Question about Intel Pentium 4, 3.06 GHz Pentium 4 (P4306R5) Retail Processor
My Processor is switched off after switch on the machine
My Processor is switched off within 15 seconds after switch on the machine
The CPU cooler may be stopped up-- not working. That causes the processor to shut down se-f-protecting against excess heat. Check the cooling fan first.
Posted on Feb 18, 2008
I called myself programming the new keys for my pt cruiser, but,it didnt take. At first it would start and run for a few seconds, now it wont turn over.what did I do wrong and how can I fix this?
Takes the master key to get it started again. The security gives you 3 tries to get the vehicle started, after the third time, it kills the starter.
2002 Chrysler PT Cruiser Note: You must have two valid keys to add a new key to the system.
1. Insert the first valid key into the ignition switch. Turn the ignition switch to the
ON/RUN position for at least three seconds, but no longer than 15 seconds.
Then, Turn the ignition switch to the LOCK position and remove the first key.
2. Insert the second valid key into the ignition switch. Turn the ignition switch to
the ON/RUN position within 15 seconds. After 10 seconds, a chime will sound.
In addition, the Vehicle Security Light will begin to flash. Turn the ignition switch
to the LOCK position and remove the second key.
3. Insert the new key into the ignition switch. Turn the ignition switch to the
ON/RUN position.within 60 seconds. After 10 seconds, a single chime will
sound. In addition, the Vehicle Security Light will stop flashing. To indicate that
programming is complete, the Vehicle Security Light will turn on again for
seconds and then turn off.
The new key is now programmed. The Remote Keyless Entry transmitter will
also be programmed during this procedure.
Repeat this procedure to program up to eight keys.
Oct 09, 2016 | Cars & Trucks
Tip
How to program Chrysler Remote Transmitter
A Chrysler Transponder Key once programmed into a one car cannot be programmed to work any other car.
The transponder code identification is learned by the Sentry Key Immobilizer Module during programming. The Sentry Key Immobilizer Module sends the "Secret Code" to the transponder key and is retained by the transponder key during programming. After programming of the transponder key identification to the Sentry Key Immobilizer Module and the Secret Code is exchanged, the Sentry Key Immobilizer Module will ask for the transponder identification and the Secret Code every time the key is turned to ON or START.
No Emergency "Start" procedures for Chrysler vehicles.
Chrysler Key Operation and Programming
Model: 300 Year: 2005 - 2008
Model: 300C Year: 2005 - 2007
Remote alarm / central locking
System Operation
  • Pressing key LOCK button activates alarm and central locking.
  • Pressing key UNLOCK button once deactivates alarm system and unlocks driver's door.
  • Pressing key UNLOCK button twice within 5 seconds deactivates alarm system and unlocks all doors and trunk.
  • Pressing trunk lid button twice opens trunk lid.
  • System will automatically lock all doors when vehicle is driven above 15 mph.
  • Additional functions can be set to respond to the transmitter.
Programming
When
  • Key transmitter added or replaced.
How
  • Key transmitter is programmed during immobilizer programming procedure.
Immobilizer
System Operation
  • Switch ignition ON.
  • Immobilizer warning lamp illuminates for approximately 3 seconds.
Programming
When
  • Keys added or replaced.
How:
NOTE: Two programmed key transmitters must be available for the following procedure to operate. If none available key transmitters can only be programmed using diagnostic equipment.
  • Insert first programmed key into ignition switch.
  • Switch ignition ON for at least 3 seconds but no longer than 15 seconds.
  • Turn ignition OFF and remove key.
  • Withing 15 seconds insert second programmed key into ignition switch and turn ignition ON.
  • After 10 seconds an acoustic signal will be heard and immobilizer warning lamp will flash.
  • Turn ignition OFF and remove second programmed key.
  • Within 60 seconds insert non programmed key into ignition switch and turn ignition ON.
  • After 10 seconds an acoustic signal will be heard and immobilizer warning lamp will illuminate for 3 seconds.
  • Switch ignition OFF.
  • Remove Key.
Check operation of programmed key transmitter.
Repeat procedure for additional key transmitters if required.
Model: 300M Year: 1999 - 2003
Model: Concorde Year: 1998 - 2003
Model: LHS Year: 1998 - 2001
Model: PT Cruiser Year: 2000 - 2005
System Operation
  • Pressing remote transmitter UNLOCK button once deactivates alarm system and unlocks driver's door only.
  • Pressing remote transmitter UNLOCK button twice within 5 seconds deactivates alarm system and unlocks all doors.
  • Alarm / Central locking functions can be altered using remote transmitter.
Programming
When
  • Remote transmitter added or replaced.
How:
NOTE: One programmed Remote transmitters must be available for the following procedure to operate.
  • Obtain all remote transmitters.
NOTE: Any existing remote transmitters not used during programming will become inoperative.
Using a programmed remote transmitter proceed as follows.
  • Press and hold remote transmitter UNLOCK button.
  • After holding the UNLOCK button for at least 4 seconds but no longer than 10 seconds, press remote transmitterPANIC button for at least 1 second and release both buttons.
  • Ensure acoustic signal is emitted indicating programming mode active.
  • Within 30 seconds carry out the following procedure for each remote transmitter (including previously programmed remote remote transmitter)
  • Press any button of each remote transmitter to be programmed.
  • Ensure acoustic signal is emitted after each remote transmitter operation.
  • Programming must be completed within 30 seconds.
  • Switch ignition OFF or wait 32 seconds to exit programming mode.
Ensure final acoustic signal is emitted.
Replacement remote transmitters can also be programmed using diagnostic equipment.
Immobilizer
System Operation
  • System arms after switching ignition OFF.
Programming
When
How
NOTE:Two programmed key transmitters must be available for the following procedure to operate.
  • Obtain all keys.
  • Using first programmed key turn ignition switch ON and wait 3 seconds, return to OFF position and remove key.
NOTE: First and second programmed key operations MUST be performed within 15 seconds.
  • Insert second programmed key and switch ignition ON.
  • Wait approximately 10 seconds.
  • Ensure immobilizer warning lamp begins to flash and an acoustic signal is emitted.
  • Switch ignition OFF and remove key.
  • Within 50 seconds, insert new key and switch ignition ON.
  • Ensure acoustic signal is emitted and immobilizer warning lamp remains illuminated for 3 secondsindicating programming completed.
For each additional key repeat procedure starting from the beginning.
Replacement keys can also be programmed using diagnostic equipment.
Automotive and Commercial Locksmith Chrysler Remote Control Programming...
on Mar 26, 2015 | Televison & Video
How can i get a manual for 2005 jeep liberty ?
Owners manual.. Dealer with he VIN#. Mechanics manual, any parts store. It covers all the Liberty's.
Oct 27, 2015 | 2005 Jeep Liberty
Getting pe error
Whirlpool Washing Machine Displaying Fault Code PE The part(s) or condition(s) listed below for the symptom PE - PRESSURE SENSOR ERROR // Water level pressure switch error are ordered from most likely to least likely to occur. Check or test each item, starting with the items at the top of the page.
per https://www.repairclinic.com/RepairHelp/How-To-Fix-A-Washing-Machine/408-5--/Whirlpool-PE-PRESSURE-SENSOR-ERROR-Water-level-pressure-switch-error
b2kjqj
Dec 09, 2017 | Whirlpool Washing Machines
Hotpoint WD440
Possible there is an error in the processor and it needs to be reset. You can switch off power, remove the plug from the mains and keep off for about 15-30 minutes. Make sure there is no moisture within the panel in which case you can allow the panel to dry -- after confirming that there is moisture on the panel.
Switch on after the time limit and if there is no response it is possible that the board has hung up.
May 29, 2013 | Washing Machines
I have hp compaq nc6000 every time i switch it on it comes on and goes off within 5 to 10 seconds. there is no display when during yhat time. what could be the pssible cause
From the description this is a motherboard issue, a common problem with hp, at this point I would recommend having it assessed.
Jul 20, 2012 | HP Compaq nc6000 Notebook
Cant shut off my craig with remote or by buttons on tv
If the set works well then the fault is the standby shut off circuit. ou need to trace the processor standby out which leads to a transistor that switches ON/OFF on request from the processor. If there is data output but the transistor does not switch there can be short or leakage within. Replace and test the bias of the transisitor. If not the processor can also be the suspect. Your voltage check on the processor output will confirm
Oct 27, 2011 | Craig CLC501 15 in. TV
My pt cruiser won't start... Not because of the battery or engine but because of the anti theft... Weve tried all keys and remotes to no avail... What now?
Programming
When
System malfunction. Key added or replaced.
How
NOTE: Two programmed keys necessary. Complete each step within 15 seconds. NOTE: Some models - replacement key can only be programmed using diagnostic equipment.
Obtain all keys to be programmed. Using first programmed key, proceed as follows: Switch ignition ON and OFF within 15 seconds. Using second programmed key, proceed as follows: Switch ignition ON and OFF within 15 seconds. Within 10 seconds: Immobilizer LED flashes. Programming mode activated (acoustic signal will be heard). Proceed as follows: Within 50 seconds: Insert first key to be programmed into ignition switch. Switch ignition ON and OFF. Within 10 seconds: Single acoustic signal will be heard and immobilizer LED stops flashing and illuminates for 3 seconds to indicate correct programming. Repeat complete procedure to program remaining keys. Keys can also be programmed using diagnostic equipment.
Jun 25, 2010 | 2003 Chrysler PT Cruiser
2004 jeep cherokee alarm won't disarm
NOTE: A maximum of 8 keys can be programmed.
Dec 29, 2009 | 2004 Jeep Grand Cherokee
1999 olds aurora when you turn the key just says clean key wait 3 minutes
the key has magnet on it that may be weakening. It will have to be reprogrammed.
  1. Insert the first valid key into the ignition switch and turn the ignition switch ON for at least 3 seconds but no longer than 15 seconds. Turn the ignition switch OFF and remove the first key.
  2. Insert the second valid key and turn the ignition switch ON within 15 seconds. After ten seconds a chime will sound and the Theft Alarm Light will begin to flash. Turn the ignition switch OFF and remove the second key.
  3. Insert a new Key into the ignition switch and turn the ignition switch ON within 60 seconds. After 10 seconds a single chime will sound. The Theft Alarm Light will stop flashing, turn on for 3 seconds; then turn off. The new key has been programmed.
Jul 07, 2009 | 1999 Oldsmobile Aurora
Intel Pentium 4, 3.06 GHz Pentium 4 (P4306R5) Retail Processor Logo
54 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
