Closed Caption keeps coming back on
My elderly parents have had problems with their TV since it was moved a few months ago. The closed caption keeps displaying on the screen. We've turned it off, and it stays off for several minutes, and then it's starts displaying again. I have no idea how to stop it for good. the Model is 27MS3404R.
  • 2 more comments
  • keeshond Feb 17, 2008
    I have done this many times. It just keeps coming back.
    Yes, I've done this, as I mentioned in problem discription, but it keeps coming back after a few minutes.
    I have saved the settings, but it still comes back on. Please understand that I am doing everything listed in the manual, and it should work, but it does not.
    The closed caption on my parents' magnavox TV keeps coming on even after I have turned it off and saved the change exactly as the manual states. It works for a few minutes, and then the closed caption comes back on. The TV was fine for years, and it was recently moved and then this started happening.
    Genius:
  • 3,587 Answers
Methinks you have a loose connection or board in the chassis, from the move. DO NOT open that back, until the power has been off for quite some time(30 min) due to shock potential. This is really for a qualified service professional.
CC has two components. Firmware(as indicated above) and a cc conversion board. I suspect that is the cause of this issue, since it's restarting on it's own.
Posted on Feb 17, 2008
    Genius:
  • 1,665 Answers
See page 30 of user manual below:
http://support.radioshack.com/manuals/ome16-3422.pdf
Closed Captioning (CC) allows you to read the
voice content of television programs on the
TV screen. Designed to help the hearing
impaired, this feature uses on-screen “text
boxes” to show dialogue and conversations while
the TV program is in progress.
1 Press the CC button on the remote
to display the current Closed Caption
setting.
2 Press the CC button repeatedly to
choose from the four Closed Caption
options (CC Off, CC 1, CC 2, CC
Mute). Dialogue (and descriptions) for
the action on the captioned TV program
will appear on-screen if the tuned program
is broadcasting CC information.
3 When finished, press the STATUS
/EXIT button
to remove the menu
from the TV’s screen or let the option
time out and disappear from the TV
screen.
    Genius:
  • 3,422 Answers
1) Press the CC button on the remote
setting.
2) Press the CC button repeatedly to
3) When finished, press the STATUS
/EXIT button to remove the menu
time out and disappear from the TV screen.
NOTE: The CC MUTE option
can be used to set the TV to
turn the Closed Caption mode
“ON” whenever the MUTE
button on the remote is
pressed. This activates the CC1
option.
Goodluck,
Please don't forget to rate me as fixya..
  • 770 Answers
When you turn it off are you going into the setup menu to do this?? if so after it comes back on and you go back to the menu and you see it..as "on" You will need to save your settings before you exit out of the menu
Have a toshiba 50" Plasma TV purchased 11/06.
I do not think there is an issue with the TV. I do not think that the station themselves broadcast the Closed Captioning.
Feb 04, 2011 | Toshiba 52HM95 52" HDTV Projection...
Black square comes on tv
hi,
in your tv the closed caption option is in on position. make it off o run out the black square.
to make the closed caption (cc) off. do the following.
1. press the menu button
2. select setup
3 go to closed caption (cc)
4. select closed caption mute (cc mute)
ok
Jan 27, 2011 | Panasonic CT-36D32 36" TV
Cannot turn off Closed Caption
Here's the copy on CC from my manual LC-32SB23U.
1. Press CC.
This will present the Closed Caption information display.
2. Press CC while the Closed Caption information is
still on the screen.
Press repeatedly until you select the desired closed
caption service.
INFO BOX ON THE SCREEN,
Air ANALOG
Audio : MONO
CC : 1/2 CC1 ------ Closed Caption information
Ratings : NONE
Example:
If a program has three services (Digital CC(ENG), CC1
and Text1), the closed caption display will toggle in this
sequence:
1/3 ENG -- 2/3 CC1 --- 3/3 Text1 -- Off
The CC button keeps a record of the last service
selected in its memory.
If the last closed caption mode (e.g. 1/3ENG) you
selected is not available for the next program, or on
another channel, the closed caption service that is
available is automatically selected, and this service
appears in parentheses, e.g. “1/3(CC1)”.
Closed Caption services that appear in parentheses will
not be stored in the CC button's memory as your last
selected service. Only services that you have selected
with the CC button are stored.
If this doesn't work, the TV may need a software upgrade.
I can get you a copy of my manual LC-32SB23U for you. But, are you sure there is and "A" in the middle of your model number?
Jun 02, 2009 | Sharp LC-32SB23U 32 in. LCD TV
Closed caption
Are you talking computer or TV?
Closed caption on a TV is when the volume is muted and it prints the speech in a box on the screen. You have to turn it on in the menu.
Nov 27, 2008 | Computers & Internet
Big black box on screen
It has something to do with the closed captioning. He must have hit the closed caption button on your remote. You need to either turn the closed caption off or make another selection under closed captioning like cc1 cc2. Just keep making selections until the box goes away.
Jul 09, 2008 | Toshiba 57H82 57" Rear Projection...
Closed caption activiting on everytime tv is turned on
If you have the Suddenlink remote and the DVR box you can turn captions on or off by accessing a technical menu. To do this, press POWER and Menu buttons together (menu 2 times) to bring up a special menu. Select Closed Captions. On the popup menu select closed captions and using Select button change to OFF or ON as you wish. The trick is to get the menu to come up. Timing of pressing the two buttons is frustrating and it may take a few times befotre you get the special menu.
Oct 02, 2007 | Televison & Video
Blach block out
if your big black square starts about the middle of the tv & goes down close to the bottom, you have closed caption text turned on. normal closed caption is small, but test caption, is just a big black box with no writing in it. go into your menu & shut it off, it could even be a button on your remote called, "caption", or "cc". good luck.
Dec 27, 2006 | Samsung TXJ2067 20" TV
Televison & Video Logo
622 people viewed this question
Top Televison & Video Experts
Electro Med Services...
