Question about Maytag Performa PAV2200
Top of agitator comes off while washing
Sometimes when we are running the washer the top of the agitator comes off...im wondering how to make this stay on...its happened before but i just put it back on and it stayed and now its doing it again
  • 3 more comments
  • Anonymous Apr 22, 2008
    my washer agitator comes off while washing also, can't keep it on, it floats up and doesn't work. I can't see any way to lock it on.
  • Les0802 Apr 24, 2008
    Add me to the list, mine comes off too and it drives me crazy because if you have liquid softener in it, it all comes out. I think it's the plastic ring inside the bottom of the agitator that is slipping and pushing it up. Hopefully this can be fixed.
  • Batson May 25, 2008
    Same problem as others. The bolted down section of the agitator is not the problem. The area that keeps the fabric softener and screw cap works itself up off the tube that is bolted down.
  • Anonymous Nov 23, 2008
    Same problem with the auger plastic piece that won't snap into place anymore to the fixed agitator. Apparently, the only fix is to replace or glue as suggested in this thread. The plastic becomes worn and won't mechanically hold in place anymore. We have 5-years into this machine and hope for five more. I'll go with the glue idea.
  • old mess Dec 08, 2008
    I have the same problem - the bolt is tightly holding the agitator, but the top part just lifts up while working, so it is completely ineffective! Has anyone found a solution? If it is posted I've missed it... can you re-post?
    Thanks!
  • 868 Answers
This agitator has a bolt that locks it to the transmission Pull the softener area off the machines agitator off and look inside to see if the bolt is there.I'll help you any time a problem arrises
Posted on May 23, 2008
  • Archie Ferrarini
    Archie Ferrarini May 26, 2008
    If its the fabric softner  top section thats coming off the agitator,than the holding edges are probably worn  and unless you have to remove this section often glue it down other wise replace it
  • naturesprov Jul 19, 2011
    No, there is no bolt. It is some misdesigned plastic clip on for the top agitator. An idiot designed this. Better have some really strong water proof glue for this fix as there is a lot of upward force on the agitator.
Agitator doesn't run
The problem could be transmission failure
May 23, 2013 | GE WWSE5240D Top Load Washer
PAV2300 agitator bolt keeps coming loose
Loctite sounds the order of the day. Don't overtighten once the thread lock is in place and allow to cure before using machine.
Apr 23, 2012 | Maytag PAV2300 Top Load Washer
Mildew smell coming from washer and getting stronger daily. I have shook washer and there appears to be a small amount of water sloshing around after I have tried multiple times to spin it out. Approx...
What you need to do is run washing machine cleaner through the machine, typically monthly. Do not disassemble, you will not find anything that you can help with.
Also, be certain that you are having successful vacuum break at the discharge point of the drain hose. Sometimes you can draw water back into the machine. BE sure that you have a p trap on the drain into which you are draining.
Apr 12, 2011 | Estate TAWX700JQ Top Load Washer
How to take off the agitator on my kenmore washer mod 11094572200
if its a older model remove cap on the vary top on the agitator it is a screw under there
Sep 28, 2009 | Kenmore 22422 Top Load Washer
Knocking noice in agitation cycle
Do you get same sound if you run through a wash cycle empty (no clothes?) using detergent? If so, then likely a basket support has come loose (check deep inside along top ring). If not, then you may be overloading washer (unless using different sized loads), or the agitator is not working like it should, and basket is torquing.
Sep 15, 2009 | GE WJSR2070B Top Load Washer
Agitator top part is lose
pop the top off your agitator. There is 4 small plastic pieces that make the top part of the agitator work. Remove the 7/16 bolt in the center of the agitator and pull the top of the agitator out. Replace what they call a dog kit. Go to any parts store and they will know exactly what your talking about. They are olny about 6 bucks. its an easy fix so no need for a service technician.
Nov 14, 2008 | Roper RAS8445KQ Top Load Washer
I have roper washing machine
I don't know if the agitator is turning or not but the whole agitator is lose from the bottom part of the agitator. The washer also leaks. We have checked all of the hoses etc and there is no problem with that. We wonder if the leak isn't coming from the agitator being lose.
Nov 07, 2008 | Roper RAS8445KQ Top Load Washer
Washer does not agitate
hi thanks for the question it looks like a problem with the transmission but only if afer the water fills the tub the motor starts running if te motor docent start after its full look for a timer problem . so if motor runs on wash cycle and no spin transmission problem thanks the appliance doc please rate me.
Feb 23, 2008 | Frigidaire FEX831CS Top Load Stacked...
Washer
it sound like the drive block under the agitator is worn out does the bowl lift up and down?.remove agitator to see the drive block.
Jan 12, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing Machines Logo
222 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
