Cuisinart TOB-175 1500 Watts Toaster Oven with Convection Cooking Logo
Posted on Jan 29, 2010
Door spring broke on Cruisinart CTO 350 series Toaster Oven
Purchased about 3 years ago, similar to TOB 175 - Door spring just broke. Cuisinart say they don't have part for this. Can the oven door be fixed. Cannot find a diagram of interior.
  • Anonymous Jul 27, 2013
    I have the mod # BOV800XL can't completly take the cover off it seems to still be connected somewhere.I guess I'm going to bite the bullet and pay $75.00 for a ten cent spring!! Any help out there?
    It's a breville unit
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Nov 10, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
836
Points
I had same problem with my cuisinar 350 series broken door spring. After disassembly found a broken extension spring measuring about 3/16 dia.,by 6.5 inches long.Spring was broken about a third down. I lifted ,or bended a loop and a halve up from each broken section and joined the two sections together. lifting each loop of the spring is tricky at first, requires a small screwdriver to be inserted between loop to be lifted and then gently bent the loop with needlenose pliers.
Not knowing how to disassemble the unit I had a hard time assembling the unit back.
I would start by taking off the screws holding the front black backlite first, then the main cover.
The main stainless steel cover does not have to be removed completely, by just gently unbending
the cover I was able to access the spring for removal.
Lots of luck
How can I get a copy of instructions for Cuisnart convection oven TOB 165?
Cuisinart has the manual for the TOB-165 on the Product page; it's a discontinued model. See https://www.cuisinart.com/discontinued/toaster_ovens/tob-165.html . The direct link to the instruction book is https://www.cuisinart.com/share/pdf/manuals/tob-165.pdf . (Note: you will need Adobe Reader or a similar program to read or print the manual.)
I hope this helps.
Leg on left side (facing oven) broke in half and will not accept glue repair
Same thing jus happened to me tonight. Already had the thing repaired because it wouldn't turn on. Booo Cuisinart!
3helpful
The handle came off the glass door. It looks as if glue was used to secure it. How should I reattach it? What kind of glue works for a glass door on a toaster oven?
Sorry to read about your problem, I hope this helps you out.
get goop glue from home depot
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
1 Thumb - Not Helpful
I have a new toaster oven and the clock won't set properly
I would call Cuisinart - this one has a 3-year warranty, and all they would need is a serial number, not the receipt. Do any of the lights turn on? When you pressed clock, did you hold in the hours button?
-Tha Mp3 Doctor
Cuisinart TOB-175
It is roughly 17 inches across from left handle to right handle, but slightly less. About 15.25 inches from front to back.
-Tha Mp3 Doctor
1helpful
CUISINART TOB 175 CONVECTION OVEN MANUAL
Cuisinart has the manual on their website:
http://www.cuisinart.com/manuals/index.php?cat_id=15
Scroll down to the link for the TOB-175.
Lower heating eliments don't heat or glow. Only top ones work
The elements are not orderable, but you can call Cuisinart with your serial number - the product has a 3-year warranty, and that is definitely a defect - will they glow if you put them on Toaster setting?
-Tha Mp3 Doctor
Toaster oven power failure
Call Cuisinart - that product has a 3-year warranty.
Top Cuisinart Toaster Ovens Experts
vince
ADMIN Andrew
ADMIN Andrew
Kardoc
Are you a Cuisinart Toaster Oven Expert? Answer questions, earn points and help others
