Question about Garmin eTrex Vista GPS Receiver
Cannot load maps onto micro SD card.
I cannot seem to load maps onto the Micro SD card. Can you load mapsource maps from PC directly to micro SD card in GPS unit? My PC recognizes that there is something in the drive but shows no space used and no space free. What am I doing wrong?
  • Anonymous Feb 21, 2008
    I get sucess to insert the maps, extension img, but i do not get success to look theses ones.
  • samico111 Mar 31, 2008
    I tried to copy my SD Topos so that if I lost one I would have a replacement. I copied the files from the SD Card to the Hard drive on my PC and then rewrote the files to a new SD card. The GPS would not recognize the maps on the SD Card. Has anyone else tried to make a spare SD card? If so how did it work and how did you accomplish it.
  • 4 Answers
Yust go to www.mapwel.biz/down.htm get software MapUpload and now you can upload any map to micro sd card without loosing your existing map.
Posted on Aug 24, 2008
My micro sd card says write protected. can not load  any maps. have done so in the past 2gig micro sd.
Posted on Oct 04, 2008
Nuvi2555LMT
The micro SD card has to be between 4-8gb. Garmin Express is used to load the South American maps. Garmin Express can be downloaded from Garmin. Once installed on your PC, plug your GPS into your PC. The program should give you the option to install the South American maps to the SD card.
Dec 31, 2016 | Garmin nuvi2555lmt nuvi 2555lmt
No detailed maps found that support routing.need to download software on to micro sd card for garmin nuvi 205
The solution to the "No detailed maps that support routing" problem can be found at http://www.fixya.com/support/r6197735-no_detailed_maps_found_support_routing
To set up a map on the micro SD card you can follow the instructions on http://www.fixya.com/support/r5628920-update_garmin_satnav_maps Don't download directly to the micro SD card as it won't be recognised by your satnav. Download to the computer and install from the computer to the card as described at the above link.
Apr 11, 2011 | Garmin nuvi 205W GPS Receiver
My nuvi 3760T does not have enough space to load europe map. Can I remove preloaded north america map and reload at a later date without losing it?
If you have the map downloaded from the garmin website to your computer you could remove it and replace it later. However a better option might be to download the map of Europe to your computer and install it to a micro SD card. A 4 Gb card would hold the map of Europe and you don't risk losing your North America map. You can get details of how to set up the map on your micro SD card at http://www.fixya.com/support/r5628920-update_garmin_satnav_maps
While this link is mainly about how to update your maps it has a section on setting up maps on an SD/Micro SD card also.
Mar 26, 2011 | Garmin GPS
When i open my memory card in my file manager a MSDC write sector error appear. What Shall I Do
Garmin maps on SD card are not intended to be useful outside the GPS. You can't download the data to use elsewhere, use it in Mapsource, etc. Only in the GPS.
This is why it is common to buy the DVD version and install the mapset on your own SD card.
I believe this is the root of the problem. If you believe the card itself is defective give Garmin a call/email and they will replace it. It is not likely the case, though, based on my experience helping people with Garmin SD problems.
Jul 19, 2010 | Garmin China NT 2008 City Navigator SD...
My young son has wiped some of the games off my daughters ds.they were on an R4 card.they dony come up on the main screen but do seem to be somewhere on the cards memory.anyway of bringing them back?
best take the micro sd card out of the adaptor put into your pc then transfer the games to your pc then delete from the micro sd then transfer back onto the micro sd from the pc that should do it
Jan 08, 2010 | Nintendo DS Console
Unit will not recognize micro sd card with map on it.
your new micro SD card may be too big (in MB). I have the same probem with my camera.
May 31, 2009 | Garmin GPSMAP 60CSx GPS
Vista HCX Micro SD Problem
Vista only recognize gmapsupp.img files.Go to www.mapwel.biz/down.htm take MapUpload software then from mapsource select maps you want to transfer to sd card.Or directly from Mapsource select Transfer and send selected map to sd card.Maps must be unlocked.
Aug 19, 2008 | Garmin eTrex Vista GPS Receiver
Garmin Streetpilot i3 GPS cannot load map to memory card
The Garmin C340 comes preloaded with maps while the I3 require that the maps be installed onto a micro sd card.
You can place the micro SD card into a SD adapter and use a regular card reader to download your maps. When the software ask for 'Device' to download to use the drop down arrow and find your drive letter associated with the card reader. Using a card reader will be much faster since the it is ubs 2.0 vs ubs 1.1
You could also go to Garmin website and download and install the USB drivers, see link below.
http://www8.garmin.com/support/agree.jsp?id=591
Dec 27, 2007 | Garmin StreetPilot c340 GPS Receiver
General confusion with plethora of maps etc
If you have a copy of mapsource read the help file
"Transferring and saving mapsource data"
if the data will not on your (micro)SD card use a bigger one
Dec 25, 2007 | Garmin GPSMAP 60CSx GPS Receiver
Garmin i2/i3
Either you have a bad micro SD card or you are loading more data than the card can hold.
You will need slightly less than 2GB of memory load load USA and Canada all together at the same time.
You can also try buying an external card reader and instead of loading to the garmin load the map data onto the micro SD card from the reader.
Dec 03, 2007 | Garmin StreetPilot c340 GPS Receiver
Garmin eTrex Vista GPS Receiver Logo
1,353 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Steve
Will Halftowaite
Are you a Garmin GPS Expert? Answer questions, earn points and help others
