Question about GE WPRB9110WH Top Load Washer
GE Washer Our washer is only 2 years old. It has in intermittent problem. We can do 2 - 4 loads with out an issue or sometime more, then it just quits towards the end of the cycle and wont drain. Sometimes if we wait a few hours or a day it will then work for a while again. We have had a repairman out 4 times. Twice to look at it and say nothing is wrong. Once he replaced the motor and last week he replaced the control card. This week, same problem. Any ideas?
  • 958 Answers
Have they checked the door lid switch?..it could be intermittent also because if the switch is not close, it would not drain and spin anymore. try to bypass the switch temporarily by shorting it out then use it . becarefull because you can now open the door while it is spinning ad it is very dangerous.
Posted on Feb 19, 2008
We have a 2-year old GE washer WBVH5200J3WW brought from HomeDepot. It leaks water from the bottom. Any suggestions are appreciated.
Just started having the same issue (ours will be 2 yrs old next month) we are thinking its the rubber seal tube around the front that is worn out....
Jan 16, 2011 | General Electric WBVH5200J Front Load...
The GE Profile Harmony will not drain. It trys, but makes quite a rumbling noise.
Not an expert, but we had the same issue.....until our pump died completely. Limped along for a few years by unplugging the washer, and waiting about 20 minutes....then pump would work for awhile.
Now, our pump has died. With this quality issue, we are debating.....new pump, or new washer? Definitely will NOT buy a GE if we go that route! Good luck, it seems a LOT of people are experiencing this issue. GE should issue a recall!
Jun 18, 2010 | GE WPGT9360EPL Top Load Washer
How old is my washer? When were these made?
You need a serial number to tell for sure.
They probably stopped making those a few years ago.
And the oldest one I've seen it about 10 years old. So probably between 2-10 years old.
GE washer repair in orange county, ca
appliance repair orange county, ca
Feb 07, 2010 | GE WJSE4150B Top Load Washer
GE adora WHDRE526EWW when started it begins to fill then stops filling and have to restart sometimes three to four times help!!!.
I wish I had a solution, I have the same issue. My WHDRE526EWW Top Load washer stops intermittently sometimes while filling up, sometimes while rinsing, sometimes while washing and sometimes while spinning. I just have to guess when it's going to stop and check on each load frequently to restart it when it stops. Sometimes I can't even get it to start spinning again and I will have to unplug it and plug it back in and then it will spin. Hope someone can help!
Jan 05, 2010 | General Electric WHDRE526EWW Top Load...
Makes horrible noise during spin cycle only
The bearings have most likely gone bad. This is a very common problem with the front load washer when powder soap is used.
Jan 28, 2009 | GE WBVH6240F Front Load Washer
GE model WCVH6800JMS front load washer spin cycle
My washer is 1 1/2 years old and I have the same problem.
Nov 11, 2008 | GE WBVH6240F Front Load Washer
Water leaking when when washer is running a large or super load
the leak could be coming from anywhere in the washer it just leaks out from the lowest point of the washer i would suggest placing a putty knife under the top on the right and left side and pushing the tabs in to pop off the front panel to see where the leak is coming from
Oct 30, 2007 | Kenmore 24872 Top Load Washer
My GE WDSR2080G makes a metallic rubbing noise during agitation
Take front off and watch while it agitating useing a good light and see if you can tell where the noise is coming from 52c26ee.jpg
Oct 21, 2007 | GE WDSR2080D Top Load Washer
Noise during spin cycles
GE WPXH214ACC Washer drum makes loud noise when spinning sometimes. We've had it since 2005 & never had this happen before. Washer is level, must stop & redistribute clothes to correct. Just started happening now.
Oct 12, 2007 | Washing Machines
GE WPRB9110WH Top Load Washer Logo
114 people viewed this question
Top GE Washing Machines Experts
Tim Whalen
Marvin
Marvin
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
