Question about Yamaha HTR-5440 Receiver
Tuner how do i set my radio stations after they have already have been set.
  • cnorrdin Sep 07, 2008
    I have the HTR 6130 and the manual is very confusing on this point. There is a button on the unit labeled: "Edit Pre Sets" but no info in the Owners Manual on editing pre sets, and the process is not at all intuitive.
  • 1,512 Answers
Hi Dude
Presetting channels for radio stations is generally all the same on most systems. Select the frequency you want and then HOLD IN the preset button you want until it locks to the frequency into the new preset. Good luck, and happy presetting :)
regards
Graeme
Posted on Feb 18, 2008
Forgot how to programme radio stations on Philips Micro System MC-222
Tuning to radio stations
  1. 1 Select TUNER source. ? TUNER is displayed briefly.
  2. 2 Press BAND once or more to select your
    waveband.
  1. 3 Press down on TUNING a? or a? and release button.
    ? The radio automatically tunes to a station with sufficient reception. Display indication during automatic tuning: SEARCH.? If a FM station is received in stereo, STEREO is shown.
  2. 4 Repeat step 3 if necessary until you find the desired station.
To tune to a weak station, press TUNING briefly and repeatedly until you have found optimal reception.
Programming radio stations
You can store up to a total of 40 radio stations in the memory.
Automatic programming
Automatic programming will start with a chosen preset number. From this preset number upwards, former programmed radio stations will be overridden.The system will only programme stations which are not in the memory already.
Press PRESET 3 or 4 (on the remote control ¡ or TM ) to select the preset number where programming should start.
Note:
- If no preset number is selected, default is preset (1) and all your presets will be overridden.
Press PROGRAM for more than 2 seconds to activate programming.? AUTO is displayed and available stations are programmed in order of waveband reception strength: FM followed by MW and LW.The last preset automatically stored will then be played.
Manual programming
Tune to your desired station (see "Tuning to radio stations").
Press PROGRAM to activate programming. ? PROGRAM flashes in the display.
Press PRESET 3 or 4 (on the remote control ¡ or TM ) to allocate a number from 1 to 40 to this station.
Press PROGRAM again to confirm the setting. ? PROGRAM disappears, the preset number and the frequency of the preset station are shown.
Repeat the above four steps to store other stations.
Jun 19, 2016 | Philips Audio Players & Recorders
How do I Get all radio stations on my remote .
That depends on how your TV is set up for radio reception.
Some TVs have a dedicated FM/AM radio tuner. This requires signals from both forms of radio antenna.
More commonly now though, digital TV includes a wide range of radio stations broadcast as part of the TV range. In the UK, the radio stations are grouped in the 700+ channel range. e.g. 701 is BBC Radio 1.
Sep 09, 2014 | Televison & Video
Dewalt DSCN1360 tuner problem
Don't you have an automatic tuning system or ATS? By pressing a band switch for a while the ATS starts looking for stations and stores the ones that have a good enough signal. Even if a station broadcasts but the location of the radio is not adequate for a good signal to be received, the station won't register and it will appear to you that the tuner is skipping.
Dec 02, 2013 | Eton FR300 AM/FM/Weather/TV Radio
Radio wont find any stations
tuner IC TEF6901 probably failed - needs new tuner unit that cannot be purchsed!
Jul 06, 2012 | Visteon Car Audio & Video
Hi, I was wondering if my LG DVD Micro HiFi System FB163, could play an the radio as an alarm? If so how?
Hello, To set a radio station as your alarm -
  1. Press and hold "timer" for two seconds.
  2. All the functions DVD/CD/USB/Tuner will flash for two seconds.
  3. Press "set" when the mode you want to be woke up by is showing.
  4. If you pick "tuner" then "play" and "record" will flash alternately flash in the display.
  5. Pick one by pressing the "set" button.
  6. Then select the preset station you want to wake up to.
  7. Now press set again.
  8. You will now wake up at the time and radio station you selected.
Regards, Tony
Mar 24, 2011 | LG FB163 DVD/DivX USB Micro system Shelf...
Cannot play ipod in 99 daewoo lanos
instead of pressing the left/right scanning buttons hold them and then let go when you want to stop
Aug 15, 2009 | Daewoo Lanos 1999 Car Radio/stereo...
AM radio tuner set as MW tuner. How to switch to U.S.A. AM mode?
AM is just another name for MW. The Radio should tune to a strong signal regardless of the frequency the radio is set to. It should also sweep the entire frequency looking for stations. I'm assuming it has a channel scan setting, plus options to set a number for the station. AM/MW are very much dependent on the position of the either internal or external Ariel. If you have the radio in the wrong position or you have some electrical equipment nearby it could block the signal for the station you want, but not affect the others. Which might explain why it can't find the station you want.
May 05, 2017 | Philips DCM230/37 iPod Docking Executive...
Problem to find radio station on tuner?
FM ( at least in the USA) only goes 90.1-90.3-90.5 and so on.
This is how stations are separated.
There are no stations on 90.4 or 101.6 and so on
Nov 02, 2008 | Denon AVR-1803 Receiver
Presetting radio stations on my pioneer rx370 tuner
Using the tuning buttons, select your station. Then press memory, select the station call#, and then press memory once again.
Dec 04, 2007 | Westclox Presto 80199 Clock Radio
Yamaha HTR-5440 Receiver Logo
290 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
