Question about Technics SL-1210 Turntable
All my vinyl sounds warped on turntable
Happened suddenly. previously, albums sounded fine. Am wondering if this is due to belt problem on turntable or something else. It's a fairly old (but good quality) technics. Have used it for years, never had a problem till now.
Couldn't find the model in the list so I chose the first one - it's actually an SL-B200 Technics turntable.
  • RealNeatGuy Jul 23, 2008
    i have a Direct Drive Turn-Table that somehow has the same problem. i opened it up to look at it and noticed that it spins unevenly. The rotation slows down and speeds up. Sometimes its unoticeable on 33's but on 45's its impossible, just totally warped.
    Its a Gemini XL 500 II...its really nice, which is why i want to know if theres anything I can do before i chuck it and get a belt drive for cheap...
    any help would be real...neat
  • 33 Answers
Most common problem is the belt getting soft, especially if it has sat for a long time. It will get a weak spot where it sat on the drive pulley and every time the turntable goes around and hits that weak spot it will slow down a little making it sound like a warped album.
The belts are usually very easy to replace. Usually just lift off the turntable or there might be a small clip on the center pin, then it lifts off. Replacement belts can be ordered from several places, as shown in this search... http://www.google.com/search?&q=SL-B200+Technics+turntable+belt
Posted on Feb 17, 2008
Buy some direct drive turntables!!
Posted on Apr 29, 2008
How to replace a belt on a turntable
Generic instructions for replacing a belt on a turntable such as yours are here:
http://www.gbaudio.co.uk/data/belts.htm
If you have trouble lifting the platter off, use the finger holes and lift. A gentle tap on the spindle (with the handle of a screwdriver, for example) ought to free things up.
Oct 28, 2014 | Audio Players & Recorders
Crosley CR249 warped table
Sounds like you need a new platter. Has the platter worked OK before or has it always been like this?
I suspect you might have to contact Crosley to see who supplies parts.
Jan 10, 2013 | Crosley CR249TA Turntable
One side of my vinyl record will play fine but the other side won't spin right and the needle gets stuck on the record
The only thing you can do is clean the record with cleaning fluid. You will find special cleaning fluids for records on Amazon. If the record is warped you can try a weight pressing down on the record. But sadly if a record is warped bad there's no real cure.
Dec 28, 2012 | Crosley 0187SST Turntable
Gemini tt-2000 direct drive. Turntable platter is visibly warped, wow unacceptable. Flutter is also bad, piano suddenly has vibrato. What can be done? This is a new unit, bought last year, but because...
If the turntable platter is visibly warped there nothing you can do to correct this, the only option is contact the manufacture and see if they would be willing to supply you with a replacement part at no charge, especially when you have been moving. But I would check your warranty closely, you just might be in luck.
Feb 10, 2011 | Gemini Sound Products Gemini TT2000 Direct...
How do i fix vinyl records that warped due to being in heat
Depends how bad they are. If only slight then you might get away with a heavy weight on it. Protect the record with card, you might have to leave it a long time.
Warm it up somehow, don't apply heat direct to the vinyl.
Having said that I must tell you I have had no success with any I tried to rescue any of my records.
Sep 22, 2009 | ION Audio Vinyl Recording Turntable
Hi, I have a technics stereo system from 1986.
If the turntable is belt driven you may have a stretched and slipping belt that needs replacement. This seems most likely and is simple to fix. You will have to lift off the turntable to see the mechanism beneath. It may be held on by a nut or clamp. A web search for the model name and "dirve belt" may yield a replacement.
If it is driven directly by a motor without a belt, the motor is probably dying. Replacement more involved, expensive, and hard to justify, unless you're really into vinyl.
Aug 06, 2009 | Technics Audio Players & Recorders
Numark tt1625 turntable wavey sound
Your belt is probably worn and needs replacing. Lift felt on platter and and lift the platter section off the unit by putting your thumb and forefinger through the two large holes and pull upwards.There should not be any special routing for the belt and should go directly onto the spindle motor to your platter. Place the belt around the inside rim of the platter while it is still off the unit. Now replace the platter and move the platter around until you see the spindle motor through one of the holes. Use some tweezers to manouvre the belt onto the spindle motor. On some units you will have to lay the belt out inside the unit, replace the platter and manouvre the belt onto the platter. Hope this helps
May 28, 2009 | Numark BATTLE PAK v.4 Turntable
Teac P-988 Everything sounds slow/warped
not passing the "wow and flutter" specs, eh?
The most common cause of this is a loose or defective belt. An inferior belt will have varying thicknesses along it's length. When it hits a skinny part, it will slow slightly. When it hits the thick part, it will speed slightly. Overall effect is that the record sounds warped.
needledoctor.com has got some good stuff.
Jun 12, 2008 | Teac P-988 Turntable
Technics SL-1210 Turntable Logo
1,816 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
