Question about Black & Decker TCM700 Coffee Maker
Coffee maker sputters like it's done but it's not -takes long time to brew, if it will
Now have this B&D coffee maker but had the same problem with other brands. One out of every 5 or 6 times it works fine, but the rest of the time it will start, then after a cup or so it will sputter like it is finishing up, but it isn't. It will sputter along for 20 minutes or so and finally finish the 8 cups of water.
If I "plunge" the intake hole with my finger it will push the water through for a little bit, then go back to sputtering.
I can't find my receipt so I'm stuck with this and would like get it working.
Help would be appreciated.
  • SammieLinn Nov 19, 2008
    B&D (Applica) advised to run a solution of 4 cups white vinegar diluted up to the 6 cup mark with water. Followed by a rinse. Did that, still the water reservoir won't completely empty. It starts sputtering when it hits the 2 cup mark, followed by steaming, then finishes - leaving water in the reservoir.
espressodoc
  • 29 Answers
SOURCE: Hardly any brewed coffee comes out and will not stop ventilatng!!!!
If you run water through the wand and the ventilate does not clear then there is a problem with the flow meter. Possible a piece of something got in there and wonlt let it do it's job. I don't think it is something you are going to be able to deal with. Do a search for an authorized Saeco repair center and tell them you were told the flow meter may be faulty. Sorry.
Posted on Jul 30, 2007
Coldcut
  • 1554 Answers
SOURCE: 42115
let it perk some weak vinegar mix to clean the tubing and heating area, then run just water to flush that out.
If it still has this issue then the thermal switch may be bad.
Posted on Jan 26, 2008
  • 30 Answers
SOURCE: Spacemaker? Digital Coffeemaker-overflows during brewing with grounds everywhere.
I've read of this problem from other users of the newer Spacemakers and believe I know what's going on. Black & Decker used too strong a spring in the mechanisms involved in the "sneak a cup" feature which keeps the small tab or finger underneath the basket from opening and allowing the coffee to run into the decanter.
My suggestion would be to make certain that the tab that presses against the bottom of the basket is open when you insert the carafe. Not owning one of these units I can't state categorically that this will solve your problem, but all of the Spacemakers are fundamentally the same, just some cosmetic and design differences between them.
If it turns out that the tab is open when you go to bed and the basket still overflows it's possible the spring is so strong that it's moving the carafe away from the back of the unit, causing the tab to close against the basket. If that's the case I would figure out how to remove the spring without breaking anything in the process, then take it down to your local Ace Hardware and get a same sized but weaker spring. That should solve the problem permanently.
Posted on Oct 24, 2008
co7196
  • 3433 Answers
SOURCE: filter cone is full of hot water & thermo pot has about 5 - 6 cup
Te water fill lid is not closed or or the flow valve in the tank is plugged. Remove the basket and clear the hole in the bottom of it.. If new, return it to place of purchase.
Posted on Jun 22, 2009
  • 13 Answers
SOURCE: Mr Coffee doesn't brew
Usually when that happens you need to clean it out w/ white vinegar and water because it's developed a blockage of some kind. I'd recommend 6 cups vinegar and 6 cups water, and brew it through like a normal brew cycle. If you haven't done this at all in the year that you've owned it then it probably won't work completely the first time. You might have to do it quite a few times, and I suggest doing it at least once a month from here to keep the problem from happening again. And remember to always use a fresh solutution each cycle, don't want anything you take out to go back in, you may not get any coffee then! :)
If you like, there's another way you can do it. Put in the solution of vingear and water, start to brew it, and just when you start seeing it drip into your pot, turn off the unit and let it sit for an hour. Soaking it or running it through several cycles can both help, it's up to you how you go about it.
Posted on Aug 28, 2009
Mr coffee model gbx23 stopped working, it won't turn on.
It might be a problem with your outlet, and not the coffee maker. Your kitchen outlets should be GFCI protected. There is supposed to be a sticker on all outlets that are protected by a Ground Fault Circuit Interrupter, but sometimes they are left off. Look for an outlet in the kitchen that has a rest button between the outlets. You can also take the coffee maker to a known working outlet, or bring something that you know works to the coffee maker outlet, to see if it is the outlet that is not working or if the coffee maker is still not working at a good outlet. If the outlet isn't working, try others in the kitchen to see if they are. If they are not, and you didn't locate a reset button on one of them, then check the breaker box for a tripped breaker.
Coffee makers do have at least 2 safety switches inside them, but they are only to keep them from overheating and catching fire. If one of the switches did go bad it is possible that it might shut down the entire machine. If that is the case, then it's time for a new coffee maker, as the safety switches are not servicable.
dd1bd15d-8ff7-4198-9167-3cc45a5562ef.jpg120v AC GFCI outlets
(220v AC outlets will have the same reset buttons)
Apr 28, 2014 | Mr. Coffee GBX23
I have a Kenmore Elite Coffee Maker, I press brew, the light flashes and then it beeps but does not brew.
gotta have the correct time set, also check auto brew timer. Coffee pots usually beep when they are done brewing and then when it's turning off, usually after a hour. Play around with timer (hrs. and min.)
Apr 07, 2011 | Coffee Makers & Espresso Machines
Won't brew...steams, sputters but no water up to filter
You may have a mineral build up, (common in areas with hard water). Fill unit with a 50/50 mixture of white vinegar and distilled or bottled water. Let sit for an hour then start the brew cycle. If this fails to clear the blockage there are some coffee maker cleaners available at most supermarkets.
Jan 22, 2011 | Cuisinart Brew Central 12-cup Coffee Maker
Slow brewing
The coffee maker has three contributory factors for brewing experiences. First, putting enough water in container prior to brewing is expected to dispense in to coffee capture cup. Second, installing the component parts after inserting coffee leaflets should not hinder brew seepage into the cup. Third, allowing enough time for the brew to dispense is a requisite means to coffee impressions. Furth, coffee leaflets require appropiate numbers inserted at the container area lest the machine takes time to sock and dispense. However, refer to the device user guide for appropiate manufacturers instructures to user as expectations during brewing. Also, refer to the user guide to ascertain any conditions that may be signs of damage preventing fast brewing.
Jan 22, 2011 | Oster HDX23 12-Cup Coffee Maker
I want to make stronger coffee
There are a few ways to do this. One would be to add more of the coffee grinds into the tray. Double your amount, you have double the potency. You can also try the energy blend coffee grinds that they sell at your local stores. That gives it an extra kick as well. Also, Brazillian brands and Columbian brand grinds seem to have a little more potency than the rest.
Hope this helps.
Dec 23, 2010 | Saeco Vienna SuperAutomatica Coffee...
Doesn't complete a full brew cycle before alarm sounds to indicate end of brew cycle. Have to re-start up to 4 times to get a full pot of coffee.... what can be done to solve this issue?
sorry I don't have a solution but actually have the same problem. This is driving me crazy! (not really) I have tried taking the filter out and cleaning the unit with vinegar. nothing helps.
Aug 22, 2010 | Cuisinart Grind and Brew 10 Cup Coffee...
Aug 28, 2009 | Mr. Coffee 072179228578 12 Cup Coffee...
12+3+5+5+5+5+5+5+4+4+1+74+74+4+1+4+46+6+5
say it 12345678900000000000
any problem
thank you for rest time
Jul 11, 2009 | Saeco D-XXDX 8-Cup Coffee Maker
Took it apart to clean it now i have unscrewed and a spring has come out that makes the door to the filter open and close. oopps
A clean coffee maker is essential to good coffee. Residue of stale coffee oils will interfere the brewing that caused only little produced. It is suggest regular cleaning of your coffee maker according to manufacturer recommendation.
I took everything out, got a small piece of fine sandpaper, held the plunger in with a pencil, turned on the grinder and sanded the round top portion of the grind basket driver. It takes a few times to get a good snug fit that’s still easy to remove.
The instruction manual that came with the pot will tell you to use one cup (measuring cup) of "white vinegar" and fill the rest of the reservoir with regular water. Turn it on and let it perk the mixture through the system. Then perk a couple of pots of plain water to flush out the rest of the vinegar.
The books say to do this once a month to keep things clean and the coffee tasting great.
A professional machine that is plumbed into a water supply must be thoroughly disassembled, and each part soaked in acid, and manually cleaned. Unless your water is exceptionally hard (you should have a water softener inline with the machine in hard water areas) this should only need to be done every 5 years or so. Heads and screens and filters should be soaked every day in a cleaning solution available from any professional machine supplier. A machine that is not plumbed should have a small amount of Puly brand cleaner added to its tank, and run through several cycles every 3 months. Puly is available thru machine suppliers, but there are also several other brands that do the same. Visit your local coffee machine shop for a good cleaner.
Hope this may help;
Regards,
VOTIT
Sep 23, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Black & Decker TCM700 Coffee Maker Logo
246 people viewed this question
Top Black & Decker Coffee Makers & Espresso Machines Experts
eyecam
jason
Are you a Black & Decker Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
