank you for choosing
May 08, 2011 | Saeco Incanto Rondo Fully Automatic Coffee...
English manual for a saeco sup 021 - decalcifying
You can download it from this link:[1].pdf
Nov 14, 2009 | Saeco Incanto Classic Espresso Machine
SAECO Incanto Type Sup021 grinds and jettison grounds - no coffee
Here's how to fix your problem, remove the brew unit and clean the shower screen located at the top, under the red o-ring. Remove the screen and clean, then try coffee again this time adjust grind about 2 numbers coarser.
Jul 30, 2009 | Saeco Incanto Classic Espresso Machine
SAECO Incanto Sirius Brew Group
When you remove brew unit look on the back you will notice a small latch near the top, make sure it is in the up position.
Feb 03, 2009 | Saeco 00034 Incanto Sirius Super Automatic...
Water hissing at back of brew unit after coffee made
I think you have to replace the steam valve.
Have you descale your machine regulary?
How old is your machine?
Maybe your boiler have to be replaced:-(
Jul 25, 2008 | Saeco Incanto Classic Espresso Machine
Saeco Incanto Classic Espresso Machine Logo
374 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
