Adding HD to projection 43" TV
I purchased this product in Feb of 2002. What do I need to make the adjustment to the 2009 ruling about HD?
    Scholar:
  • 110 Answers
You will need to connect an ATSC tuner box to your TV. You can find a lot more information about the switch (and even some government coupons for the boxes!!) here:
https://www.dtv2009.gov/
Posted on Feb 17, 2008
Digital signal hookup and compatability
the tv will be hd through the dvi port you can purchase a converter at most shops the you plug the hd freview sat and it will work if the tv has freview built in then it will still work when the switch over happens
Jan 17, 2009 | Hitachi 46F510 46" Projection HDTV
Picture Color is Malfunctioning
You will need a serviceman to check the voltages at the red CRT pcb to see if B+ is normal and then decide if RED CRT is defective or not......T.
Dec 03, 2008 | Hitachi 43UWX10B 43" Rear Projection...
Digital Conversion in Feb. 2009
It looks like you will need a HDTV tuner not a converter box. Here's the link to your manual.
http://www.mitsubishi-tv.com/img/220771
Sep 05, 2008 | Mitsubishi WT-46809 46" Rear Projection...
Mitsubishi(cs35403)sound ok but only blank with retraces
Good Day, den005;
Sounds like you a CRT drive problem. Does screen change when attempt to adjust the G2 voltage?
Your 1995 TV has served you well and I think it would be a waste of $'s to attempt to repair. Buy a new LCD, HD TV. FEB. 2009 is just around the corner (for HD only signal).
It sounds like CRT (picture tube) may be bad.
Good Luck, big IRISH.
Aug 15, 2008 | Televison & Video
Jvc projection tv
it will still be the lamp ,it took a spark its been damaged it will cause all the lines in the tv it has nothing to do with the circuit board
Jul 05, 2008 | Televison & Video
Does my plasma need set top box
The changeover slated for Feb 2009 only effects those people that receive TV signals from antennas. If you currently use cable or satelite, you do not requrie a set top box. Your particular model has an HD tuner so you would be fine in both cases.
Dan
May 06, 2008 | Televison & Video
Assessing my tv for hd servie
Yes , this will switch the digital back to anolog so your set will still receive your channels . The cutoff date is Feb. 19th 2009 so you have alittle time left. The boxes will avg. between $50 to $190 or more depending on what you what the box to do . Also there are coupons available from the goverment for rebates that will give you $40.00 off the purchase price , go to your post office for more info . Good luck
Mar 03, 2008 | Sanyo DS31520 31" TV
Making Trinitron HD-compatible
Every one seems to have a problem understanding what real will happen in Feb 2009 First if you already watch TV from a cable provider you WILL NOT have a problem, Now if you have a set that picks up a signal over the air (rabbit ears or antenna) then you will be affected and will need a converter. Check www.dtvtransition.org for more details. And Finlay if you watch from a satalight receiver you will be fine
Feb 19, 2008 | Sony FD Trinitron WEGA KV-36HS500 36" TV
Sony KP-57HW40 tv is what we have now and is this a high definition tv?
After the FEB 2009 cut over, your "OLD" tv will nolonger be able to receive OFF THE AIR signals as they will be broadcast over different frequencies. HOWEVER, as long as you subscribe to CABLE or SAT TV (Dish/Directv/etc) your old TVs will continue to work as they always have -- (because the signal is not OFF AIR) but you just won't have an HD picture.
Dec 21, 2007 | Sony KP-57WS500 57" Rear Projection...
Televison & Video Logo
47 people viewed this question
Top Televison & Video Experts
