Vivitar ViviCam 8018 Digital Camera Logo
Posted on Jan 29, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have just purchases a 8018. It is default set at 3 mp. I have downloaded the manual and followed the instructions to change mp to 8. However, when the camera is turned off it goes back to 3. Is this normal or a fault in my camera? Do I need to remember everytime I want use it to change it from 3mp to 8mp?
Anonymous
Level 3:
Brigadier General:
  • Master 11,967 Answers
  • Posted on Jan 29, 2010
Anonymous
Master
Level 3:
Brigadier General:
Answers
11967
Questions
0
Helped
2200913
Points
38521
15
Image Size
The image size and quality setting determines the number of photos that can be saved and the amount of
memory required for each photo. The higher the photo quality the more memory it will use up. The image size
and quality will also affect the maximum size you can print your photo effectively. To set the Image size:
1. Press the Menu button.
2. Press Right/Left button to select the Image Size mode.
3. Press the Up/Down button to select the desired image size.
4. Press the Menu button to confirm, save and exit to standby mode.
If this still doesn't work, press the menu button twice.
1helpful
3answers
How to delete genieo
If you value your privacy, and the stability of your computer, then don't follow any suggestions that include using the genieo adware uninstaller : it leaves active software behind.
The company know this, but seem unable or unwilling to resolve it.
Instead, try to carefully follow the instructions at
http://www.thesafemac.com/arg-genieo/
or
https://discussions.apple.com/message/24950143#24950143
1helpful
Came without instructions. Why do I have to pay for instructions? I paid for the camera it should come with instructions!
The manual should have been on the CD. In addition, you can download the manual for free at
http://www.vivitar.com/files_products/12/8018%20User%20Manual.pdf
1helpful
No user manual came with my camera. I purchased an 8018 ViviCam and do not hardly know how to use it.
You can download the manual from
http://vivitar.com/files_products/12/8018%20User%20Manual.pdf
Where can I get a free manual for a vivitar vivicam 8018
You can download the instruction manual in PDF format by clicking this link.
  • You'll require Adobe PDF Reader installed on your computer to view the manual. If it is not already installed on your computer, download it free from: http://get.adobe.com/reader/
Thanks for using FixYa.
Instructions say I can download and open User Manual for Vivitar ViviCam 8018. How?
Click on this link for the User Manual:
Vivitar 8018 User Guide
Once you open it, use the small floppy icon and save a copy to your computer.
For reference, here is the support page for your camera where you can also download the manual:
Vivitar 8018 Support
Click on the Downloads menu item.
Thanks for using Fixya. Please take a moment to rate this solution.
1helpful
2answers
I need to set the time and date on my mums Vivitar Vivicam 8018 and can't work out how to do it! Any help appreciated (Or we're 99 weeks behind real time forever more!)
1. Press the Menu button to enter Set Date option.
2. Press Left/Right to scroll from one option to another.
3. Use Up/Down to change the highlighted digits.
4. Press the Menu button to confirm and save.
This is on page 21 of the manual.
1helpful
I HAVE JUST GOT A NEW VIVICAM 8018 I CANNOT FIND USERS MANUAL ON INTERNET IT DID NOT COME WITH ONE MODEL NUMBER MAYBE ONE OF THE FOLLOWING MID0050709 E1264A00208631 RES 3264X2448
http://vivitar.com
Enter 8018 into the search box. When it finds the camera, click on its name. When it tells you about the camera, click Downloads. You should see the manual then. Click on it to begin the download.
2helpful
Downloading the manual is quite a problem .Is it really 2,600 odd pages long ?I only want a few instructions and diagrams.
http://vivitar.com
It's 52 pages long.
I need a user manual was missing when i bought my 8018 digital camera last week
No Worries,
Please follow the below link, its an Official Vivitar link.
http://www.vivitar.com/products.php?dircat=1&dirsubcat=24&dirprod=12&page=downloads
CLick on the model No.
Click on Downloads.
You will see download for PDF, I have also provided direct link to the manual
http://www.vivitar.com/products/12/8018%20User%20Manual.pdf
Cheers
Oct 30, 2009 • Cameras
AudioCodes MP-11R/2FXS
The easiest way (if enabled) is to use the voice menu as if you would assign a new IP to the device.
  1. Connect a telephone to one of the FXS ports. Lift the handset and dial ***12345 (three stars followed by the digits 1, 2, 3, 4, 5).
  2. Wait for the 'configuration menu' voice prompt to be played.
  3. To change the IP address, press 1 followed by the pound key (#).
  • The current IP address of the gateway is played. Press # to change it or hang up if you don't want to change it.
  • Dial the new IP address; use the star (*) key instead of dots ("."), e.g., 192*168*0*4 and press # to finish.
  • Review the new IP address, and press 1 to save it.
Of course you can try the default IP of 10.1.10.10 if the device is set to it's default standards.
If not, you can try a network scanner like angryip (link) or network scanner (link) - this might take a long time, since the IP can be virtually anything.
If you have physical access to the device, you can also use a straight RS-232 cable to connect the AudioCodes to your PC and use HyperTerminal to connect (Baud Rate: 115,200 bps (MP-124), 9,600 bps (MP-11x), Data bits: 8, Parity: None, Stop bits: 1, Flow control: None)
If you need the manual (and it never hurts ;-) here is the link:
http://www.audiocodes.com/filehandler.ashx?fileid=36320
If you have any more questions, just come back here and leave a comment - I'm happy to help.
Top Vivitar Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Vivitar Camera Expert? Answer questions, earn points and help others
