Jensen CD4610 CD Player Logo
Posted on Feb 17, 2008
Cd player works but fades out time to time
I recently got my alternator changed and since then, every time i play my stereo it works for a while and then once i change speeds or downshift it goes out and you can here static like its a loose wire. I turn it off and turn it back on after about 3 minutes and its perfectly fine until i slow my speed. I have a 1993 ford F150.
A
Anonymous
U HAVE TO SEE ME I KNOW WHAT U STAEREO HAVE...323 254 3454
2helpful
2answers
My radio wont play Cd's. Everytime I put in a cd,
Your CD player's lens is not working, meaning either if you can open it and change the lens or install a new stereo, see which solution is cheaper.( you can find stereos for around $35) . Good Luck
2answers
Jvc kd-sx770 car stereo--radio works, but cd player doesn't
Hello beeswing70,
The player is recognizing that a CD has been inserted but is not able to read it.
Sometimes the lens assembly becomes contaminated and obscures the laser. I'd try using a commercial "lens cleaning CD" two or three times and then try a CD again. These lens cleaning CD's are widely available. If cleaning does not help, the player need professional service.
Hope this helps.
1helpful
CD's won't play on Home & Car stereo after Burning
I may add alot of times older equipment has a hard time reading burned cd's because when ever burning cd's the pits that are burnt into the cd are shallow. The faster the cd burns the more shallow it is... one thing you can try to do is burn at 2x in the WAV format cause it most diffenately will not read mp3 format being that old equipment. You may get lucky burning at 2x because the pits that it burns in the cdrom will be deeper. As the clarification said do use CD-R's. If this doesn't work at 2x chances are that equipment is just not going to be able to read a burnt cd period. Good Luck!!! I hope this works for you!!!
Sincerely,
cdixon18
The Man Inside the Machine
1helpful
Speakers arent playing any sound
if the car has a factory fitted amp . when you fitt a new radio you may need a bypass lead .this is one plug to plug for radio and the othere plug when you take off plug to the amp.
Face of clock looks faded. an 'E' before the time, radio wont
The E means you have tried to put an MP3 CD into it and it didn't work.  There is a button atop the clock radio that allows you to fade the backlight.
1helpful
2answers
I love loud music
i have alpine stereo's in all my vehicles and i have had this problem. if you run a 10-14 gauge constant wire from the stereo directly to the battery the stereo will not shut down in protection mode. it is not the cd it is the stereo going into protection mode because of lack of current not voltage. i hope this helps after i did this i could play the stereo as loud as it can go until my battery died
2answers
Aiwa Stereo
Same model, same problem. (CX NA-50) I have one that worked great for two years (at best) and I haven't used it since then. I recently decided to look for a solution via the internet.
I read somewhere else that there was a class action settlement with aiwa (now expired) since many of these units had this problem.
2answers
Speaker Pop when i turn on or change tune on radio
the speaker is probably worn is it factory is the speaker wires crossed need more detail
Trouble playing store bought cd's
itll be the lens on the player clean it with surgical spirit
Top Jensen Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
