Question about Garmin zumo 550 GPS Receiver
Garmin my zumo will not turn on, the screen is blank and there is no response from any buttons
  • 3 more comments
  • Anonymous Feb 23, 2008
    My unit will not switch on at all?
  • Anonymous Mar 02, 2008
    ZUMO WILL NOT TURN ON
  • Anonymous Mar 23, 2008
    Z umo 550 will not turn on, the screen is blank and there is no response from any button. If i pull the battery and replace it (requires special T10 bit), the unit will power on. Happens too often that I know how to overcome it.
  • Anonymous May 25, 2008
    Hi,my zumo is now about one month "old"and suddenly died today, no respons at all, have to try the battery trick? Jack, Buell
  • annjim Jun 01, 2008
    yep zumo will not power on no matter what trick of the trade I try double pressing of buttons removal of battery etc urgent help suggestion needed I go on vacation am Monday 6/2/08
Have had a similar problem a couple of times. Removal and refitting battery appears to sort it out.
Posted on May 28, 2008
Take out the battery and leave for a few minutes then replace.
Posted on Mar 02, 2008
I have contacted garmin and they requested i return it to them for repair.
Posted on Feb 18, 2008
I unplugged cable to computer during first update This is a garmin zumo 340
Try doing a Hard Reset
  • hard reset zumo 340 en 350 - YouTube www.youtube.com/watch?v=tWUDsiXu9QI
    • BY MRGPSNL
    • 6 MIN
    • 10K VIEWS
    2014-03-20 · Met een hard reset breng je je toestel terug naar de fabrieksinstellingen en is je apparaat weer ... hard reset zumo 340 en 350 ... Garmin Zumo ...
  • zumo 340LM ' Garmin buy.garmin.com > Shop > Automotive > Motorcycles Garmin Connect lets you search, plan and share your rides. Get Started /en-GB/GB/accessoriesAndMapsUrls/010-01043-06.ep. Customer Service. Product Support;
  • Hard reset Garmin Zumo 220, 550, 660 - YouTube www.youtube.com/watch?v=g9h9QtWWedk
    • BY MRGPSNL
    • 4 MIN
    • 25K VIEWS
    2014-03-20 · Met een hard reset breng je je toestel terug naar de fabrieksinstellingen en is je apparaat weer 'als nieuw ... Hard reset Garmin Zumo ...
  • Garmin zumo 660 665: How to Reset Video - GPS City www.gpscity.ca/videos/play/Q0td7d4BH9A How-to video for the Garmin zumo 660 665: How to Reset Video explaining its functions and installation.
  • http://www.bing.com/search?q=garmin+zumo+340+reset&qs=n&form=QBRE&pq=garmin+zumo+340+reset&sc=0-21&sp=-1&sk=&cvid=3C4EE77095704DEC935AD44372BE0B4D
    May 11, 2016 | GPS
    Zumo 550 randomly shuts down, sometimes won't power up again.
    Commonly happened when playing MP3's using an early version of the firmware. Install the Garmin updater and install the latest firmware and patches.
    My original unit did the same thing.
    Jul 13, 2009 | Garmin zumo 550 GPS Receiver
    Garmin Zumo 550 Freezes
    If the unit freezes with something on the screen, then the book that came with the unit tells you to push the power button and the + sign button at the same time and this should fix the problem. Good Luck.
    Jun 30, 2009 | Garmin zumo 550 GPS Receiver
    The garmin is on but frozen
    Look near the SN # and press the reset button.
    or
    with the garmin off, hold down the right bottom of the screen and turn the garmin on, it will then ask you if you want to perform a hard reset. Choose yes and that should fix your problem.
    Mar 27, 2009 | Garmin zumo 450 GPS Receiver
    GARMIN WILL NOT TURN OFF
    I have the same problem. Seems to happen when I get a photobox warning in a tunnel an after that loose satelite connection in the tunnel. This has happened two times at the same place, The only solution I`ve found so far is to take out the battery and start again. Hopfully there will come a software update for this soon!
    Feb 22, 2009 | Garmin zumo 550 GPS Receiver
    MY GARMIN ZUMO 550 NOT WORKING
    If no life in it what-so-ever, to get it to work.
    Try Press power button and + button at the same time,
    Check fuse in adapter,
    hold lower right corner of screen, turn on, when offered to clear all data, clear it, start again.
    Re-register, re-update,
    Should be good.
    Regards.
    Jan 09, 2009 | Garmin zumo 550 GPS Receiver
    My garmin zumo will not turn on.
    Have you also held the power on button for a couple of minutes, with the battery installed, and without the battery installed. There is an issue with the garmin dying, some cases a new battery helps, other cases, just leave the battery to charge for several hours, worst case is that you have to ship it to Garmin. I had a couple of Dead Zumo, however, removing the battery for several minutes, putting it back and clipping the zumo in the car holder did the trick for me. I also have a spare battery and allen wrench, just in case...
    May 26, 2008 | Garmin zumo 550 GPS Receiver
    Touch screen not working properly
    I'm not familiar with the Zumo family of GPS from Garmin, but if they are similar enough to the StreetPilot, you should be able to recalibrate the screen. In the StreetPilot series, to recalibrate you turn the unit off. Press and hold the bottom right of the screen and turn the unit on. Keep pressing the screen until the calibration information begins. Try this, see if it works on the Zumos, too.
    Mar 11, 2008 | Garmin zumo 550 GPS Receiver
    GARMIN c550 will not turn on
    There is an ISSUE with the DEAD ZUMO, however some of the are solved, and some need to be shipped back.
    There are a couple of options.
    1) remove the battery, keep power button pressed for a few minutes. install battery, try.
    2) fully recharge the battery with the wall charger, try
    3) With a fully charged battery, press and hold the + button and press the power button(hard reset).
    4) hold thumb firmly on top left of touch screen and hold power button till it switches on(hard reset).
    5) Try a different battery (fully charged)
    6) Ship it to Garmin
    Sep 08, 2007 | Garmin zumo 550 GPS Receiver
    Garmin zumo 550 GPS Receiver Logo
    199 people viewed this question
    Top Garmin GPS Experts
    SHARCNET-USA
    SHARCNET-USA
    TO Lady
    Are you a Garmin GPS Expert? Answer questions, earn points and help others
