Question about Microwave Ovens
Insructions How much space must be left open on sides and top of microwave oven when building oven into cupboard above a convection oven?
  • bokka Feb 18, 2008
    dear sclieu,
    the manual says at least 20cm on top, 10cm at the rear and the height of cupboard more than 85cm. I just bought
    the lg SolarDom light wave as you know the all in 1 microwave, but now I don,t want to use it incase where it's standing now,in the previous m/oven place, the all round space might not be sufficient for this kind.We are building a new house and I'm
    just playing around with the new oven, but I need the correct dimensions. Hope you can help me, thanks, Bokka
    Problem Solver:
  • 16 Answers
Looking at mine, it fits in pretty snug. Not much space needed on the sides and the top is bolted into the cupboard. This may help a bit but you may want to look at the install instructions for your specific model:
http://www.onwisconsin.com/homes/remodel/oct04/270397.asp
Posted on Feb 17, 2008
How do i take the old GE Spacemaker XL 1330 out
two screws in the floor of the cabinet/space above it ?
Nov 30, 2015 | GE Profile Spacemaker Over-the-Range...
Is the sharp above range microwave model r-1871t recirculating?
According to the Sharp product site, http://www.sharpusa.com/ForHome/HomeAppliances/Microwaves/Models/R1871.aspx , the R-1871 is a convection and microwave oven. The manual describes using the convection oven feature on page 18 (page 20 of the PDF). The direct link to the manual is: http://files.sharpusa.com/Downloads/ForHome/HomeAppliances/MicrowaveOvens/Manuals/mic_man_R1872.pdf . The convection button is on the top left in the middle group of buttons. You use the numeric power level buttons to set the oven temperature. When you program convection cooking, the 1 button will bring the oven to 100 degrees F. The 6 button gets the oven to 350 degrees F.
I hope this helps.
Sep 18, 2015 | Sharp Microwave Ovens
Installing a microwave / convection oven above a stovetop
Needs to be properly vented to outside the house. Only install a microwave that's designed for over-stove use in this space.
Aug 25, 2014 | Microwave Ovens
My GE microwave convection oven JVM1790SK 01. It has started to make a load grinding noise, and is sparking above the cavity area, otherwise it operated properly. When I remove the fan assembly part...
The fan is for air circulation regulation, e.g. preventing steam (and smoke) from building up inside, and also stops air pressure from building up inside so you won't get a blast of steam coming out or worse. On the convection side it heats the food faster and more evenly. You will need to replace the fan assembly to keep the microwave safe. the noise and sparks are probably due to spent bearings and / or a dislodged fan scraping against another surface or something getting in the way of the fan
Nov 30, 2017 | GE JVM1790 Convection / Microwave Oven
Oven won't shut off
One of the door switches is defective, caused by a build up of food particles or normal ware, to correct this a professional will need to identify the problem and replace it.
Mar 07, 2012 | GE Advantium 120 Convection/Microwave Oven
Trying to remove 1874 Microwave from 05 Dynasty. Mounted in slideout
Dynasty, There 2 long bolts toward the front floor of your overhead cupboard, could be under false floor of same. The lower underside will possibly be secured to mounting plate at back. Be sure to remove these screws otherwise you may bend your mounting plate.
Feb 15, 2012 | Sharp R-1874 Convection/Microwave Oven
Opening mmv5165ba to clean filters
Unless your Microwave is older, you have a problem. The newer electronic ovens require a lot of ventilation to keep their circuits from overheating. Further, I know of no microwave recipes that produce grease. You may want to get back to me on this.
Ray
Nov 15, 2008 | Maytag MMV1153A Microwave Oven
Microwave oven
no sir we cant, if that's the requirements for the microwave to run with out trouble, then that's what you have to follow. if you dont, it might overheat because of poor ventilation.
Feb 20, 2008 | Microwave Ovens
Interior Light
The interior oven light can be accessed in the following way:
1.Open door and remove the top grill via the 2 screws along the top edge.
2. In the interior light will be under metal plate with fasten by single screw. The halogen bulb is rated at 120V 20watt. Looks like a G-8 bulb with 8mm pin spacing with o.a.l. 1-5/8" long
Get these bulbs cheap at http://www.1000bulbs.com/120-130-Volt-G8-Base-Halogen-Light-Bulbs/
Jan 01, 2008 | GE JVM1790 1000 Watts Convection /...
Microwave Ovens Logo
194 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Marvin
Marvin
Are you a Microwave Oven Expert? Answer questions, earn points and help others
