My Ge wssh300gww will
My Ge wssh300gww will not spin. Once the cycle reaches spin all the green lights flash and it beeps. the water will not drain and the spin cycle will not engage. What can I do?
  • 1 more comment
  • mkey12 Feb 17, 2008
    I did try that thank you. It was unplugged all night and the same thing happens. I even tried different wash cycles. Same problem. All the lights come on just before the spin cycle and nothing happens
  • Gary Davd
    Gary Davd May 11, 2010
    I have the manual here if yoyu post your email I will send it to you i dont see anything about blinking lights you can try this
  • Gary Davd
    unplug the unit for 5 mins to reset board and see what happens sometimes this is caused by pwr spikes
  • 28 Answers
As the other posters mentioned, the problem with draining is most likely caused by a clogged filter. Mine had 14 cents, 2 zip ties, and a bra wire stuck in it. Here is the process (after many hours of swearing and bleeding) so that it should be pretty easy.
The first step is to tilt the washer back so the front is 3-5 inches off the ground. Prop it up with something. To remove the front lower panel, there is 2 phillips screws under the bottom edge. Remove the screws and the panel should drop down off the pegs holding the top edge in.
Inside, attached to the drum you will see a rubber boot with an accordion sleeve which contains the filter. There is 2 green spring hose clamps (the source of many expletives) and a silver phillips screw on hose clamp. To get at the filter, you should not need to, nor do you want to, remove the green spring clamps. You will spend hours trying to get them back on.
I have attached a picture for reference. Unscrew the silver clamp (large one, closest to drum) and pull down the sleeve to get access to the filter. If you are full of water, you can slide a pan inside the machine and just pull down the edge closest to the pan to drain until the water is gone. Reach down into the accordion (gross) and grab the filter. It has a lip on it so you will need to work it out through the accordion thing, but it likely has some really gross stuff in it. Clean it out, wad it back into the boot, and reattach to the drum. Dump about 2 gallons of water into your drum to make sure you are not leaking. Switch the knob to spin cycle and hit start 2 times. It should drain the water out within a couple seconds.
Posted on Sep 06, 2009
  • delbriggs Oct 22, 2011
    this was helpful .we remove the filter they contain very little dirt the problem now is it spins but it doesn't drain the water please help
After opening our washer (same model) I found a manual for techs taped inside. it gives instruction on how to get the error code and a chart to go with said code. We found it to be either the hose or the pump. We did the hose first, but that didn't work. we ended up taking of the black rubber part which had a white plastic filter. There was tons of stuff in it- gross. I highly recommend taking off the front and back panel, and using two people. It took me and my husband over an hour with lots of frustration just to get the three spring things back on and the hoses in place- it was awful. The design is awful, especially if you are supposed to do this frequently. Anyway, channel locks and vise grips worked the best over all. I will be checking pocks more diligently from now on! How does all that large stuff get down those small holes?
Posted on Jul 06, 2008
GE front load #wssh300g0ww agitates and drains (now that I emptied the filter) but still will not spin. During spin cycle, it agitates a few times then stops.
Posted on Jul 11, 2012
Thank you for responding. I did fix the problem. This washer does not say anything about cleaning a filter inside the rubber drain boot between the washer drum and the pump. I took it appart and found a plastic filter which was clogged with lint, change, and a sock. After cleanning this out the washer works great. Thanks for responding.
Posted on Feb 17, 2008
    How did you locate the filter
2 Suggested Answers
SOURCE: My Ge wssh300gww will
It is probably a clogged pump (don't look in owners manual for info - curiously it isn't in there - just says call tech - bolocks!)
Remove 2 screw on front bottom panel.
Remove cover.
Plastic boot and pump are on right had side. Clean out - and use the change to buy a drink - celebrating the fact you didn't have to spend hundreds on a tech!
Posted on Aug 25, 2008
Model gw 712. Why are lights 3, 5, 7, and 8 flashing?
Hotpoint, GE, RCA Washer Repair - Does not spin or drain ...
? 6:13
https://www.youtube.com/watch?v=69az-ZA3eSQ
Jul 10, 2013 - Uploaded by ApplianceVideo.com
Hotpoint, GE, RCA Washer Repair - Does not spin or drain - VWSR4150DAWW ... Fisher & Paykel ... my washer won't drainnor spin. what is the problem? .... But in the end, this video helped me fix our washing machine.
How to repair a Fisher Paykel Washing Machine
www.instructables.com/.../How-to-repair-a-Fisher-Paykel-W...
InstructablesHow do I remove the lid on a F&P intuitive eco washing machine to get to the motor panel?? IMadeIt ... It runs until the spin cycle and it drains but won't spin.
Dec 18, 2015 | Fisher and Paykel Washing Machines
Simpson 605 washing machine
it is worth having it properly diagnosed first before making a decision to spend money
could be a program board or start run capacitor
Nov 11, 2017 | Washing Machines
Fisher & Paykel Pride 5.5 won't wash. It fills with water then starts to beep. I can advance it to the rinse stage so it drains the water, once the water is drained, it starts to beep again. The...
Hi - the out of balance switch has activated this will be found under the lid right side if you bend lw enough you can see it hanging by a lever - it may have activated from the previous cycle - it needs to be freed - put it outside of the bowl and be sure its free to operate - if not it needs to be removed and replaced.
Jul 12, 2011 | Washing Machines
GE front load waher Model #: WSSH300GWW fills and agitates, but does not spin and drain.
take drain hose and lay it in a bucket to drain water or a wet vac works better. remove 2 scews from lower pannel it will drop down and come off. look for a accordian shaped black hose. disconnect it and remove junk in it. check inside the pump inlet for stuff it's the thing one end of the funny hose is hooked to. put back together and don't over tighten clamps nut driver tight is fine.
Feb 17, 2010 | GE Washing Machines
F&P washer lights on and beeps
Clogged pump stopped up drain. If the washer does not think all water was pumped out in 8 minutes then it shuts down. Slow drain is my first inclination.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Dec 31, 2009 | Fisher Paykel EcoSmart GWL15
Ge front load washer won't go into rinse cycle.
Check the cold water hose. My brand new machine had this behavior until I discovered a kink in the cold water hose - works great now.
Jun 03, 2009 | GE WSXH208A Front Load Washer
Whirlpool Cabrio WTW6600SW1: Won't drain
The washer drew half a tub of water on the "Bulky items" cycle, and stopped. All the lights on the cycle dial light up and flash, the machine beeps and the me error message in the "estimated time remaining" field is "Ld". I've tried to shut the machine down and change the cycle to "drain and spin" but it will not agitate, won't drain or spin.
Sep 05, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
Remove cover.
Mar 07, 2008 | Washing Machines
Washing Machines Logo
2,597 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
