Question about Panasonic AG-DV1000 Mini DV VCR
Error H U 11
Ok, so I have a bunch of tapes, that when I put them in the deck, they play, but every couple of seconds the sound cuts out, and I get an error on the screen of the deck that flashes "H U 11" instead of the timecode. Anyone know what this means?
    Champion:
  • 221 Answers
U11 is a "dirty video heads" message. Either use a cleaning tape or have the unit professionally cleaned.
Posted on Feb 18, 2008
I took my Pioneer SX-450 Receiver and Pioneer CT-1040W Tape Deck apart to move it. Put it back together. Now can't get a tape to play.
After putting a known good tape in the deck, push play, if the tape doesn't move, try rewind and FF. If nothing happens, the deck has a problem. I assume this is a cassette deck. If so, I always try the thrift stores for a new(used) one. There are good bargains there.
Dec 22, 2016 | Pioneer Audio Players & Recorders
Rs-bx707
Two causes for this. The first being a faulty tape head, or possibly a wire to it that become disconnected. The second is the failure of the pre-amp inside the deck. Also investigate any switches. These can have faulty contacts or dirty ones, causing the sound to be cut off.
May 24, 2014 | Audio Players & Recorders
What is the bias control's function?
The Bias control is used during recording. If you turn down the bias, you will get more highs, but the distortion will increase, and then start to increase dramatically if you back off the bias more.
As far as playing tapes from different decks goes.......
1..Does the tape that you recorded on your deck sound OK on your deck ?
2..Does the tape that you recorded on your deck sound OK on other decks ?
If 1 and 2 are true, then your deck is OK.
If the tapes recorded on a specific deck sound bar on yours, but 1 and 2 are true, then the other deck is faulty.
When a deck leaves the factory, the head is aligned to a " standard " tape. By standard tape I mean a very special tape recorded in such a way, that a tech can tell if the head is out of align and "tweek " the physical alignment of the tape head..
All decks are aligned just a little differently, but fairly close to each other.
first do the mechanicals....is the head of your deck spotlessly clean ?. Use 99% pure isopropanol alcohol and a cotton swab. Never use anything metal to clean the tape head. If you scratch the head, its toast.
If your deck is clean, plays its own recordings well, and those recordings play well on other decks, then your deck is not the problem.
Hope this helps,
Rob
Mar 24, 2012 | Audio Players & Recorders
I have a onkyo cassette tape deck ta 2600,when you push play on the cassette,it would play the tape for half of a second and stop
Sounds like the cassette tape itself is too tight to play, try fast forwarding or rewinding the tape in the deck all the way to the end of tape several times before trying to play. This may solve the problem
Dec 27, 2010 | Onkyo Audio Players & Recorders
Tdk sony dvm60 miniDV tape not playing in final
HI please check your easy setup in tyhe fcp and set it as pal or ntse dv and should get the video in
Mar 02, 2010 | TDK DVM60 Mini DV Tape
I have distortion of playing tapes.
Degraded tape, dirty heads (clean with acetone and Q tip but don't get on plastic), dry coupling capacitors.This assumes that the distortion that you refer to is dirty or fuzzy sounding audio.
If a new tape, recorded and played back, sounds ok then your electronics are in good shape. That means your tapes are junk. If cleaning heads takes care of it, well that's pretty obvious. If your capacitors are dried out you will need to bring it in to a repair shop.
Apr 20, 2009 | Audio Players & Recorders
Cassette player is eating tapes
Hey there.
Cassette head cleaners generally only improve the sound quality on playback. This problem sounds more like something mechanical; I would open the player and check out the capstan and rollers. If they are dirty, clean them with a mild soap and water solution, (carefull to not get it too wet). Also, as for the tape deck in your vehicle, OEM systems are notorious for eating and destroying cassette tapes.
Let me know how this goes over,
HortonA!
Mar 22, 2009 | Audio Players & Recorders
Sony mp3 MHC-RG440s
well fuses are at the power supply sections and if the tape was jamed inside the deck, just disconnect the plug and try to take-off the case/cover of your unit but before opening it wait for about 1-2 hours to discharge the capasitors and then disassymble your unit try to get the tape deck and then get a knife a scissor, something to cut the tape inside the deck, thats the best solution, but you won't get your tape back though even when you get your tape uncut well, when you play it again you will not get good sound.
maybe your tape deck have a problems, maybe a broken gears, a belt was snaped, or a relay is the main problem.
its better to observe your unit first before you play a tape again.
ok? hope you could get your system back in good condition and have a good day.
Mar 16, 2008 | Sony MHC-GX450 CD Shelf System
Will not dub another tape
This site is useless. It tells you nothing.
Why does it exist?????
Jan 19, 2008 | Sony TC WE435 Stereo Dual Cassette Deck...
Panasonic AG-DV1000 Mini DV VCR Logo
154 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
